50/50 "Toyota" Engine Coolant 2014 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Raider0311, Jun 21, 2019.
  1. Jun 21, 2019 at 1:55 PM
    Raider0311
    Raider0311 [OP] New Member
    Jeff
    Oklahoma City, OK
    2014 Tundra 1794
    Roll n Lock bed cover, Icon Stage 8, RXT leaf pk, 18" XD Bully's, Nitto 35's, Billet UCA's
    So what's the deal with "Toyota" coolant. Getting ready to go to Colorado for 10 days and along with new brake rotors (time for new and open to suggestions), and an Icon Stage 8 suspension in two weeks, noticed my coolant is low. Is there actually "Toyota" coolant or will any 50/50 work and do you have to flush the system if you add something besides pink?
  2. Jun 21, 2019 at 2:37 PM
    Professional Hand Model
    Hand Protectors
    You could do a drain and fill with Zerex Pink for Asian Vehicles. Its HOAT (hybrid organic additive tech) thats phosphate enhanced for Toyota/Lexus.
    Drain the radiator and the two plugs on the block. Plug it back up and fill it. Run it with the heater on and squeeze the tubes to burp. Parking on a strong incline helps the burping process. Might take a few small top offs to get the levels proper.
    As an added measure, I like to disconnect the heater core hoses and pour new coolant in till the fresh runs through it. The reason being the heater core traps a small amount of coolant for which there is no refresh/draining capability except the process described above.
    Only concern is why are you losing/low on coolant now?
    Heads up that the fluid level changes with the temperature of engine. The hotter and the fluid reads higher. Checking when cold will show lower.
  3. Jun 21, 2019 at 2:48 PM
    Raider0311
    Jeff
    Oklahoma City, OK
    2014 Tundra 1794
    Just tried to respond with pic from my phone but not sure it went through. Actually looks lower today. Been over 100 the last two days. It's been sitting for about an hour now and it's below the low mark.
  4. Jun 21, 2019 at 2:52 PM
    Raider0311
    Jeff
    Oklahoma City, OK
    2014 Tundra 1794
  5. Jun 21, 2019 at 3:46 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    What coolant is in it now? That doesn't look pink in the photo.
    Probably should do a flush and fill with HOAT coolant. It's about time.
  6. Jun 21, 2019 at 3:49 PM
    Hand Protectors
    Not sure and can’t make out the low line, but you are at 5 years on your coolant so drain and fill as above. Keep and eye on the levels. Once you have it topped off to full make sure it stays there (hot/level and full).
  7. Jun 21, 2019 at 3:59 PM
    Raider0311
    Jeff
    Oklahoma City, OK
    2014 Tundra 1794
    Got it 2 years ago and haven’t had to do anything until now at 115k
  8. Jun 21, 2019 at 3:59 PM
    Raider0311
    Jeff
    Oklahoma City, OK
    2014 Tundra 1794
    No clue what’s in it
  9. Jun 21, 2019 at 4:20 PM
    JohnLakeman
    Whatever it is, it has a greenish-blue hue to it. Doesn't appear to be Toyota coolant. Worst case, it's more water than anti-freeze, If you park outside, better get it changed before winter.
    Toyota pretty much invented the HOAT anti-freeze technology. Any anti-freeze will work if you flush the system well, but HOAT chemistry is superior to the old green Prestone ethylene glycol in terms of corrosion resistance. It tends to be pricey from Toyota, and HOAT anti-freeze from Zerex would be the way to go. It has always been reddish-pink in color, but is in no way related to the safe pink anti-freeze used in RV water systems (propylene glycol). It was once available from Toyota as concentrate or 50/50. Not sure if they even sell the concentrate anymore. If you buy concentrate, mix with distilled water to minimize minerals introduced into the system.
  10. Jun 22, 2019 at 11:44 AM
    Raider0311
    Jeff
    Oklahoma City, OK
    2014 Tundra 1794
    Thanks everyone! I appreciate all the good info!
