87 vs 91 Octane For 07 Tundra 5.7
Discussion in 'Performance and Tuning' started by EricB556, Sep 1, 2021.
  1. Sep 1, 2021 at 8:07 PM
    EricB556
    EricB556 [OP] New Member
    Eric
    Cali
    2007 Toyota Tundra 5.7
    None completely stock
    Hello Tundra Stans,
    I currently own a 07 Toyota Tundra with a 5.7 and I've finally bought it off my dad. Currently it has about 240,000 miles on the odo and I want to preserve this truck as long as possible by giving it the best fuel possible. Its been in the family since it had 5 miles original on the dash and I don't want to destroy the fuel system in the truck, since Toyota recommends 87. However, I met a Toyota Tech that puts 91 in his 4.7 ( i dunno the year make and model of his tundra, but its a 2nd gen) and he recommends that I put 91 instead of 87 cause there are benefits to it and on other online forums people do recommend it. When is the best time to put 91 into the gas tank because I don't want to ECU the be messed up or anything in the fuel system. I someone want to explain this to me I would be extremely grateful.
    Also the truck is completely stock other than general maintenance on the truck!!!!
  2. Sep 1, 2021 at 8:18 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    How did it get to 240,000 mi with 87?
  3. Sep 1, 2021 at 8:30 PM
    EricB556
    Eric
    Cali
    Pretty good I changed the fuel injectors around 200,000 miles for regular maintenance, but I want more out of my truck and I know people run 91 on a stock ecu tune so i wanted more info from people that know more than I.
  4. Sep 1, 2021 at 8:35 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    If it runs 87, and don't lag or knock keep running it. If it does, go up a grade, see if it helps. Run 87 in my '17 with no issues.
    Cpl_Punishment likes this.
  5. Sep 1, 2021 at 8:37 PM
    alb1k
    Left Coast
    It's good
    I’ll be interested to hear. I believe high octane is for higher compression engines. I don’t think there is a benefit to 91 for your truck. Popcorn time.
  6. Sep 1, 2021 at 8:40 PM
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    If the stock tune is configured for 87, which it is because that is what the manual recommends, there is no benefit to running higher octane.
    If anything, you may lose a tiny bit of power running over 87.
    But it won't hurt anything either.
  7. Sep 1, 2021 at 8:42 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Never heard of higher octane screwing up a stock ECU. I run 87 in my 255k mile truck with zero issues. Run some Berryman’s or fuel cleaner of your choice in the tank from time to time, and you will be fine.
  8. Sep 1, 2021 at 8:44 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    His wallet?
  9. Sep 1, 2021 at 8:48 PM
    DVCNick
    DVCNick New Member
    Well, that...
    TFT[QUOTED] likes this.
  10. Sep 1, 2021 at 8:49 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I would just run top tier 87 from a station that gets lots of traffic. Higher octane isn't going to help anything unless, as mentioned above, you're getting knocking, which seems unlikely in a low compression engine that's designed for 87.
    mtucker and DVCNick like this.
  11. Sep 1, 2021 at 9:00 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Eric, Toyota designed and engineered your truck to run just fine on 87 regardless of what a tech or people on the internet tell you. Reread @alb1k nuanced answer above one more time and let it sink in. The only thing running 91 is going to do is as another poster noted and that's make your wallet lighter. Enjoy your truck.
  12. Sep 1, 2021 at 9:03 PM
    smokey0810
    Paid $2.55 for 87 tonight with our local grocery store discount.
  13. Sep 1, 2021 at 9:04 PM
    FarmerDan1008
    FarmerDan1008 New Member
    Danny
    2020 Limited TRD OR 4x4 Crewmax
    $4.55 here in california
  14. Sep 1, 2021 at 9:07 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Higher octane doesn't mean a better or longer lasting engine in a 5.7 Tundra unless you already have specific low octane symptoms.
    You're better to take the extra money you would spend on higher octane fuel and put it towards things that will matter like regular oil changes, extra car washes and maybe a wheel alignment.
    TFT and Cpl_Punishment like this.
  15. Sep 1, 2021 at 9:07 PM
    smokey0810
    Dang….you at least get a good description during that robbery?
    blackdemon_tt likes this.
  16. Sep 1, 2021 at 9:52 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Fuuuuu.... I know what you mean... man Costco $3.99... 50 cents end over end will get you. Free gallon of gas technically every 4 gallons...
    @EricB556
    Im a fellow original 07 owner 5.7 with 240k.. 87 religiously except for base gas, that was 91 since it would give it idling issues and hesitation... enjoy your truck..
  17. Sep 2, 2021 at 11:26 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Hello,
    Thank you for contacting us regarding your truck. It would be best to talk to Keith he owns an 2007, so he has hands on knowledge!!! He is out of the office most days, but is always available via phone. You can call or text him anytime at 760-877-4234. He does take many calls and texts a day, but is very good at getting back to everyone. Unfortunately, emails are just last to be responded to. Thank you for understanding.
    Thanks, Shawna
    coTony likes this.
  18. Nov 14, 2023 at 3:20 PM
    curtisclaire
    curtisclaire New Member
    Curtis
    2007 Toyota Tundra 5.7 Crew Max
    been using strictly 91-92 octane since day one - 2007 Tundra 5.7 CrewMax over 200K Miles
    Metro14536 likes this.
  19. Nov 14, 2023 at 3:30 PM
    AZBoatHauler
    So.Arizona
    That’s like $5k for something you got no use out of.
    des2mtn and Cpl_Punishment like this.
  20. Nov 14, 2023 at 4:00 PM
    curtisclaire
    Curtis
    Humm, a few hundred bucks a year and yet Tundra has never been in the shop except for regular maintenance….. runs strong as the day I got her…. You cheapskates would have gone through two trucks by now…..
  21. Nov 14, 2023 at 4:04 PM
    coTony
    Tony
    Montrose, CO
    I am interested to hear what he says. I have a dual tune which is barely noticable in the 87 tune mode but when switched to the 91 tune there is a noticeable difference for sure. Admittedly my tune is not perfect so more may be possible
  22. Nov 14, 2023 at 4:33 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    If you have a stock tune there will be no difference between 87 & 91 octane the gas isn’t any better the fuel will just have a quicker burn and the ECU will compensate if needed
  23. Nov 14, 2023 at 4:40 PM
    Tileguy
    Tileguy New Member
    Birmingham, Alabama
    2011 Toyota Tundra
    I own 2 tundras, one just under 500k the other at 293k. Ran 87 since the day I bought them. No issues with either truck.
    AZBoatHauler and Cpl_Punishment like this.
  24. Nov 14, 2023 at 4:57 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    I typically run 89 in mine. Started doing that when I noticed our 4Runner seems to like it a bit better. What I mean by that is it seems to have a smoother idle when under load (at stoplights, in gear, on brake, with ac engaging/disengaging). Other than that, I don't really notice any more power or change in mpg in the 4R.
    I'm not sure the 5.7 would be that picky, but it's habit now to just punch the 89 button.
    If you can find ethanol free for a decent price, run it. I've seen 2mpg increase in the Tundra running ethanol free gas.
  25. Nov 14, 2023 at 8:06 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    143K on the clock of my 2018. Ran 89 for about 3,500 miles last year, and saw zero difference in mileage, performance, sound, smell, knock, or anything else. Equated to an additional twenty cents per gallon for a guy that burns a lot of gas. Is it a lot? Nah. About $350-$400 per year at my rate. Other than that, I’ve been nothing but 87 E10. Zero troubles and just regular maintenance.
    Just like that one new guy with 200K on nothing but high-test.
    I think this is one of those things that people either buy into or they don’t. Kinda like tire pressure…. Run what makes you happy and what you believe in. Sometimes a placebo just tastes better!
    AZBoatHauler likes this.
  26. Nov 14, 2023 at 9:00 PM
    AZBoatHauler
    So.Arizona
    Cpl_Punishment and Saltyhero13 like this.
  27. Nov 15, 2023 at 3:27 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I've been sticking my finger in my ass on and off for the last 3 yrs.
    No issues as far as I can tell.
    I'm going to keep doing it.
    Just feels like the right thing to do.
  28. Nov 15, 2023 at 3:30 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Yes. Because physics, material science and engineering are just life choices and states of mind.
