Accessing mounting holes to install deck rail system
Discussion in '2.5 Gen Tundras (2014-2021)' started by SuperWhite20, Dec 3, 2019.
  1. Dec 3, 2019 at 5:26 PM
    SuperWhite20
    SuperWhite20 [OP] New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    I just ordered the 34071 short deck rail system. My question is - what have you all used to cut the spray on bed liner in the mounting holes to get to the threads. I know I can use a tap. But what is your secret method to clean the holes without messing up the threads. That bed liner is some hard stuff. I appreciate all advice. I am sure it has been asked before but I can’t find a post on it.
  2. Dec 3, 2019 at 5:36 PM
    If you know where the holes are, you could probably drill a small pilot hole to get started. I thought someone said that you can clear the hole with an X-acto knife.....??? Line-X is harder than Rhino lining I think, but others that have had this issue will chime in.
  3. Dec 3, 2019 at 5:38 PM
    Zero One Actual
    Correct. Use a blade and cut it off and it will peel off like a scab.
    Black Wolf likes this.
  4. Dec 3, 2019 at 5:40 PM
    AZTundra
    Paul
    Phoenix, AZ
    X2 on blade.
  5. Dec 3, 2019 at 5:42 PM
    SuperWhite20
    Robert
    Georgetown TX
    Thanks for that solution. I am waiting on the rails so I can now get busy with the knife.
  6. Dec 27, 2019 at 11:07 AM
    SuperWhite20
    Robert
    Georgetown TX
    I actually used an 8mm tap and it cut the liner material right out of the hole. The rails mounted right up and torqued the screws to 66.5 inch pounds. I had that torque wrench over 30 years and it’s the first time I used it? Never know when you’ll need a tool.
    NewImprovedRon likes this.
  7. Mar 4, 2020 at 4:34 PM
    rdclutch
    rdclutch New Member
    2020 Tundra SR5 CM / 2006 4Runner - 180,000 Miles
    Hi Guys-
    I just purchased a 2020 SR5 CM with the spray-on bedliner from the port. I asked the dealership to install the deck rail system since I saw that where the threads would be were sprayed over. They ordered the part but when they went to install it, the tech says they couldn't do it because with SR5 that have the spray on bedliner, the threaded holes are not there. I thought what????? They said on previous years you could just back tap it. But not in the 2020. Anyone have experience with this with this situation? Thanks!
  8. Mar 4, 2020 at 4:56 PM
    15whtrd
    15whtrd Mr. Blonde
    That would be new to me. I was pretty sure all the beds come ready to accept the rails. I would take a closer look it’s possible they are just filled in with liner material.
    To anyone else that wants to get their bed sprayed, you could leave some screws in the threads if you’re worried about them getting filled or put a little grease just inside the hole so the material won’t stick.
    AZTundra likes this.
  9. Mar 4, 2020 at 5:01 PM
    AZTundra
    Paul
    Phoenix, AZ
    That was my thought too, but I'm not familiar with the 2020's. Can't imagine they'd be any different though.
    15whtrd[QUOTED] likes this.
  10. Mar 4, 2020 at 5:02 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m kind of thinking the dealer gave up too easy. Gave it a quick look and saw no holes and moved on. Probably was the oil change guy LOL
    AZTundra[QUOTED] likes this.
  11. Mar 4, 2020 at 5:17 PM
    rdclutch
    rdclutch New Member
    Thanks guys! Maybe I’ll just drill some small pilot holes to see if the threads are there. Truck just rolled off the lot so it’s stock and frills but love that Cement color!
    Paul B likes this.
  12. Mar 4, 2020 at 5:25 PM
    15whtrd
    15whtrd Mr. Blonde
    Can you see divots where a hole might be?I wouldn’t go drilling in just any old place LOL.
    rdclutch likes this.
  13. Mar 4, 2020 at 5:31 PM
    rdclutch
    rdclutch New Member
    @Mr.Blonde. Lol. Death by 1000 tiny prick holes. I’ll order the part and line it up based on the pin inserts holes. Should give me an idea of where that threaded holes “should be”. @SuperWhite20 - sounds like you did this on your 2020?
    15whtrd likes this.
  14. Mar 4, 2020 at 5:36 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Cut just a bit off the threads of a screw with a grinder. The sharp edge will clean the threads.
  15. Mar 4, 2020 at 5:48 PM
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    David
    Alaska
    2020 DC TRD-OR, Cement
    Let us know what you find out. I just purchased a 2020 DC and was planning on getting the deck rails soon. Thanks!
    P.S. Great color choice! Love the cement. Don't see any here in Alaska.
    fiveduece and rdclutch[QUOTED] like this.
  16. Mar 4, 2020 at 6:13 PM
    15whtrd
    15whtrd Mr. Blonde
    Should be right in these white spots. I would use a nail or ice pick type tool, and poke around.
    AlaskanAssassin likes this.
  17. Mar 4, 2020 at 8:22 PM
    Chewy65
    Chewy65 New Member
    2015 Black Tundra SR5 DC
    Level kit, upgraded speakers/amp., compustar drone system, changed center seat for center console
    I used a 7/16 drill bit. It is big enough that it made a cut where the bolt hole is but couldn't reach the threads and didn't damage them. You can feel locations with your finger, there is enough flex in the bed liner spray.
  18. Mar 5, 2020 at 12:22 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    Superwhite’s tundra is a 2020
  19. Mar 5, 2020 at 2:55 PM
    rdclutch
    rdclutch New Member
    Hi Guys-
    Appreciate all the feedback. So just like @SuperWhite20 ’s experience - the threaded holes are there on my 2020 SR5. I just felt around for soft spots and used a thick needle at first to test. It went straight through. Thanks @Mr.Blonde for the pic. I guess you were also spot on about the dealership tech guys giving up lol.
  20. Mar 5, 2020 at 4:02 PM
    SuperWhite20
    Robert
    Georgetown TX
    I just used a 8x1.25 bottoming tap to clear the liner spray out of the holes. Threads are there! Installed mine with no trouble in a 2020 SR5. Then, went on Amazon and ordered the PFC TACOMA tie downs. They are black and look great in the bed. Also ordered 4 mini PFC Tie downs. No issues, all looks great and as good as the aluminum ones that came with the rails.
  21. Mar 5, 2020 at 4:04 PM
    SuperWhite20
    Robert
    Georgetown TX
    I’m not real impressed with my dealer techs. Six times for tire balance! Three tires later it still shakes. Tech puts wheel weights on top of old weight tape still on the tire!
  22. Mar 5, 2020 at 4:14 PM
    Captdan762
    Captdan762 New Member
    TN
    2020 Tundra, 2017 4Runner
    Glad I saw this thread. Someone at work sold there 2014 Tundra and gave me there deck rails. I didn’t see any holes. But I know they should be there.
  23. Mar 5, 2020 at 5:12 PM
    AlaskanAssassin
    David
    Alaska
    What did your dealer charge for the deck rail kit?
  24. Mar 5, 2020 at 6:26 PM
    rdclutch
    rdclutch New Member
    $195 plus tax. If you order from Sparksparts, it’s $175 but shipping will bump it to $200.
  25. Mar 5, 2020 at 6:35 PM
    SuperWhite20
    Robert
    Georgetown TX
    I went online and got mine for $196.19
  26. Mar 5, 2020 at 7:16 PM
    AlaskanAssassin
    David
    Alaska
    Unfortunately, I can't really utilize SparkParts because shipping to Alaska is redonk (see below)! Also tried ordering a TRD Pro grill and hood bulge and shipping was $400+.
    The sole dealer up here has a monopoly too.
  27. Mar 18, 2020 at 6:32 PM
    fiveduece
    fiveduece I like to party.
    Brandon
    2020 TRD sport MGM crewmax
    tint, N-Fabs, trifold cover, bilstein 5100 w/spacers, +2 shackles, MT deegan wheels
    Can I ask where you got them from?
  28. Mar 18, 2020 at 7:54 PM
    SuperWhite20
    Robert
    Georgetown TX
    Amazon - I went by the part number. One came up but then there were three other dealers listing it below. It has been a few months so it may have gone up. It’s Like PT278-34071. I mistakenly said $137.00 I was $196.19. I think $137.00 was what I told my wife.....
    Zero One Actual and fiveduece like this.
  29. Mar 19, 2020 at 1:43 AM
    fiveduece
    Brandon
    Haha, well played. Thanks for the info, I've found them for 180 or so, hadn't seen them under 150 yet. I may do this eventually, too many other things need done first though.
