Adding Cruise Control to a 2006 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by dbittle, Jan 22, 2021.
  1. Jan 22, 2021 at 4:12 PM
    dbittle
    dbittle [OP] Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    Greetings fellow Tundra Brothers
    I recently bought a 2006 work truck with the 4.7 engine and no cruise control or intermittent wipers. After some internet research, I visited the local pick-a-part today and harvested a cruise control switch from a 2008 Camry, along with the wire that runs to the spiral connector. When I got home, I discovered the wire is different on a Tundra. It appears I need 84633-34010, which is no longer available and supersedes to 84633-60010, which the Cool Springs Toyota site says won't fit. Anyone have a workaround for this in their hip pocket?
  2. Jan 22, 2021 at 4:22 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I installed cruiser by adding the pins to the factory connector the horn was on originally.. as for intermittent wipers, those are plug and play with the stalk.
  3. Jan 22, 2021 at 4:33 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    That is going to be my plan as well. I have a factory service manual and wiring diagram downloaded, so hopefully I can figure out which positions to put the wires into.
    I had an issue with the intermittent wipers also. The switch from the donor car is held in by a clip. On my truck, the switch is held in by two phillips head screws. Different part, darn it.
  4. Jan 22, 2021 at 5:03 PM
    empty_lord
    05 rollover special
    You have the newer style switch. You have to find a switch out of a tundra or 1st gen taco, 3rd gen 4runner. Etc
    dbittle[QUOTED][OP] likes this.
  5. Jan 22, 2021 at 5:14 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    Aah, that makes sense. Digging around on the Toyota Overstock site, I think I need 846520C021. It looks like it crosses over to the 2005-2008 Solara. They have a 2006 that I will take a look at tomorrow.
  6. Jan 22, 2021 at 5:46 PM
    empty_lord
    05 rollover special
    If it has a matching fog light switch, grab it too. Your truck is likely prewired for fog lights like mine. Just need a fog light relay, the assemblies, and the switch. (Or you could wire the 9006 connectors to some aftermarket fogs)
    dbittle[OP] likes this.
  7. Jan 24, 2021 at 6:14 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    I was able to find the right intermittent wiper control, so that's fixed. Does anyone know which positions the cruise control wires go into on this connector in the steering column? I am having trouble deciphering the wiring diagram and figuring it out for myself. I believe 2002-2006 year model Tundras all have the correct cable and connector, part 84633-34010. If anyone has a picture from when they added cruise to their truck, it would help me so much!
  8. Jan 24, 2021 at 6:15 PM
    empty_lord
    05 rollover special
    I’ll see if I can find my old cable... my steering control cable had it already wired
  9. Jan 24, 2021 at 6:25 PM
    empty_lord
    05 rollover special
    Is it 3 wires? Red black and black white?
  10. Jan 24, 2021 at 6:25 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    I sourced my cruise control stalk from a Camry and the connector is different. Man, if you can find that old cable and post up a picture of which pins to use, it would help me so much. A gentleman on another forum put up a complete PDF of instructions and even has a photo showing the connector. He did it when the correct cable was still available though, so he didn't focus on which pins are used. For posterity, here is his PDF instruction sheet.
  11. Jan 24, 2021 at 6:27 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Blue is horn contact.
    White Csw+
    Black Csw-
    This is my OEM '05 wiring.
  12. Jan 24, 2021 at 6:28 PM
    empty_lord
    05 rollover special
    [​IMG] This is it. Red should be 12v. My switch came from a Prius
    the first red is horn
  13. Jan 24, 2021 at 6:35 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    Thank you empty_lord and assassin10000! Mine has the black and red wires as well. This will fix me up! Thanks again!!!
  14. Jan 24, 2021 at 8:25 PM
    empty_lord
    05 rollover special
    so how long before you go nuts like me and do power door locks and what not... and steering wheel controls? LOL
    dbittle[QUOTED][OP] and CodyP like this.
  15. Jan 25, 2021 at 6:51 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I remember trying to work through all this with my old regular cab taco. Keep up the good fight.
  16. Jan 25, 2021 at 8:48 AM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    I'm pretty much there! I have read through that and have plans to head down the same path. I like the manual windows and I like the rubber floor mat. The power locks would be a nice upgrade. I'm also thinking of ditching the bench seat and putting in bucket seats with a center console. Just need a supply of donor vehicles!
  17. Jan 25, 2021 at 8:59 AM
    empty_lord
    05 rollover special
    Buckets are soo much better for sure. Check your interior fuse block. If the front plug is green on the fuse block, you have the fuse block to be plug and play.
    best find a donor with it all at once. The heated mirrors are also amazing to have in the winter
  18. Jan 25, 2021 at 3:45 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    Success! The job is complete and the cruise control, including the light, operate correctly!IMG_0905.jpg
    RainMan_PNW and empty_lord like this.
  19. Jan 25, 2021 at 4:47 PM
    empty_lord
    05 rollover special
    Fun fact.
    This is how I started my mess. Intermittent wipers and cruise... it spiraled from there
  20. Jan 25, 2021 at 8:23 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    I believe I'm about to start the same mess :rolleyes: I'd like to add cruise control and maybe the wipers as well
  21. Jan 25, 2021 at 8:27 PM
    empty_lord
    05 rollover special
    07 is a wee bit different. But still all plug and play.
  22. Jan 25, 2021 at 8:29 PM
    joseph_womack
    Joe
    Louisiana
  23. May 25, 2022 at 1:31 AM
    Jchaim99
    Jchaim99 New Member
    I just bought an 06 Tundra Base model with 48k and no CC... with the help of this forum, I installed it myself! The Stalk is all I needed (did not need the harness). All I had to do was remove the red and black wires from the stalk and put it in the clip already on the steering wheel and CC works flawlessly! The truck was perfect, with the exception of lack of CC, but now it is totally perfect! Thank you to all of the Tundra enthusiasts. My knee thanks you!!
