8ft 1300lb Camper in 1st Gen Tundra Double Cab? Share your Set up
Discussion in '1st Gen Tundras (2000-2006)' started by SunMountain505, Nov 19, 2023.
  1. Nov 19, 2023 at 8:23 PM
    SunMountain505
    SunMountain505 [OP] New Member
    I'm curious if anyone has experience hauling an 8ft slide in camper in a first Gen Double cab. I've scoured the forums but haven't found much. How did your truck drive? Did it cause a lot of wear and tear? I know the payload is around 1600lbs, and from what I've read the Double Cab has pretty slim margin to haul weight given the GVWR. Any advice on a 1300lb dry camper? Post photos of your set ups!
  2. Nov 19, 2023 at 8:35 PM
    Payload is likely less than 1600# for a FGT DC. You haven’t found much out there because the setup would be less than ideal. Most go for a lightweight shell and RTT. Slide in campers really need 3/4 ton trucks for the suspension, payload and frame strength. 1300# is pretty light for a slide in, but as you mentioned, that’s dry weight. Few hundred pounds for gear, batteries and propane leaves you no payload for passengers and a top heavy, poorly handling truck.
  3. Nov 21, 2023 at 7:41 PM
    SunMountain505
    Thanks for the perspective.
  4. Nov 21, 2023 at 8:36 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    My camper weighs in at about 600lb lightly loaded so I'm not the best use case for your question. Also I have very little drive time with this camper in the tundra(<300 miles). At 600lbs the Tundra still drives great, but I would warn you that the loaded weight of a camper adds up quickly.
    I have had the camper loaded to over 1000lbs (previous truck)in food/gear/water/etc for a two week trip, and I rough it by most peoples standards.
    Personally I think traditional slide in campers are best suited for one ton trucks.
  5. Nov 22, 2023 at 7:57 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Somewhat related, for perspective . . .
    I tow / camp out of my DC w/ a shell.
    I try to pack as minimal for weight savings, but sufficient for basic needs, & safety.
    This set up / load seems fine for the truck. . . but I wouldn't want to go much more.
    Tongue weight is probably only around 100-ish lbs. & the boat / motor/ trailer around 1400 lbs.
    Cooler, generator, tool box, tackle, water, and some personal crap, and I get 15 MPG on the highway.
    Love these trucks . . . they just weren't made for much weight.
    I refer to mine as a 3/8 Ton. LOL.
  6. Nov 22, 2023 at 8:50 AM
    Technically a half ton is only 1000#. They are all overachievers these days.
  7. Nov 22, 2023 at 2:07 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Agreed . . . from my experience these trucks do 'ok' pulling (all things considered), but having just 'weight' in the bed seems to add up a lot quicker, if that makes sense.
    SunMountain505[OP] likes this.
  8. Nov 22, 2023 at 2:50 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    That's a sweet little Whaler. Is that custom wood bench?
    Thread jack sorry op
  9. Nov 22, 2023 at 4:30 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Thanks , yeah there's a lot more there than meets the eye. There's a stainless steel frame / basket that sits off the deck about an inch. Inside is the fuel tank, 2 batteries for the trolling motor, fuel filter, fire extinguisher, & tool kit. That seat back slides right out, and theres a base / support for a seat / leaning post in the middle. I got all the teak from a friends lumber yard . . . and even with a good guy price, it was still major sticker shock. I used silicon bronze fasteners for the teak, that was another dose of sticker shock as well! LOL
  10. Nov 22, 2023 at 5:31 PM
    Mine does just fine pulling.
  11. Nov 23, 2023 at 8:25 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Fwiw, my 2wd DC 8' bed has roughly 1800 lbs payload cap and I wouldn't haul around a 1300 lb slide in with it.
    Numbers are numbers on paper, but in reality, that's an awful lot of weight to haul around in the bed of a half ton for long stretches. And it's not just the dead weight, but the other stresses of wind, G force from turning, acceleration, braking, etc.
    "Can" the truck do it? Sure. Just not something I'd be comfy with.
    I've considered and weighed all the pros/cons of a diy slide in, a purchased slide in and a tow behind TT. Effort, cost, convenience, storage, maintenance, etc etc.
    In the end, I'll likely go with a smaller TT, if I do anything.
    I like the idea of a 600 lb slide in like posted earlier, but I'm guessing that wasn't cheap.
  12. Dec 5, 2023 at 2:28 PM
    SunMountain505
    RichterScale[QUOTED] likes this.
  13. Dec 6, 2023 at 11:17 AM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Look at a company like OVRLND CAMPERS or the Project M by 4 Wheel Campers. They're both lightweight... Around 400-500lbs for your truck. Plenty of standing room and a huge bed up top. Depending on how you look at it, a negative is the interior is completely bare and you have to build it out yourself. For me... That's a positive because I want to keep it modular and ready to be used as a truck. So my interior build will be pretty basic. Fridge, some kind of basic water pressure setup, and maybe a cot down below that turns into a couch like the Disc-O-Bunk cots. I already put a deposit down for my camper. It'll be ready in about 3 months.
    These aren't my truck. Just examples I've found floating around the web on 1st gen tundras
  14. Dec 6, 2023 at 11:21 AM
    dirtnsmores
    Southern CA
