AC Failed at only 2 years - $1,900 to repair
Discussion in '3rd Gen Tundras (2022+)' started by Eurodriver, Mar 29, 2024.
  1. Mar 29, 2024 at 8:24 AM
    Eurodriver
    Eurodriver [OP] New Member
    Is this a reasonable amount? Why did it fail so early? Compressor went out apparently.
    I shopped around and $1,900 was the best quote I could get. The dealer quoted me $2,700! That seems absurd, but I can't find any history about 3rd Gen tundras needing AC replacement.
    Am I missing something? This AC can't be brand new to the Tundra - why so much?
  2. Mar 29, 2024 at 8:32 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    How much of the estimate was for parts?
  3. Mar 29, 2024 at 8:40 AM
    DFS
    DFS New Member
    2022 Capstone Tundra
    That's like 10-15% of your Bluebook value, might as well total it!
    hagrid, Tom, ColoradoTJ and 5 others like this.
  4. Mar 29, 2024 at 8:50 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    Why doesn't this qualify as a warranty repair?
  5. Mar 29, 2024 at 8:55 AM
    Hella Krusty
    Hella Krusty New Member
    Not able to warranty this ??
    iforceAZ likes this.
  6. Mar 29, 2024 at 9:00 AM
    mass-hole
    mass-hole New Member
    he has like 500k miles on the truck already.
    1lowlife, GODZILLA, pwpblue and 4 others like this.
  7. Mar 29, 2024 at 9:10 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    Oh, tough. Really 500,000 miles? Is that correct? Then failure may not be early.
    GODZILLA likes this.
  8. Mar 29, 2024 at 9:10 AM
    Breathing Borla
    Northern Illinois
    lol, look at Euros posts.:nuclear:
    1lowlife, DFS and Medic343 like this.
  9. Mar 29, 2024 at 9:11 AM
    MaxPayne3
    MaxPayne3 New Member
    2024 Lunar Rock SR5 Crew Cab
    Just starting out but never will be done
    It sounds reasonable, right now no aftermarket parts are available, so the compressor is a dealer item. Add the fact that you have 1234YF freon which is generally a $500-$800 evac and recharge cost. Most shops like mine will not just replace the compressor, because when the compressor fails you get particles that go through the system and clog up or recirculate and end up causing the compressor to fail again. I always do at least the compressor and dryer/receiver, if we are unable to flush and out the condenser then we will also replace that as well. Most of my A/c jobs with kits are between $1600-$2200 depending on the system 134a or 1234YF and what parts need to be replaced.
  10. Mar 29, 2024 at 9:13 AM
    Should be under warranty. :notsure:
    iforceAZ, Medic343 and IsaiahCanada like this.
  11. Mar 29, 2024 at 9:24 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    @MaxPayne3
    I am curious. What vehicles do you do the most AC replacements on? Also where are you located as this may affect them going bad?
    The last one I had replaced was in a Chrysler just outside of warranty and the guy who did it thought Chrysler must of had a defect as he replaced so many evaporator coils in them. By far the manufacturer he saw the most. This was in Florida.
    Tundrastruck91 likes this.
  12. Mar 29, 2024 at 9:26 AM
    cmiles97
    cmiles97 New Member
    XP package
    Euro, it all started when you removed sections of the truck for bigger tires. :boink:
    hagrid and brtnstrns like this.
  13. Mar 29, 2024 at 9:28 AM
    MaxPayne3
    The aftermarket has been really slow to catch up with later model vehicles since Covid. I had a 22 Nissan Rogue in the shop yesterday and it needed a mass air flow meter and air filter. Neither one of those are available as aftermarket parts. The MAF at the dealer is a $500+ sensor.
  14. Mar 29, 2024 at 9:31 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    This is a good question. I also wonder if the Carista temp recalibration reduces the life of the AC system. I hope not because it sure improved the AC functionality.
  15. Mar 29, 2024 at 9:34 AM
    cmiles97
    cmiles97 New Member
    XP package
    Also keep the receipts. I bought a used 2003 Honda Element for the wife. The same thing happened to it. Years later I found out it was a defective part. I didn't have any of the paperwork for the repair and missed the window of reimbursement anyway. 2003 was the 1st year of the Element. Even with that repair, it was a great reliable vehicle.
  16. Mar 29, 2024 at 9:45 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Sorry you are getting hit with this, out of warranty repair costs are out of hand. The elephant in the room is the refrigerant and the new equipment and procedure to evacuate and recharge it. R134a is $8 a lb. at Walmart. 1234yf is at least 10x as costly and you need another machine.
    Rcflyersd likes this.
  17. Mar 29, 2024 at 9:52 AM
    MaxPayne3
    I'm in Arizona in the metro Phoenix area, and the heat here does not discriminate lol. I do see a lot of Ford and Hyundai vehicles for A/C related issues. Also there are technical service bulletins (TSB's) for certain vehicles like Chevy & GMC trucks and SUV's where the condensers had a bad weld/solder on them and they are prone to leak. 3rd and early 4th Gen Ram trucks also had issues with evaporators, which are a PITA in any new vehicle these days because the entire dash has to come out to replace those. I had a 3rd gen Tacoma under warranty and there was a TSB for a known issue with the A/C cutting out in ambient temperatures over 100 degrees. The fix was for Toyota to add a pusher fan to the front of the condenser. Took it to the dealership twice and they would not honor the TSB because they claimed it was "intermittent". It would only do it sitting at a stop in traffic, well duh because when you start driving airflow is moving across the condenser allowing it to cool down. It was a lease and the end of last summer is when I began experiencing problems with it and if I would have kept it I would have escalated the problem with Toyota corporate this summer. Anyway, to get back on track, when it comes to A/C compressors I generally only use the OEM or in the aftermarket a Denso, Delco or similar. Stay away from Murray, Duralast, and the other "store brands", I've had nothing but problems with them.
  18. Mar 29, 2024 at 9:53 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Euro, what's your mileage at now! I think that even with an extended warranty, you would be past the maximum mileage to fit under the warranty.
    It does seem that you got a good motor but things around the motor are failing!
  19. Mar 29, 2024 at 9:59 AM
    MaxPayne3
    No, pretty much anything 2018 and newer is a craps shoot on whether or not an aftermarket part will be available for it, depends on the part itself. My shop also specializes in heavy line work, transmissions and some engines and those parts are even harder to come by, even for stuff in the 8-10 year old range.
  20. Mar 29, 2024 at 10:56 AM
    vorkuta775
    vorkuta775 New Member
    seems odd. have you inspected the AC condenser? all the components to see if there is any physical damage? check there maybe all the hard wheeling did something? if not then yes I would certainly go down the warranty path if you have not started that already.
  21. Mar 29, 2024 at 11:45 AM
    mass-hole
    Not literally 500k but he is well beyond warranty.
  22. Mar 29, 2024 at 11:50 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    . The moon is 230,000 miles. He's almost there!
    Toyotoholic likes this.
  23. Mar 29, 2024 at 12:07 PM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Now if that isn't the pot calling the kettle black. :devil:
  24. Mar 29, 2024 at 1:01 PM
    AZBoatHauler
    So.Arizona
    This lives on the Sequoia.
    Toyotoholic, WILLINH, RobertD and 5 others like this.
  25. Mar 29, 2024 at 1:09 PM
    brtnstrns
    brtnstrns New Member
    2024 Tundra Platinum HV; 2022 Polestar 2
    The 2-1/2 Gen Gods are punishing you for speaking positively about your Tundra a few days ago
    vtl and SAGE63 like this.
  26. Mar 29, 2024 at 1:10 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Works great and is much cheaper
    Black Wolf and IsaiahCanada like this.
  27. Mar 29, 2024 at 1:21 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Have you checked your fuses? Maybe Rock auto has your compressor?
  28. Mar 29, 2024 at 3:08 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    This was my exact thought too.
  29. Mar 29, 2024 at 3:40 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    OP should wang his truck shitbox off of a few more pine trees. Mebbe that'll do it.
    @Eurodriver: this is your new online home. Transfer your flag now, plz.
    1lowlife, pwpblue, Black Wolf and 3 others like this.
  30. Mar 29, 2024 at 4:01 PM
    Hella Krusty
    But does the AC work??
    AZBoatHauler[QUOTED] likes this.
