Adjusting auto level headlights
Discussion in '3rd Gen Tundras (2022+)' started by skbirkholz, Nov 2, 2022.
  1. Nov 2, 2022 at 1:40 AM
    skbirkholz
    skbirkholz [OP] New Member
    Scott
    So I was hoping someone might know how to adjust the auto level headlights. I leveled my Platinum and it has the auto level headlights and I am now constantly getting flashed by oncoming traffic. I sure hope the height can somehow be adjusted since I dont want to drive around blinding everyone. I am attaching a pic of the back of the headlight and was hoping maybe that white plastic thingie is a adjustment screw of some kind. I can not find anywhere on here or on the internet about the ability to adjust the height of these.
    Hopefully someone can help
    Thanks Scott
  2. Nov 2, 2022 at 1:56 AM
    dreamcatcherxo
    dreamcatcherxo New Member
    Sorry i'm a bit confused... do you have the adjusting dial to the left of your steering wheel to raise/lower your headlight beam angle?
    if so, what i've done in the past with my tacoma when i lifted it was if you look at the front lens of your headlight, you'll see a little dot/dimple in the center.
    Measure how high that is off of the ground, and remember that value. then park on a completely flat surface, with your vehicle aimed at a wall, and have that "dimple" be exactly 25 feet away from the wall. mark the wall with some blue painter's tape at the height that you measured earlier from dimple to the ground. adjust the headlight so it is around 4-5 inches below the blue tape.
    for example, if it is 46'' from the ground to the dimple, you want to adjust the top cutoff of your headlight on the flat wall to be around the 41-42'' mark.
    iJord714 and DSLKSL like this.
  3. Nov 2, 2022 at 2:02 AM
    skbirkholz
    Scott
    No the auto adjust headlights do not have the adjusting dial. They supposedly adjust to the correct height themselves.:/
  4. Nov 2, 2022 at 5:24 AM
    TRDnoob
    TRDnoob New Member
    2013 Platinum 4x4
    That white nut should adjust it. Looks like what I had to adjust on my old tundra when I leveled it. you can put socket on the nut or use Philips head screwdriver in the gear part to adjust it.
  5. Nov 2, 2022 at 5:59 AM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    OK! We have conflicting posts two in a row! Does the auto adjusting headlight in fact auto adjust, or do you have to turn the white nut?
    I've read in other places that the auto adjustment range is minor, and perhaps only designed to offset higher pointed headlights when the rear is squatted down with a payload in the bed.
    ALSO, I've read that the "auto adjustment" is really just the self leveling rear suspension, which prevents rear squat from payload / lights pointed too high.
    I've owned a lot of vehicles with self adjusting headlights and they all would calibrate at startup. You could see the headlights move to full range of adjustment as soon as you started the vehicle. I have not seen that on this truck at all.
    I suspect (and this is completely speculative):
    1) The auto adjustment refers only to the rear air suspension self leveling feature
    2) The white nut is still used to aim the headlights on a baseline flat surface with suspension in Normal height.
    I would love for a tech or an engineer to explain accurately!
  6. Nov 2, 2022 at 6:08 AM
    TRDnoob
    TRDnoob New Member
    2013 Platinum 4x4
    I think you are correct on that they only have a small range of adjustment. I dont think they have anything to do with the rear suspension leveling because you can get the auto headlights on the limited trim without the rear suspension that self levels.
  7. Nov 2, 2022 at 7:33 AM
    Boats N TRDs
    Boats N TRDs New Member
    Travis
    2022 Tundra Limited HV TRD OR
    Chrome delete
    I think you're close, but I don't think it's adjusting based on the air suspension, but the rear shock travel instead. My limited has auto-leveling headlights and I do not have the air suspension.
  8. Nov 2, 2022 at 10:58 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    So the TRD lift kit comes with a new ARM for the load leveling headlights? Damn, need one of those
  9. Nov 2, 2022 at 3:21 PM
    MJPlat
    MJPlat New Member
    Nothing to do with those dials, just need a long phillps screwdriver…
    2D25BDEC-A589-46F9-B996-F9021B777BC2.jpg 1EB20071-3B3C-4255-95D8-EE69E2F8A27A.jpg
  10. Nov 2, 2022 at 8:22 PM
    1794ELPTX
    1794ELPTX 2022 1794 Edition Tundra
    El Paso, TX
    2022 1794 Tundra
    I had the TRD Lift Suspension Kit installed and the load leveling arm was removed and that function is now disabled. That is in Step 38 of T-A1-1379-D.pdf (Installation Instruction). I don't know why Toyota removed the linkage arm and disabled function. it is an expensive lift kit and don't know why Toyota did not engineer the proper linkage arm length for the load leveling headlights to be within specs.
  11. Nov 2, 2022 at 11:33 PM
    skbirkholz
    Scott
    Yes Thank you everyone but yes this is what did the trick. Very simple turned the screwdriver lowered them to correct level. took 4 min. No more getting flashed. :)
  12. Mar 9, 2023 at 8:09 PM
    Bayoutundra
    Bayoutundra New Member
    2023 Lunar Rock Limited TRD Off Road
    2.25" icon spacer with Cornfed 1" rear spacer, 35x11.50 Wildpeak AT3 on stock TRD wheels. TRD Pro grill swap, protech cluster radio and bezel screen protectors.
    What is the correct level when adjusting them?
  13. Mar 10, 2023 at 8:22 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Read post 2
  14. Nov 1, 2023 at 4:30 PM
    HiUp
    HiUp New Member
    2022 Tundra
    2/1 Westcott level, upper control arms, 17”wheels, Milestar A/T 37x12.5
    Thanks for this info
    I was able to make this adjustment on my tundra with an 8mm wrench
  15. Nov 2, 2023 at 4:06 PM
    TundBP
    TundBP New Member
    23 Blueprint Platinum
    I never would have thought auto level headlights would need a manual adjuster. Thanks for the pro tip on the adjustment screw locations.
  16. Nov 2, 2023 at 6:05 PM
    23 Platinum
    23 Platinum 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    I keep blowing up that pic and I can't see the screw. I need to adjust mine down
  17. Nov 2, 2023 at 6:15 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Look at the first post, the white area is the place that has a serrated edge. Look from the top of the headlight downward and you will see a place you can put a number two Phillips (long) down ward and it will fit into the serrated piece. Turning the screwdriver will adjust up or down.
    tc1183 likes this.
  18. Nov 2, 2023 at 6:25 PM
    23 Platinum
    California
    Thank you, that seems pretty clear
  19. Nov 2, 2023 at 6:26 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    This makes me happy with my dial on the dash SR5
    TundBP[QUOTED] and 23 Platinum like this.
  20. Nov 2, 2023 at 7:30 PM
    TundBP
    TundBP New Member
    Do your manual adjustable headlights via interior dial have a manual adjustment screw on the housing??!!
  21. Nov 2, 2023 at 8:03 PM
    22whatwedo
    The Open Road
  22. Nov 3, 2023 at 1:42 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    Auto level headlights have range of travel just like any other actuator based system. The philips screw simply adjust the baseline. I’m positive base led headlights also have some sort of baseline beam cut off adjustment with the addition of the dial.
    TundBP[QUOTED] likes this.
  23. Nov 3, 2023 at 12:13 PM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    No new arm, the tech has to adjust the headlights manually IAW the instructions that come with the TRD Lift, they actually remove the arm for the auto level. See page 44.
  24. Nov 4, 2023 at 8:46 PM
    23 Platinum
    California
  25. Nov 15, 2023 at 3:55 PM
    Okotoks Tundra
    Okotoks Tundra New Member
    Hello wondering how much you had to turn it to adjust. I have been trying to raise mine a bit as even having the manual adjust at zero in the cab is too low.
    However feeling some resistance and not seeing much change in level on the wall. Don’t want to push past the point of failure.
  26. Nov 15, 2023 at 5:53 PM
    23 Platinum
    California
    I had to turn it quite a few turns because it was way high after the lift
  27. Nov 15, 2023 at 5:54 PM
    23 Platinum
    California
    I felt zero resistance when turning it
  28. Nov 28, 2023 at 6:17 PM
    jiggity84
    jiggity84 New Member
    Jacob
    2024-Lunar Rock-Limited TRD Off-road
    Factory installed OEM 3” lift kit
    So no “auto leveling headlights” with the TRD lift kit then?
  29. Nov 29, 2023 at 7:51 AM
    Bailey1794
    Bailey1794 New Member
    Houston
    2023 Smoked Mesquite Hybrid 1794 Tundra
    Diode Dynamics Ambassador & Talons Garage Affiliate (See Below for discounts) Use code Bailey for Diode Dynamic free shipping Current Build & Pics Instagram.com/Bailey1794 Discounts & Affiliate links below https://linktr.ee/bailey_1794?fbclid=PAZXh0bgNhZW0CMTEAAaYH-pwfNz76E_oAQekLat2ZdcSY0VrV7a8O3_UxaU15mlBifUGV3lGaU4s_aem_Aamyw5XakyTlp6h_WyGSA8wBSO-cFzK1Z0t3EQBBaXEgDCnQI49fSwGFqQNWOCNd5OxDNGhVrMYRcfs_DEuuCXSy
    Man this sucks i didnt know the TRD kit removes the Auto Height Bracket? Is there a possibility that we can leave it on?
  30. Dec 23, 2023 at 7:35 AM
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    I know the TRD lift instructions tell toyota to disable the auto leveling headlight feature due to it being incompatible but they also say to remove the fog lights. It looks like the linkage will still reach after removing the lockout/disable bracket.
    Has anyone reinstalled the linkage to the auto level headlight sensor after getting the TRD lift or know if it will still function even if not as accurate?
    machd08 likes this.
