7 pin trailer wiring connector
Discussion in '1st Gen Tundras (2000-2006)' started by Seamcg1, Feb 17, 2025.
  1. Feb 17, 2025 at 9:00 AM
    Seamcg1
    Seamcg1 [OP] New Member
    2092 tundra
    None
    I have an 02 SR5 4X4. The pin connector gets chewed up any time I go off road. Has anyone installed the connector anywhere other than the bracket that hangs down beside the trailer hitch? If so, any particulars on location, etc. would be appreciated.
  2. Feb 17, 2025 at 10:05 AM
    yes!
    w666, koditten, assassin10000 and 6 others like this.
  3. Feb 17, 2025 at 11:36 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I like that! Mine is mounted on the hitch, and I've torn it off twice by backing into a trailer.
    Thanks for posting.
  4. Feb 17, 2025 at 1:13 PM
    koditten
    Kirk
    Midland of the Mitten
    Note: you do lose one of your plate lights, but the law only says it has to be lit. No biggy.
    I did the same, but I rotated mine 180 degrees. It's much easier to align the pins with the cover flap pulled down vs trying to look under the cover flap.
  5. Feb 17, 2025 at 2:54 PM
    The trailer plug and the receptacle is keyed. Auto aligns.
  6. Feb 17, 2025 at 3:02 PM
    koditten
    Kirk
    You are rotating the entire assembly. Keyed has nothing to do with it.
  7. Feb 17, 2025 at 3:12 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Subjective....and rotating 180 deg from the position @KNABORES has his installed creates more likely hood of weather intrusion....at the end of the day "to each their own"
  8. Feb 17, 2025 at 3:55 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Do you catch any flack from "law enforcement" about the lack of license plate light?
  9. Feb 17, 2025 at 4:43 PM
    koditten
    Kirk
    I agree.
    As person that hooks up a trailer 6 or more times a week, having that flap pivot down is a noticable improvement.
    It's also easier to see if the safety post on the flap is engaged with the plug to keep it solidly inserted.
    Do what you want. It's fine with me.
  10. Feb 17, 2025 at 5:22 PM
    w666[QUOTED] and koditten like this.
