6 lug wheel interchange
Discussion in '1st Gen Tundras (2000-2006)' started by CC80guy, May 23, 2024.
  1. May 23, 2024 at 6:20 AM
    CC80guy
    CC80guy [OP] New Member
    Larry
    Lehighton, PA
    2001 Tundra SR5 Access Cab TRD 4.7
    Will a 2015 Tacoma 6 lug wheel fit a 2001 6 lug Tundra? Research tells me both are 6x139.7 but I need to be sure before laying out the money. Thanks.
    Larry
  2. May 23, 2024 at 6:29 AM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    According to wheel-size.com 2015 was 5 lug. 2016 Tacoma has the same lug pattern and hub size as the first gen Tundra.
    depending on model they have different offsets though. So they may stick out too far or may rub the frame depending on which way they're offset differently.
    Would suggest a test fit on the front to make sure.
  3. May 23, 2024 at 6:40 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    All full size Tacomas, not the smaller 5 lug models have the same lug pattern and hub bore diameter as our trucks, but you may have issues with offset and such so the wheels may be too sunk in.
  4. May 23, 2024 at 7:03 AM
    CC80guy
    Larry
    Lehighton, PA
    Upper photo is my wheel, lower is the Tacoma wheel. I'm not seeing much of a difference in offset but opinions?
    Larry
  5. May 23, 2024 at 7:11 AM
    You can't calculate out offset by looking at the face of a wheel. You need a straight edge and a tape. Measure from the rear edge of the lugnut to the lip of the wheel (to a flat surface spanning between two lips). That will give you your backspacing. Once you figure out your backspacing then your width and you can calculate offset pretty easily based on the width of the rim.
  6. May 23, 2024 at 7:11 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Will physically bolt up. Not all 16" wheels fit if you have the 13wl brakes.
    interwebs says taco wheels are 28-32mm offset and the tundras are 13-17mm.
    wheels usually have the offset stamped on the inside to be specific.
  7. May 23, 2024 at 7:12 AM
  8. May 23, 2024 at 7:13 AM
  9. May 23, 2024 at 7:35 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Most tacoma wheels look like dog shit anyways. Your starfish in gold look siiiickkkk ask @The Black Mamba
    The Black Mamba and bmf4069 like this.
  10. May 23, 2024 at 7:35 AM
    CC80guy
    Larry
    Lehighton, PA
    A little searching turned up several photos right here on the forum of the Taco wheels on a Tundra, including this one so it looks good. I appreciate the responses.
    Larry
  11. May 23, 2024 at 7:38 AM
    FishNinja
    Lee
    06DC2wd
    If it floats your boat. More powah to yah baby.
    For Toyota OEM options 5 spoke splits though......
    bmf4069 likes this.
  12. May 23, 2024 at 7:45 AM
    CC80guy
    Larry
    Lehighton, PA
    Not going for look. The Tacos have nearly new snows on them for less than the tires alone would cost so they'd become the Winter tires, on in Nov, off in Mar..
    Tlar25, shifty`, bmf4069 and 2 others like this.
  13. May 23, 2024 at 7:47 AM
    FishNinja
    Lee
    06DC2wd
    a man of function???
    bmf4069 likes this.
  14. May 23, 2024 at 8:24 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Hashtag starfish gang.
  15. May 23, 2024 at 8:45 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Starfish 4 Life :cool:
  16. May 29, 2024 at 11:12 AM
    CC80guy
    Larry
    Lehighton, PA
    And the answer to the question is,, yes, they fit just fine.
    The Black Mamba likes this.
  17. May 29, 2024 at 12:25 PM
    Pretty sure that was a stock option? I feel like we went back and forth over this for a while, but can’t recall what year. Like ‘04 or something? I think it was in the catalogs. EDIT: maybe I’m thinking of the ones that had a square-ish cutoff toward the hub.
  18. May 29, 2024 at 12:29 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Stock Taco wheels have a different offset, right?
    KNABORES likes this.
