Adding backup sensors
Discussion in '2.5 Gen Tundras (2014-2021)' started by stevep1794, Dec 11, 2018.
  1. Dec 11, 2018 at 11:01 AM
    stevep1794
    stevep1794 [OP] New Member
    2019 Tundra Limited 2WD - Cement
    I have a 19 Limited and want to add back up sensors to it... other than the obvious in getting the end caps and harness run; What else will I need. Do I have to get the ECM updated to tell the system it now has backup sensors? I'm good with my part numbers.. just wonder if it will need additional dealership programming.
    Challenger1 likes this.
  2. Dec 11, 2018 at 11:20 AM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    NewImprovedRon likes this.
  3. Dec 11, 2018 at 11:28 AM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    im sure it wont be cheap to add, but I have all the parking sensors andwhat not that youd need. just not sure what all it would require to make work on a truck that doesn't come equipped with it.
  4. Dec 11, 2018 at 11:59 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Unfortunately, it requires a ton of parts to work. Main Body ECUs, harnesses etc. Probably not worth it from a financial perspective.
    Erichudgins[QUOTED] likes this.
  5. Dec 11, 2018 at 12:14 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    yea that's what I figured.im sure the main harness of the vehicle is probably different as well. I see that being a lot of money and risk with little reward.. Sorry for the negative feedback OP
    stevep1794[OP] and Challenger1 like this.
  6. Dec 11, 2018 at 12:55 PM
    jptshadow
    jptshadow New Member
  7. Dec 11, 2018 at 1:06 PM
    Erichudgins
    Eric
    Murfreesboro, TN
  8. Dec 12, 2018 at 5:43 AM
    cmcstotts
    cmcstotts New Member
    2019 white tundra TRD Crewmax
    I have a 2019 crewmax limited and the rear bumper has the sensors already installed. When in reverse I do not get an audible alarm. I do not have park assist option on my truck. What can I do to make the rear sensors beep when in reverse? Is there a switch or setting to turn an audible alarm on? If not what are the sensors for?
  9. Dec 12, 2018 at 7:10 AM
    GbRunner10
    GbRunner10 New Member
    My button is on the lower right set of switches above the brake controller. Has a "P" on it. 2018 Crew Max TRD Offroad. Attached is a picture of a limited for example.
  10. Dec 12, 2018 at 8:46 AM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Does the Front bumper have sensors? If not then you probably only have RCTA and BSM.
    Erichudgins likes this.
  11. Dec 12, 2018 at 11:34 AM
    cmcstotts
    I will check to see if I have sensors on the front. I don't have blind spot monitor. I guess I assumed new cars had backup audible alerts. It has sensors for something on the rear bumper. My 2010 ford had what appears to be the same sensors and would alert to objects behind you.
    ConstructionAg_06 likes this.
  12. Dec 12, 2018 at 2:00 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    The rear sensor should only beep if your getting close to an object while in reverse. The closer you get the faster it should beep until you rear end something
    15whtrd likes this.
  13. Apr 14, 2019 at 10:04 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Sorry to bring up an old thread but does anyone here know if there is an "extension cord" available for the parking sensor wires that plug into the parking sensor on/off switch next to the steering wheel? I am trying to relocate the parking sensor on/off switch down below the air control in the glass break sensor spot. I am sure I could cut the wires and splice in some additional length but would much rather have a plug and play cable if available. I currently have a button for my front camera where the parking sensor switch was and am trying to button my project up. Another crazy thing toyota did was make the slots for each switch (parking sensor, tow haul, traction, glass break) all different. Each switch has a designated location in the truck (can be resolved with minor modification). Anyway, any help would be appreciated.
  14. Nov 7, 2020 at 6:28 AM
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
    Anyone found a good quality aftermarket backup sensor kit? Most of them seem pretty cheap.
    I would also consider some thing that mounts to the license plate frame, and that might actually be preferable. Though I don’t know how well that would work sensing at the corners.
