Adjustable sway bar link install
Discussion in 'Suspension' started by Nbab23, Jun 10, 2024.
  1. Jun 10, 2024 at 10:22 AM
    Nbab23
    Nbab23 [OP] 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    So I had a clunk occasionally when turning right that I attributed to a bad sway bar link. I think the angle after my lift was a bit much even with spacers. I decided to go with Heim joint style adjustable sway bar links. I used the directions to install but it really just said “adjust height as needed” so it really wasn’t helpful in that regard. After install I now have a clunk when I turn left that I can feel right under my feet. It only happens occasionally though usually when there is a dip in the road. I notice that the sway bar is closer to the heim joint on the drivers side compared to the passenger so I wonder if that is jamming up a bit on those left turns. Anyone have any experience installing these? I did it all on the ground and had to lift the drivers side a bit to get it to line up with the link since my driveway has normal slope to it. Just trying to figure out if this looks normal or if I installed it incorrectly. Pic 1 is passenger side. 2 is drivers side where I feel the clunk.
  2. Jun 15, 2024 at 7:42 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    So I decided to redo the drivers side and it now looks like the passenger side. But now I get a metal on metal clunk when I turn left or right when there is a decent dip in the road. Haha. I just can’t win on this one. I’m debating putting the sway bar spacer back in and changing the length to match stock….
  3. Jun 15, 2024 at 7:44 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Probably hitting the coilovers
  4. Jun 15, 2024 at 7:48 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Sway bar? We don’t need no stinking sway bar.
    helidave, Nbab23[OP] and texasrho83 like this.
  5. Jun 15, 2024 at 7:58 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Yeah I was thinking it may be when I’m hitting those dips and turning.
  6. Jun 15, 2024 at 7:59 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Ha I was waiting for this comment. I know there’s a lot that run without. I may give it a try just to see what it feels like but I’m pretty aggressive when I drive it (not in an asshole kind of way) I just like to enjoy using the v8 to it’s potential.
  7. Jun 15, 2024 at 8:00 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    You think that would mean the links are adjusted out too much? The fact that they might be hitting the coilovers? If that’s the case I don’t really see any solution other than putting the spacers back and and putting the links back to stock length.
  8. Jun 15, 2024 at 8:13 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd say yeah if you've got them adjusted "tall" you're gonna have a higher chance of hitting the coils
    2mchfun and Nbab23[QUOTED][OP] like this.
  9. Jun 15, 2024 at 8:33 AM
    2mchfun
    Adjust them to where the sway bar is level. Are your bump stops hitting the lower control arms? You should notice impact marks. If not, your shocks are likely bottoming out, and that is bad news. At that point, bump stop extensions or possibly Durobumps, Timbren bump stops, or similar.
  10. Jun 15, 2024 at 9:17 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    I do have a set of wheelers durobumps on there. So I’m thinking it has to be hitting the shocks given the sound I am hearing. I’ll check out the level of the sway bar and adjust as needed. Fingers crossed and thanks for the help everyone.
    2mchfun[QUOTED] likes this.
  11. Jun 15, 2024 at 9:38 AM
    2mchfun
    Kinda looks like the durobump bolt head is exposed. Maybe just the picture though. If exposed, you have metal to metal noise right there.
    Nbab23[QUOTED][OP] likes this.
  12. Jun 15, 2024 at 10:00 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    It does in the photo. I’ll double check that as well.
  13. Jun 23, 2024 at 3:43 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    So just an update as I finally got around to checking everything out. Bump stops were fine, must’ve just been the reflection or angle that the photo was taken. I tried tweaking things a bit but nothing was giving a good fit so I decided to put the spacers back in and set the links to stock length. I then received an email from the company a few minutes ago that basically said the same thing and that the adjustments are just for small tweaks. First test drive felt much better and no metal on metal sound.
    2mchfun likes this.
