A/C always defaults to recirculate
Discussion in '2.5 Gen Tundras (2014-2021)' started by GatorBodine, Aug 20, 2021.
  1. Aug 20, 2021 at 6:03 PM
    GatorBodine
    GatorBodine [OP] New Member
    A/C is usually left on when I shut the truck off but Every time I get in and startup my 21' Limited, the A/C defaults to where the recirculate air always comes on. In every other vehicle I've owned I got to choose when I turn on recirculate by hitting the button. Is this normal? The HVAC is not on "Auto".
    jewsNbrews likes this.
  2. Aug 20, 2021 at 6:12 PM
    Mwall931
    Mwall931 New Member
    2020 SR5 TRD pack
    There is a setting in the head unit under "vehicle" that allows you to change that.
    Clemsonman14 likes this.
  3. Aug 20, 2021 at 6:12 PM
    GatorBodine
    Well damn. Thanks
  4. Aug 20, 2021 at 6:13 PM
    Mwall931
    Mwall931 New Member
    2020 SR5 TRD pack
    No problem. I just found it myself the other day playing around in the settings.
    Mike59 and Toyotoholic like this.
  5. Aug 21, 2021 at 10:08 AM
    GatorBodine
    Well, it didn't seem to work. Went to "vehicle settings" then to Climate preferences or something to that effect, and switched the Auto climate control choice to "off" as it was "on". No change. Turn the truck off, start it back up and the recirculate air automatically still comes on.
  6. Aug 21, 2021 at 10:31 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Mine only does it if it's set to max ac.
    mountainpete and NewImprovedRon like this.
  7. Aug 21, 2021 at 10:36 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    If it’s set to max a/c it will default to recirculate. What’s wrong with it being on recirculate? The system works much more efficiently in recirculate anyway.
  8. Aug 21, 2021 at 10:37 AM
    GatorBodine
    What do you consider "max" fan speed all the way up? If that's the case it doesn't matter with mine as I rarely have the fan speed on high. I don't have a "max A/C" button
  9. Aug 21, 2021 at 10:44 AM
    Danman34
    Danman34 New Member
    Danny
    Not fan speed. Max AC is a temp setting. If your temp knob is all the way to the left, it’s defaulted to max ac
  10. Aug 21, 2021 at 10:55 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Once you get going and the inside temp drops it shuts off recirculate on its own.
    ejes and jewsNbrews like this.
  11. Aug 21, 2021 at 11:03 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    The temp control. If all the way to cool/max ac it recirculates. Anything under max ac and the recirculating stops. Also noticable click on the control when going into and out of max ac.
  12. Aug 21, 2021 at 11:08 AM
    GatorBodine
    Mine doesn't, it will get so cold I'll have to manually turn off recirculate. This HVAC system is way different than what I'm used to. Now, I usually have it set to I guess what is Max A/C because temp reading in the digital read out is "LO". One click warmer is 60, next click 65 and goes up by single digits from there. I like cold A/C, its hot here and I don't like the heat. Just couldn't figure out why its always on recirculate. Don't really need that setting in the mornings
  13. Aug 21, 2021 at 11:23 AM
    ScenicRoute
    Is the Control set to auto. Mine is set to auto 68*. Recirculate comes on every time on its own when I start and then shuts off once inside temp comes down.
  14. Aug 21, 2021 at 11:28 AM
    GatorBodine
    No not set to "Auto" I never use that feature. I read on online version of the manual (to lazy to go out to the truck) and its says if the ambient temp is high recirculate will automatically come on. It just never goes off, maybe it won't if set to "LO" Max A/C
  15. Aug 21, 2021 at 12:04 PM
    Mine comes on as soon as I turn the AC on.
  16. Aug 22, 2021 at 6:19 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    From Pages 345 and 352 of the owner's manual:
    When the outside temperature exceeds 75F (24C) and air conditioning system is on
    ●In order to reduce the air conditioning power consumption, the air conditioning system may switch to recirculated air mode automatically. This may also reduce fuel consumption.
    ●Recirculated air mode is selected as a default mode when the engine switch is in ON.
    ●It is possible to switch to outside air mode at any time by pressing (insert photo of recirculation button on/off) .
  17. Aug 22, 2021 at 7:53 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I just hit the AC button and then hit the recirculation button to turn it off. It's not a hardship.
    NewImprovedRon and pvn.beluga like this.
  18. Aug 22, 2021 at 8:04 AM
    GatorBodine
    I know its not hardship, I was simply just trying to figure out why it always defaulted to recirculate. Never had a vehicle do that and I've had several new vehicles over last decade with "advanced" HVAC so to speak
  19. Aug 22, 2021 at 9:42 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Why does my Kia default to floor vents when I accidentally hit the auto button? Some things in life just can't be explained.
