After Bilstein level measurements
Discussion in 'Suspension' started by Xplorin, Feb 5, 2019.
  1. Feb 5, 2019 at 3:49 PM
    Xplorin
    Xplorin [OP] New Member
    Yorktown, Virginia
    2019 cement crewmax
    Just wanted to give y’all some details on my Bilstein 5100 install
    2019 crewmax Trd off-road
    Bilstein 5100s (top setting)
    2 coachbuilder shims on driver side
    1 coachbuilder shim on passenger side
    BEFORE fender measurements
    DF 36 5/8
    PF 37
    DR 40
    PR 40
    AFTER fender measurements
    (100 miles driving to let them settle a bit)
    DF 39 7/8
    PF 39 7/8
    DR 40
    PR 40
    So gained just and 1/8 under 3 inches in the front and both sides are even!
    That’s about as perfect to level as you’re gonna get, somehow the nose still looks high so I may put a 1 inch shackle on soon
  2. Feb 5, 2019 at 3:50 PM
    TheBeast The Beach
    need pictures :)
    Xplorin[OP] likes this.
  3. Feb 5, 2019 at 3:52 PM
    Xplorin
    Yorktown, Virginia
    2019 cement crewmax
    Before
    AFTER
    D9892900-3D89-4E12-AEF4-884F4FD573EC.jpg 8537980D-F942-4F20-BE21-3D50ED57C5AE.jpg
    CementGen3, BlackSheep, equin and 4 others like this.
  4. Feb 5, 2019 at 3:58 PM
    mattyd170
    mattyd170 New Member
    Rio Rancho, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    Stock for now, but have TRD Rear Sway bar for it.
    Awesome. Looks perfect. No shackle, leave it. Front will settle 1/8" after you drive it some more. Very similar to mine, although I did 2 CB spacers on both front shocks. Looks great.
  5. Feb 5, 2019 at 4:06 PM
    Xplorin
    Yorktown, Virginia
    2019 cement crewmax
    Thanks! Now I need some bigger tires
  6. Feb 5, 2019 at 4:33 PM
    mattyd170
    Rio Rancho, NM
    I am in the same predicament right now. Trying to decide between 275/60r20's or 275/65r20's. 33's or 34's. Leaning towards the 33's for everyday use. Thinking Falken AT3's.
  7. Feb 15, 2019 at 8:00 PM
    JDavid
    JDavid New Member
    2019 Tundra TRD off-road
    None as of yet
    How is the ride quality with this setup?
  8. Feb 16, 2019 at 5:32 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Truck looks great! I wonder why yours is one inch taller than mine stock.
    I'm running 5100 leveling shocks on the middle setting.
    DF is 38", PF is 38.25"
    DR is 39", PR is 39".
    I'm installing the @BOSS4x4s shims and shackles today. Two shims DF and one shim PF and moving the clip to the top setting on the 5100s leveling shock. Shackles set at top setting with 5100s installed in the rear.
    I'll post up my measurements when I'm done.
  9. Feb 16, 2019 at 5:57 AM
    15whtrd
    15whtrd Mr. Blonde
    I am surprised you don’t have bro lean. I am level with just 2 inches in the front. For some reason I thought Bilstein on the top setting with a shim would put you over 3 inches and make it nose high.
  10. Feb 16, 2019 at 6:47 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    This is what I was looking for, now will order mine. Truck looks great!
  11. Feb 16, 2019 at 6:48 AM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Looks good, however personally I think it looks a tad nose high, especially in the photo in the parking spaces. May settle a little in front though, but any weight at all in the back and may look like you have a saggy diaper. Just my opinion- make the truck yours!
  12. Feb 16, 2019 at 6:53 AM
    Fishin RGV-Trd Pro
    Fishin RGV-Trd Pro White is faster
    Alex
    RGV Texas
    2011 White Toyota Tundra Limited
    Looks awesome.
  13. Feb 16, 2019 at 1:28 PM
    Xplorin
    Yorktown, Virginia
    2019 cement crewmax
    Better than stock,
    Stiffer but a good way
  14. Feb 16, 2019 at 1:29 PM
    Xplorin
    Yorktown, Virginia
    2019 cement crewmax
    You won’t regret it!
    yeah I thinking I’m gonna do a 1 inch shackle in the rear
  15. Feb 21, 2019 at 10:51 AM
    JP77
    JP77 New Member
    2019 Tundra SR5 TRD 4x4
    Looks great man! I just got my 19 SR5 Crewmax TRD and am totally confused on how to get the nose up and level. I am leaning toward the 5100's but don't know where to start. I am guessing I need to gain 2" on the front to get leveled? What setting on the shocks do I want to go with? Any help would be much appreciated, Thanks
  16. Feb 21, 2019 at 10:57 AM
    Welcome from NY.
    5100's on the middle setting will level the truck.
    15whtrd likes this.
  17. Feb 21, 2019 at 11:00 AM
    JP77
    JP77 New Member
    Thanks, just trying to figure out where to start
  18. Feb 21, 2019 at 11:01 AM
    :thumbsup:
  19. Feb 21, 2019 at 11:07 AM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
    Here's mine with 5100's on middle setting with 2 shims on top (raised from stock about 2.5").
  20. Feb 21, 2019 at 11:08 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    5100 front shocks height adjustable with 3 different lift settings: .87″, 1.57″, and 2.28″
    Each Coachbuilder shim, if desired, adds another .5”
    In general going towards and above 3” lift requires UCA change.
    Alignment is required post install.
  21. Feb 21, 2019 at 11:17 AM
    JP77
    JP77 New Member
    Thanks for the info guys! Sounds like the middle setting will do what I need. I will get some before and after pics up after I get er done!
    15whtrd likes this.
  22. Feb 21, 2019 at 11:19 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    You may also opt for a differential drop kit if higher than 2nd setting, and carrier bearing if using shackles in the back. In addition, bumpstop extensions or replace with Superbumps.
    If you have the funds, go with the beefier 6112’s.
