A750F compatibility
Discussion in '1st Gen Tundras (2000-2006)' started by Norcalyotaman, Jan 31, 2021.
  1. Jan 31, 2021 at 11:39 AM
    Norcalyotaman
    Norcalyotaman [OP] New Member
    2005 Tundra Double Cab SR5
    So my 05 Tundra v8 double cab 4x4 is going to need a new transmission in the near-ish future.
    About a year and a half ago it started having a pending code for the lockup on the torque converter. Had it check by a shop and they said it’ll last a while provided when towing or in hilly terrain I kick it out of overdrive. I did a complete flush with a bunch of additives, pan drop and filter change. It may have bought me some time but now it’s starting to get a little worse. So I’m starting to keep an eye out for low mileage donor.
    I’m not in a huge rush, it’s still driving, so I’d like to find the lowest mileage one I can. From research it sounds like the sequoia A750F is the same and will bolt up. Anybody know if the 4Runner V8 A750F will bolt up as well? I think all the v6 A750’s will physically bolt up but from what I’ve heard the electrical connections are slightly different, plus the clutch packs maybe a little less in the v6 models.
    Anybody have any knowledge on this? Thanks!
  2. Jan 31, 2021 at 11:42 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Anything with the v8 should bolt up. The v6 ones I THINK. Have the same wiring. But you’d need to swap the bell housing and the torque converter wouldn’t be correct for the v8
  3. Jan 31, 2021 at 7:32 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Yep any v8 A750F should bolt on. I did something very similar but completely opposite with my 02 Sequoia. Dropped the tranny in from an 04 Tundra 4x4 as they fixed the planetary gear issue in 03 and it fit with no issues. I couldn't use the transfer case however as the Sequoia has the manual 4lo.
