AC only blows cold when driving
Discussion in '2nd Gen Tundras (2007-2013)' started by 2Good4You, Oct 5, 2019.
  1. Oct 5, 2019 at 2:21 PM
    2Good4You
    2Good4You [OP] New Member
    Theron
    2010 Tundra 5.7
    Hello everyone I’m new to the forum. I just purchased a 2010 Tundra 5.7 about 3 days ago. I notice that while I’m driving the AC blows just fine. When I’m sitting idle the AC blows less cold or on the passenger side I would even say it’s a bit warm. Any idea why this is or what it could be?? It’s a basic tundra no 4 wheel drive or anything.
  2. Oct 5, 2019 at 2:26 PM
    Adam New Member
    Yeah, most vehicles do that.
  3. Oct 5, 2019 at 2:35 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Low on freon or possibly a bad fan, It is not normal.
    15Yota likes this.
  4. Oct 5, 2019 at 2:46 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Easy to diagnose. See if your fan is spinning when in park and ac running full blast on Max air. If not, your fan clutch is bad. If it is, you’re low on refrigerant or your compressor is going out. Either way you have a leak in the system if it’s low. Need to find the leak otherwise you’ll have to continuously recharge and it will eventually just fail.
    Deuxlatch, Sas and TokerJoker like this.
  5. Oct 5, 2019 at 2:47 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Unfortunately as a AC system ages, the compressor seals get weaker. Make sure the freon is correct charge. And get the pressures checked.
    I had the same thing going on with my 2010 G37 before I sold it to buy truck stuff. AC was ok driving but in sitting in a parking lot in 95F heat wasn't good. When the car was new it would freeze your ass off going down the road. Freon was proper and had not really leaked down. Unless you got the equipment to mess with an AC you probably are going to have to take to a shop for a diagnosis. If you can't pull a vacuum on one and have set of gauges, you're spinning your wheels.
  6. Oct 5, 2019 at 3:02 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    The engine temp would go up and can be checked on the gauge. My estimation is that if the fan isn't spinning at idle, it would puke through the cap.
  7. Oct 5, 2019 at 3:44 PM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    At 1500 rpm the compressor is at full output, idling it is putting out less capacity.
  8. Oct 5, 2019 at 4:30 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    is your cabin filter clogged and restricting air-flow?
    sundance likes this.
  9. Oct 5, 2019 at 4:44 PM
    2Good4You
    Theron
    2010 Tundra 5.7
    How would I know this? I’m not machanically savy
  10. Oct 5, 2019 at 4:46 PM
    Rex Kramer
    Georgia
    It's behind the large glove box... It's easy to access, and I'm sure there is a Youtube video
  11. Oct 5, 2019 at 5:06 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  12. Oct 5, 2019 at 6:22 PM
    Danman34
    Danman34 New Member
    Danny
    Not true at all. You can sit at idle for a while without a fan. Temp gauge isn’t bible. It’s just a “gauge”.
  13. Oct 5, 2019 at 6:27 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    No cooling with a fan at idle instead of taking out heat from the engine? I idle for 20 or 30 minutes easily. Imagine a big ass traffic jam. The fan takes the heat out while you are idling. I dare you down here as it's still mid 90s. Fan goes south and you're toast. The wind takes over later transferring enthalpy.
  14. Oct 6, 2019 at 5:30 AM
    2Good4You
    Theron
    2010 Tundra 5.7
    Ok guys I checked out the filter & it’s new!
    Rex Kramer likes this.
  15. Oct 6, 2019 at 6:43 AM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    OK, I've read the above possible answers and none of them make any sense. Check the electric cooling fan mounted on the condenser in front of your radiator that should cycle with the a/c on. That has to be the problem. Cause it works when your driving right. Meaning the charge is ok and the cabin filter is letting air through it. So you're not condensing the 134-A before the evaporator coil. That is the electric fans job.:tumbleweed:
  16. Oct 6, 2019 at 7:16 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Not familiar with a 2010. Yes your answer would make a lot of sense. I am unaware of an auxiliary fan on a rear wheel drive truck. Front wheel yep 2 fans.
  17. Oct 7, 2019 at 9:28 PM
    leerich22
    leerich22 New Member
    Lee
    2011 Tundra Double Cab
    20" Wheels, Side Steps, Alpine Stereo, front level kit, tinted headlights
    Most likely your truck doesn't have electric fans. It is a clutch fan that is ran off the rotating engine. When you are idling, the fan is supposed to pull air through radiator, but if your clutch is weak on the fan, it won't be spinning enough to do this. When you are driving, air is being naturally forced through the radiator and a/c condenser. I have a 2011 4.6 Double Cab and I eliminated the clutch fan and installed electric fans (one 16 inch pushing air fan and one 16 inch pulling fan). I live in San Antonio Texas and it is still close to 100 degrees and my a/c is always cold whether I'm stopped at a light or cruising down the highway.
    I would also do as someone above stated to make sure the A/C freon level is topped off.
    2Good4You[OP] likes this.
  18. Oct 8, 2019 at 8:35 AM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    $7500 in upgrades
    If you have a/c you have a electric fan:yes:
  19. Oct 8, 2019 at 8:49 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    My 2013 Tacoma had this exact problem just out of warranty. It was slightly low on freon. Added freon and checked tightness on compressor lines. One turned a 1/4 turn
    Sold truck a year later and still blowing cold at idle.
  20. Oct 8, 2019 at 8:54 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Oh, crap. This argument is over with...@7.62Tundra said "enthalpy". :rofl:
    OR18TRD likes this.
  21. Oct 8, 2019 at 9:08 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    That's a fact jack:D. Cold is basically a sensory thing.
    Ain't no electric fan in my 2015. It's just like the old school days of a clutch that changes speed as it heats up.
    sundance and JohnLakeman[QUOTED] like this.
  22. Oct 8, 2019 at 9:09 AM
    JohnLakeman
    It's marginally low on refrigerant. Compressor doesn't do as much "compressing" at idle, but uses all the cooling to be comfortable while driving.
    If it was a 22RE (tiny little 4 banger, 120hp?), I would to check out the idle-up solenoid, but pretty sure the 5.7L doesn't need one. AC compressor would have little impact on a 5.7L as it cycles on/off.
    7.62Tundra likes this.
  23. Oct 8, 2019 at 10:00 AM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    $7500 in upgrades
    Show me a picture of the front of the radiator and I'll believe you
  24. Oct 8, 2019 at 11:54 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I don't need a pic and don't care if you believe me. I've been working on cars and stuff since I was a kid and still do.
    https://www.rockauto.com/en/catalog...10258,cooling+system,radiator+fan+clutch,6812
    Wife's FWD RX330 blew up a radiator due to the electric fans control going out. There are 2 fans. One that runs with the engine temp and the other that cuts in when the AC is running
    https://www.rockauto.com/en/catalog...848,cooling+system,radiator+fan+assembly,2181
  25. Oct 8, 2019 at 12:00 PM
    leerich22
    Lee
    My 2011 has a/c here in texas and had no fan other than clutch fan running off of waterpump pully. 4.6L v8.
  26. Oct 8, 2019 at 12:07 PM
    leerich22
    Lee
    I added this fan and all wiring with relay roughly 2 months ago.
  27. Oct 8, 2019 at 2:01 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Notice a difference?
  28. Oct 8, 2019 at 2:07 PM
    sundance
    sundance New Member
    I have that exact fan on my air compressors. You have it on wrong. It made to SUCK/PULL air. When you're going down the road it can't be moving any air.
  29. Oct 8, 2019 at 2:09 PM
    sundance
    sundance New Member
    That links to the fan clutch that is driven by the 5.7 engine itself.
    There is no electric fan from the factory for the radiator NOR the front AC/ATF air cooler.
  30. Oct 8, 2019 at 2:11 PM
    sundance
    sundance New Member
    You should able to tell if the AC compressor is cycling on and off sitting at idle. The engine should surge slightly when the compressor clutch engages. It will cycle in and out when you're sitting at idle. I will not stay engages all the time.
    If it is cycling in and out, then you know the compressor is trying to work. If it isn't, then you can go from there. I wouldn't add Freon just yet.
