Add water to battery?
Discussion in 'General Tundra Discussion' started by Jota21, Jun 9, 2020.
  1. Jun 9, 2020 at 10:42 AM
    Jota21
    Jota21 [OP] New Member
    i thought this was a thing of the past with modern/'sealed' batteries, but now that my dad has retired, he's been creating things to work on. I just assumed this was one of them. Apparently, you're supposed to add distilled water to cars????? I've been driving for 20 years and have never done this and have never had batteries die prematurely.
    Anyone do this with their truck or other vehicles?
  2. Jun 9, 2020 at 10:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    We have to add distilled water to electric vehicles at work. They are used 22 hours a day. Adding water weekly. They have battery banks of 12, or more.
    I check my levels in my tundra battery, but have never needed to add.
    YardBird likes this.
  3. Jun 9, 2020 at 9:09 PM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    The reason distilled water is suggested is because it has very few impurities, which can over time contribute to corrosion in the battery plates. That being said, most new style batteries are 'sealed', and under normal circumstances will almost never need water added. The only time I use distilled water is when I am filling a new battery for the first time.
    Tundyfundy likes this.
  4. Jun 9, 2020 at 9:19 PM
    SoCalTecHead
    SoCalTecHead New Member
    Tony
    Orange County California
    2020 Cement CM Limited
    A word of caution from someone who has had a DROP of battery acid in his eyes (I use to work for Exide Battery)... ***wear eye protection***. It didn't do any long term damage that I'm aware of, but it felt like a hot dagger burning through my eye. So anytime you are touching a battery be safe as you never know when something could crack or pop off and splatter acid.
  5. Jun 9, 2020 at 9:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yesterday during my Opsho treatment of my rear bumper support (for those who do not know Ospho treatment is diluted phosphoric acid. My understanding is that it etches the metal on a microscopic level, and dissolves rust particles. Letting new paint cling on much tighter.)
    I apparently had gotten some either on my forehead, and it dripped down under my safety squints due to sweat, or it just flew right over my glasses, and into my left eye. Either way it hurt, and felt like what I can only describe as "my eyeball is melting."
    I read the instructions prior to use, and immediately flushed with the garden hose that I had handy just for that occasion.
    Just make smart decisions even if you're doing dumb shit like me
  6. Jun 10, 2020 at 4:01 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    The safety advice here should be listened too.
    As far as distilled water, I use it everywhere including the radiator. But then again, I worked in a lab and had access to reagent grade distilled water. Long Island has hard water. I noticed that if I used distilled even the radiator built up less mineral deposits. In a battery, it would make sense too. Impurities could shorten the life of the battery. How much may depend on the tap water. It isn't the same throughout the country.
    Rex Kramer, YardBird and Tundra2 like this.
  7. Jun 10, 2020 at 5:12 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    If your battery has caps that can snap on & off, your battery can & should be topped off with distilled H2O periodically. This is especially important in hot climates... I topped off the batteries in both trucks and the riding mower last week.
  8. Jun 20, 2020 at 11:55 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You can get an electrolyte tester for around 20 dollars that will help you test the acid in your battery. The plates in your battery should never be showing so if they are add some water. With that being said, when it dies, and it will as Toyota uses weak batteries, buy an AGM battery and you’ll never have to worry about it again as they don’t use liquid electrolyte, only a gel and they are sealed.
    TechWrench likes this.
  9. Jun 20, 2020 at 11:57 PM
    Tundyfundy
    Bay Area, CA
    200 bucks is nothing to spend on a battery you use every time you run your truck and something that directly affects reliability and peace of mind. I’d gladly pay that to never have to worry about adding water for 3-5 years.
    FrenchToasty likes this.
  10. Jun 21, 2020 at 7:55 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The 2015+ Toyota batteries do have removable caps, but they never need water...they don't last that long. :D
  11. Jun 21, 2020 at 8:35 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    The OEM batteries seem to be really picky about needing water. Battery acid is nasty stuff, so that’s another good reason to upgrade to zero maintenance AGM
    Tundyfundy and NewImprovedRon like this.
  12. Jun 21, 2020 at 8:57 AM
    TechWrench
    Gary
    Hawley, PA
    Being new to the Tundra experience, I can't speak to the oem battery life expectancy in them, but I have owned two 4Runners and my battery experience with them is quite amazing. I bought a new, '03 4Runner SR5, V6. I kept it for about 11 years. The original battery lasted the entire time I owned it. At about year 9, because of a trailer wiring problem, the alternator in it fried while I was on a hunting trip, and I had to drive it home using only the battery, about an hour trip. About 45 min into the ride home, the battery finally gave out, and I bought a replacement at a local Walmart, to make it the rest of the way home. I put the oem Panasonic battery on a trickle charger, and when the indicator read green, I put it on a block and left it in my garage as a spare. in '14, I acquired a 2nd '03 4Runner, V8 from a friend, with over 235k on it. It didn't have the original battery when I bought it. That battery, a Walmart Everstart, started to fail about two years later, and in a pinch, I put the old oem battery I had been saving, after bringing it up to full charge, in it place. I intended to get a new battery when I had the chance. I continued to drive the 2nd 4Runner for almost 4 more years, still on the same '03 oem Panasonic battery right up until the day I traded the 4Runner in on my '08 Tundra I now have. And from what others in the TR4.org forum have posted, the oem Panasonic batteries in the 4Runners were known for their amazing durability.
    I can't explain it, but I know it happened.
    Tundra2 likes this.
  13. Jun 21, 2020 at 9:14 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Distilled or De-ionised water is used to top off batteries because it has a no natural polarity. When added to battery cells it then can move towards the positive or negative charge of the cells more easily. Tap water has precharged ions that take on a positive or negative base, which when added to a battery, can actually slightly slow the charging process until the new water acclimates to the new polarity.
    So for good measure, always add distilled or De-ionised water to a wet battery for best results.
