60000 Mile service
Discussion in 'Performance and Tuning' started by Dank1296, Mar 17, 2021.
60000 service
  1. Cost
    0 vote(s)
    0.0%
  2. Services
    1 vote(s)
    100.0%
  1. Mar 17, 2021 at 11:57 AM
    Dank1296
    Dank1296 [OP] New Member
    JC
    2015 Grey Tundra SR5
    Nerf Bars
    2015 5.7 4X4 coming up on 60000. You know the dealership gonna hit me up . I have a private mechanic that I trust. Never actually had a full service done. What does it usually entail. I had since 2017 and put 30000 miles on it and have had regular free oil change tire rotation. Only problems so far has been usual brake job(once)
  2. Mar 17, 2021 at 12:17 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    It is in your owners manual- change fluid in front/rear diff, xfer case, transmission too if you didn't do it before- all just drain and fill- don't flush the trans. Lube all zerk fittings in suspension and driveline. Air filter, cabin filter replacement. And the usual state inspection checks for brakes, suspension parts. Check your manual on coolant, I do not recall if coolant change is listed for 60k service.
    Dank1296[OP] and AZBoatHauler like this.
  3. Mar 17, 2021 at 12:19 PM
    timsp8
    NY
  4. Mar 17, 2021 at 2:39 PM
    Dank1296
    JC
    Nerf Bars
    Thanks for guide
  5. Mar 17, 2021 at 2:43 PM
    sethcphoto
    sethcphoto First Gen Freak
    Seth
    Seattle, WA
    2005 Tundra AC
    Coolant is every 100k
  6. Oct 14, 2021 at 10:17 PM
    mgnchakar
    mgnchakar New Member
    2016 Black Tundra TRD 4x4
    Thanks for the guide. That’s a lot of fluids to be changing!
  7. Oct 15, 2021 at 5:59 AM
    timsp8
    NY
    Most are easy like diff and transfer case fluid. Just drain and fill. Oil isn’t too hard, just messy for me. Search the forum for fluid recommendations and you can save some $ by not getting Toyota branded fluid.
