Ac light is blinking on my 2010 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by kam1393, May 23, 2020.
  1. May 23, 2020 at 9:19 PM
    kam1393
    kam1393 [OP] New Member
    Hi, my ac light keeps blinking In the truck, and blowing warm air how do I fix . Please help
  2. May 23, 2020 at 9:27 PM
    Hdez87
    Hdez87 New Member
    2010 black tundra crewmax limited
    Leveling kit ,22”moto metal on 33x12.50x22 nitto ridge grappler , pedal commander, flares, morimoto headlights, morimoto fog lights
    Check to see if you have enough Freon if you do then check to make sure a/c compressor clutch is coming on ,check relays, finally if all checks out then you probably need a new compressor
    kam1393[OP] likes this.
  3. May 23, 2020 at 9:50 PM
    kam1393
    Ok. When I turn on the light will stay solid for a few seconds I hear the compressor come on the shut up when the light is blinking
  4. May 24, 2020 at 7:06 AM
    Hdez87
    Hdez87 New Member
    I would check Freon, then swap relays just to make sure relay is not bad
  5. May 24, 2020 at 7:12 AM
    Hdez87
    Hdez87 New Member
    So I did some searching and someone had the same problem they replaced the relay that’s under the hood that says mg clt that’s the magnetic clutch on the compressor
  6. May 24, 2020 at 10:34 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    I had a 2003 Suzuki XL_7 with a blinking A/C light every once in a while. No one could tell me what it meant (not even the dealer). It did not seem to affect the A/C, always blew cold air. Even after I had it checked and serviced, the light still came on occasionally. One of those mysteries of life I guess...
  7. Aug 16, 2023 at 6:39 PM
    Steves559
    Steves559 New Member
    2007 Tundra 5.7
    For me, it was too much refrigerant. 2007 tundra 5.7
  8. Aug 17, 2023 at 1:54 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    This sounds odd, but try this.
    Pull the Mag Clutch Relay from under the hood. Drop it on the ground ( hard ground) from about 4’ up, then re-install it. If the blinking stops, then replace the relay since it will start sticking again very soon. Found that procedure on my Highlander forum and used that same process on my Camry, Sienna, and Tundra and it worked EVERY time. Good Luck!
    CMikeB likes this.
  9. Aug 18, 2023 at 8:03 AM
    Dragon003
    Dragon003 New Member
    I just had the same problem after getting a new exhaust manifold installed. The connecters to the ac compressor must have got jossled loose but they didn't disconnect, I went under there and squeezed them together a bit and it fixed my issue.
  10. Aug 18, 2023 at 7:49 PM
    Dragon003
    The grey connector plugs I was describing in my previous post.
