75W-90 gear oil for both diffs and transfer case
Discussion in '2nd Gen Tundras (2007-2013)' started by epicurese, Aug 6, 2023.
  1. Aug 6, 2023 at 7:30 AM
    epicurese
    epicurese [OP] New Member
    I'm planning to use “Valvoline SynPower SAE 75W-90 Full Synthetic Gear Oil” to do a drain and fill for both diffs and the transfer case. This oil is API GL-5/GL-4 compatible. This is an 08 5.7L Tundra.
    For the transfer case, I believe this will be compatible with the recommendation from the owner's manual.
    However, the owner manual states 75W-85 for both of the diffs. Will the 75W-90 be an issue here? I suspect the slightly increase viscosity of my proposed 75W-90 shouldn't be an issue, but I do live in a colder climate (USDA Zone 5, -20 F).
  2. Aug 6, 2023 at 8:08 AM
    Retired...finally
    I put the Valvoline in my rear differential a few hundred miles ago and the rear end hasn't exploded yet
    epicurese[OP] likes this.
  3. Aug 6, 2023 at 8:44 AM
    epicurese
  4. Aug 6, 2023 at 9:28 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    75w90 on the diffs is fine, but I would not risk it on the transfer, that one is a straight 75 and sadly there's not many quality 75w80 oils to stay in a safe range.
  5. Aug 6, 2023 at 9:30 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I used this exact oil in the transfer cases and differentials in my Tundra and AWD Highlander at 30k miles.
    Great price for a case of 12 on Amazon, I think it’s about 1/2 price of Amsoil severe gear. No explosions here either.
  6. Aug 6, 2023 at 9:39 AM
    epicurese
  7. Aug 6, 2023 at 9:49 AM
    Tbrandt
    Tristan
    Kansas City
  8. Aug 6, 2023 at 9:57 AM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    On Amazon there’s a German company I think revanol that makes it I use it and so do a lot of folks on tacomaworld much cheaper than the oem one that comes in a can from Toyota
  9. Aug 6, 2023 at 9:59 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    WILLINH likes this.
  10. Aug 6, 2023 at 10:00 AM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
  11. Aug 6, 2023 at 10:09 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    My 2017 transfer case is specified for single viscosity 75W.
  12. Aug 6, 2023 at 10:19 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I was going to order some Red-Line MT-LV.
    freedom123 likes this.
  13. Aug 6, 2023 at 10:28 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    Live in Maine and put 25k on rear with valvoline and no concerns. Over 300k miles on the gears
    WILLINH likes this.
  14. Aug 6, 2023 at 10:41 AM
    Tbrandt
    Tristan
    Kansas City
    WILLINH and OHwendTrd like this.
  15. Aug 6, 2023 at 10:47 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Transfer case manufacturer changed in 2014 as did the fluid.
    https://tundraheadquarters.com/borgwarner-toyota-tundra-transfer-case/
    AZBoatHauler, Zebruaj and ShawnTRD like this.
  16. Aug 6, 2023 at 10:52 AM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    75w90=:thumbsup:
    Shanet421 likes this.
  17. Aug 6, 2023 at 11:09 AM
    Tbrandt
    Tristan
    Kansas City
  18. Aug 6, 2023 at 11:42 AM
    Tbrandt
    Tristan
    Kansas City
    epicurese[OP] and Shanet421 like this.
  19. Aug 6, 2023 at 12:03 PM
    CTundraForMe
    CTundraForMe New Member
    Whatever you put in there, use good stuff. That rear diff is used 100% of the time the truck is moving.
  20. Aug 6, 2023 at 12:26 PM
    Retired...finally
    For some reason all the link gives me is Tundra accessories.
  21. Aug 6, 2023 at 12:27 PM
    Retired...finally
  22. Aug 6, 2023 at 12:29 PM
    Tbrandt
    Tristan
    Kansas City
    Sorry, didn’t actually link it there.
    Valvoline SynPower SAE 75W-90 Full Synthetic Gear Oil 1 QT, Case of 12 https://a.co/d/30CeBjq
  23. Aug 6, 2023 at 12:33 PM
    Tbrandt
    Tristan
    Kansas City
  24. Aug 7, 2023 at 10:29 AM
    bjohnson425
    bjohnson425 New Member
    Brandon
    Weird for my Sequoia which is the exact same engine/trans/ tow package the manual says 75W-90 for both my 2017 and 2021.
  25. Aug 7, 2023 at 11:25 AM
    Shanet421
    San Diego,CA
  26. Aug 8, 2023 at 10:59 AM
    bjohnson425
    Brandon
    I reckon they wouldn't have a transfer case if they weren't LOL yes they are both 4WD.. I suppose there is one BIG difference I forgot about the Sequoia has a torsen center locking diff.
    Shanet421[QUOTED] likes this.
  27. Aug 8, 2023 at 11:46 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    High Performance Lubricants can do the 75w-85 and the 75w
  28. Nov 21, 2023 at 10:44 AM
    Tbrandt
    Tristan
    Kansas City
    I switched to Redline MT-LV GL-4 in the transfer case, mainly out of concern that this Borg Warner transfer case appears to have a brass synchronizer. I don't want to run into issues with the GL-5 additives in my Valvoline 75W-90 eating away at the synchronizer. Cold weather performance was the second consideration, most of my 4x4 use is in the winter.
    I'm also amazed at how dark the front differential oil was at 30k miles, basically the same as the rear diff. The drain plug magnet also had a significant amount of metal sludge on it as well. The transfer case was as clean as honey at 30k miles and I honestly expected the front differential to be the same given my limited 4HI use and essentially zero 4LO use except for pulling a van-lifer out the ditch in Whistler, BC last summer. I'm guessing that the front axles spinning the gearset in the front differential still causes wear over the 2HI miles.
    I'm figuring on doing differentials every 30k miles and feel comfortable extending the transfer case out to 60k miles.
  29. Nov 23, 2023 at 2:28 PM
    danny.fuzz@ Yahoo.com
    danny.fuzz@ Yahoo.com New Member
    Danny
    2009 tundra TRD Rock Warrior
    Programmable tuner. 3 1/2 duel exhaust ,flow masters cold air snorkel kit, 2in frt 5in rear lift kit with lowered diffs.20in nito wheels.
    I use 75 w90 full synthetic it's about $60 a gallon at the auto parts store no issues so far
  30. Nov 25, 2023 at 2:23 PM
    riding4life162
    riding4life162 New Member
