Adding 33's with only a leveling kit
Discussion in 'Wheels & Tires' started by amymills21, May 13, 2018.
  1. Jul 15, 2018 at 10:31 AM
    stoshu73
    stoshu73 New Member
    Scott
    I just had done a Readylift 3/2 SST level kit wanted to go with 295/60/20's but who installed them said it would rub so they recommended 285/60/20's. Not sure if they were correct or not but I don't really mind the 33's.
  2. Jul 15, 2018 at 11:36 AM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
  3. Jul 15, 2018 at 5:57 PM
    WEAL
    WEAL 2018 CM SR5 4X4 SILVER
    2018 Silver SR5 4WD
    @Rngr188 ... Thanks! Looks great.
  4. Jul 17, 2018 at 7:30 AM
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Ultimately I wanted to keep my black tss rims that are 20". Apparently they are +50 offset, so don't think they'd fit with 35s and a 3/1. :(
  5. Jul 17, 2018 at 7:42 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Ya’d need spacers bud. With 1.25” ones you should be able to fit 295/65R20’s.
  6. Jun 13, 2020 at 7:59 AM
    PotroRR
    PotroRR New Member
    2016 TOYOTA TUNDRA PLATINUM
    I hope everyone is well.I am new to this suspension modifications and I would like your help .... I have a 2016 TOYOTA TUNDRA PLATINUM without any modifications, and I would like to put 33x12.50r18 wheels and tires open country mt thank you appreciate
  7. Jun 14, 2020 at 10:47 PM
    captjay08
    captjay08 New Member
    I don’t think a 33x12.5r18 will fit on a stock setup. A 2” level kit with some trimming to a minimum or 3” lift kit without trimming but heat gun on liners should do it.
  8. Jul 8, 2020 at 4:02 PM
    Scavezze1971
    Scavezze1971 New Member
    Greg
    2018 SR5 Plus TRD Off-road (Canadian)
    What tire is that? Beautiful truck!
    Rica25 likes this.
  9. Jul 8, 2020 at 10:06 PM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    I have a 3/1 level kit and about to buy 33’s as I really like 19 TSS 20’s it came with.
    Rica25 likes this.
  10. Jul 8, 2020 at 10:21 PM
    Grundysidemount
    Grundysidemount New Member
    2020 Tundra 4x4
    What % tint do you have all around
    Rica25 likes this.
  11. Jul 18, 2020 at 6:48 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I got a 3/2 level with -1 offset. Should I go 33's which should be easy no mods or should I squeeze 35s?
    Rica25 likes this.
  12. Jul 18, 2020 at 7:15 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    Anything over stock will change gearing. I have 17s with 295/70s and experience some downshifting/ gear hunting. I compensate with my right foot, nannies off, and sometime tow haul mode. You can search gear ratio calculators for numbers - with 33s you should still be in the "green" but it does change from stock. Personally not an issue for me on my set up.
  13. Jul 20, 2020 at 8:47 AM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    It's a Toyo open country at2 I believe
  14. Sep 3, 2020 at 3:44 AM
    tumaro
    tumaro New Member
    SW Sr5 Crewmax
    Any side shots or front to rear? Curious how the offset fits.
  15. Sep 3, 2020 at 4:53 AM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    This doesn’t look too small at all
  16. Sep 3, 2020 at 5:40 AM
    Mdjamesd
    Mdjamesd New Member
    Just 2" in the front.
  17. Sep 3, 2020 at 7:10 PM
    Hartsy8
    Max
    2020 MGM 1794
    I think that looks great on stock wheels
    PermaFrostTRD likes this.
  18. Sep 4, 2020 at 5:30 PM
    Mdjamesd
    Mdjamesd New Member
    Thanks!
    275/70/18 Toyo says its 33.2" if I recall correctly.
  19. Dec 29, 2020 at 5:16 PM
    #49
    Spittfya
    Spittfya New Member
    I want 3 inch leveling kit with 35 but I want to trim
  20. Dec 29, 2020 at 6:46 PM
    #50
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I'm running 33x12.50x18 on +12 offset, no lift, no rubbing. Just removed front mud flaps
    Sean492 and MTRock like this.
  21. Dec 30, 2020 at 12:38 PM
    #51
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I have a 3/1 with 285/75-18 on +18 offset wheels, the tires are slightly larger than 35's but an inch narrower. I had to push in the front liners and I have a mild rub on the drivers side body mount. For you, the 33's will not be a problem at all. I had them on my 2014 with a spacer leveling kit.
  22. Mar 17, 2021 at 4:43 AM
    #52
    tystoyota123
    tystoyota123 New Member
    Tyler
    2020 Toyota Tundra TRD off road 4x4
    3/1 Level lift kit
    Correct me if i’m wrong i’m very new here but isn’t 275/75/18 in inches around 34?? just curious because I love the way your truck looks with those tires I’m putting a 3/1 on mine and torn on what size tire to get so not sure if you meant 275/70/18 instead - thanks!
  23. Mar 17, 2021 at 6:42 AM
    #53
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    2 inch level with 33s , 275/60r20 with 20x9 fuel torque +20 offset. I feel mine are borderline small for a 2 in level. 3/1 lift would look goofy with 33s imo
  24. Mar 17, 2021 at 7:04 AM
    #54
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Just shy of 2" in front with 33's (295/70r17). Also think my tires are on the cusp of being too small...maybe 295/75/70 next time- not sure as I feel it is a good balance now and not impacting performance very much.
    BravoDeltaRomeo likes this.
  25. Mar 17, 2021 at 11:29 AM
    #55
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    @Wahayes and @UTAHRTK
    Both your trucks look good with that Lift and Tire combo to me. :thumbsup:
    UTAHRTK likes this.
  26. Sep 9, 2021 at 8:23 AM
    #56
    omed13
    omed13 New Member
  27. Jan 30, 2022 at 11:53 AM
    #57
    Balrz
    Balrz New Member
    Ryu
    New 2020 Tundra crewmax off-road premium
    Are you running Blistein 5100’s front and back?
  28. Feb 15, 2022 at 5:58 AM
    #58
    RJ82
    RJ82 New Member
    Truck looks Great man , you said you have 3/1 ?? wondering what kit you installed as im doing a ton of searching but finding it hard to decide .. any help greatly appreciated .
  29. Feb 15, 2022 at 6:06 AM
    #59
    thedonn
    thedonn New Member
    I think 295 70 18 are the best overall size to go up a little but not have drawbacks. mine are 34.3 tall. just move plastic amd install bumper shims and no rubbing. mine has a front 1.9 lift
  30. Feb 15, 2022 at 6:07 AM
    #60
    RJ82
    RJ82 New Member
    just 2 in the front ? spacer ? just to level the truck ? upper control arms aren't necessary ???
