7-Pin Wiring.... Which To What?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Apr 14, 2019.
  1. Apr 14, 2019 at 10:11 AM
    Greg Marmalard
    Greg Marmalard [OP] New Member
    2019 Tundra TRD Off Road Double Cab
    Howdy,
    Hopefully the reset of the ECU has solved my "trailer disconnected" problem on my 2019.
    Even if... the trailer side connection is floppy loose and I bought a replacement Pollak 760 that fits PERFECT! Nice snug contact that almost clicks in place! Takes effort to remove. Most highly recommended as well.
    That said I understand trailers, mines a 2019 Airstream Sport 22FB, don't always use same color code. So matching colors from a chart to my trailer may not work.
    I have the trailer side wiring diagram and know which colors go to which but don't know which sockets on the Tundra relate to which.
    Here's my Airstream wiring diagram.
    Thanks,
    Greg
  2. Apr 14, 2019 at 10:23 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  3. Apr 14, 2019 at 10:34 AM
    Greg Marmalard
    Thanks but..
    A quick look shows my problem.
    Yellow is back up in my trailer, left turn and brake on photos..... Other problems as well...
    I've seen at least 3 different configurations counting my wiring diagram...
    I have little faith Toyota follows this scheme too...
    Thanks,
    G
  4. Apr 14, 2019 at 11:15 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Can't blame you for lacking faith...I would confirm the truck terminals with a test light, forgetting about wire colors.
    Have a helper apply the brake, turn signals, etc. with the test light on different terminals until you have them all identified and recorded. Then install the connector on the trailer, connecting each color wire (known) to the same function position as the truck terminals. Connect the trailer power cord to the truck, and verify each function from truck cab to trailer rear.
  5. Apr 14, 2019 at 11:24 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Ignore wire colors, go by functions / pin position in the plug / socket. That part will be correct on your truck, and should be on your trailer. Regardless of wire colors.
