Adding bed lights
Discussion in '3rd Gen Tundras (2022+)' started by narako9, Dec 17, 2022.
  1. Dec 17, 2022 at 9:21 AM
    narako9
    narako9 [OP] New Member
    Is the wiring for the bed lights there for the models that didn't come with the lights? If not, what's the best way to tap into existing wiring to have aftermarket lights come on when the tailgate is down or the cargo light button is pushed from inside?
  2. Dec 17, 2022 at 10:23 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    You can tap into the cargo light wire circuit underneath the driver-side rear passenger scuff plate. The scuff plate just pulls up from some clips that capture it. Underneath the scuff plate is a wire bundle and one of the wires there goes to the cargo light. On my 20165, the wire is a gray, smaller gauge wire in the bundle. I don't know what the color may be in your truck because it can vary by year model. Tapping this circuit will light up any bed lights any time the cargo light comes on either by unlocking/locking the truck with the fob or by turning on the cargo light switch from the dash switch.
  3. Dec 17, 2022 at 10:31 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Definitely check your wiring with a DMM. These are 2 different trucks. May have different locations too.
  4. Dec 17, 2022 at 11:25 AM
    NewImprovedRon
    Ron
    NW Arkansas
    You can test wires in the bundle by using half of a PosiTap to puncture the wire you are testing, and using a test light to see if the circuit has power with the door open. Clip the negative to a good ground and touch the positive probe to the PosiTap. The PosiTap doesn't tear the wiring up; just punctures it.
  5. Dec 17, 2022 at 1:18 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    2022 cargo light schematic.
    Page 1 the bed lights
    Page 2 where the bed lights tap into the circut
    I would look under the bed and see if there is wiring and loose connectors to the area the bed lights would go.
    In my 2014 I had to run my own. and tap into the circut.
    Good luck..
    upload_2022-12-17_15-14-24.jpgupload_2022-12-17_15-14-58.jpgupload_2022-12-17_15-15-20.jpgupload_2022-12-17_15-15-42.jpg
  6. Dec 17, 2022 at 9:48 PM
    narako9
    Thanks everyone! I'll start under the bed for any wires and go from there.
  7. Dec 17, 2022 at 10:20 PM
    AWDDude
    AWDDude New Member
    2023 Tundra Limited - Crew Max TRD Off Road 4x4
    Im curious to see if the wiring is there already.
  8. Dec 18, 2022 at 8:20 AM
    TSS Army Green
    TSS Army Green New Member
    Keep us updated OP
  9. Feb 16, 2023 at 6:10 AM
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    That is the one thing I miss on this truck vs when I had my tacoma. Having a bed cover I need bed lights bad. It was so easy to add them to the Taco. We need a write up.
    Nojjy likes this.
