AAL or Airbags
Discussion in 'Suspension' started by beachmover9879, Aug 28, 2020.
  1. Aug 28, 2020 at 6:28 AM
    beachmover9879
    beachmover9879 [OP] New Member
    chris
    2020 Tundra SX
    Decked System - Yakima Overland Rack
    First off I am going to be installing the Bilstein 6112/5160 setup in the next month or so. Not looking to raise the truck more that 2". I'm not the tallest guy and loading 100 pound kayaks onto the roof rack is already enough of a pain.
    My question is what is everyone doing to keep the rear end of squatting with a loaded bed?
    I constantly have between 3-400 pounds daily between the Decked systen, Rack, and tools. On the weekends with kayaks and all of the gear it could be over 600lbs.
    Are there any AAL or Spring packs that don't raise the rear more than an inch or so and increase the load capacity?
    Would airbags be a better route?
    YardBird likes this.
  2. Aug 28, 2020 at 6:29 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  3. Aug 28, 2020 at 6:42 AM
    Welcome from NY.
    IMO, air bags would be better because you can always adjust it for the weight you are carrying.
    jeremyd likes this.
  4. Aug 28, 2020 at 8:53 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    I'm considering a similar route, and will be following your progress. I'm currently considering the Falcon line of shocks, because their rear shock has a an easily switched mode to compensate for times your payload is higher.
