After market stereo install help (Hizpo)
Discussion in 'Audio & Video' started by RoninWolf, Oct 17, 2021.
  1. Oct 17, 2021 at 9:08 PM
    RoninWolf
    RoninWolf [OP] New Member
    2011 White Tundra double cab
    New to the group. Doing a few upgrades to my 2011 Tundra. Installed a Hizpo aftermarket android stereo, primarily to upgrade and install a tailgate handle backup cam. Looks like most of the wiring is plug and play (with some fear and trepidation as it has been decades since I've worked on a stereo system). Anyway, looks like rear cam and everything else works, however I can't hear any sounds from the speakers. With the volume on max, I can hear faint sounds, but just barely. I'm thinking it's an amplifier (connection) issue. Any tips or suggestions is greatly appreciated.
  2. Oct 17, 2021 at 10:23 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    What system came with your truck? Non-JBL? JBL? Nav?
    Can you post a link to what you bought?
  3. Oct 18, 2021 at 12:01 AM
    RoninWolf
    I bought the truck used. Aside from checking the vehicle manual, is there a way I can verify? To my knowledge it looks like a standard cd player and radio (no nav). I don't see any indications or JBL logos anywhere.
  4. Oct 18, 2021 at 12:22 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    If it was used you could have an amp that the previous owner pulled out from under the passenger seat or something?
    Did it have the factory radio when you bought it and did it work fine before you started replacing to this aftermarket one?
  5. Oct 18, 2021 at 3:01 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome from Gettysburg
  6. Oct 18, 2021 at 7:31 AM
    RoninWolf
    I will check under the passenger seat. Yes it had the factory radio which was working fine. Thanks
  7. Oct 18, 2021 at 7:36 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
  8. Oct 18, 2021 at 2:12 PM
    RoninWolf
    Thanks for the heads up
  9. Oct 20, 2021 at 10:26 AM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    2007 Slate Metallic Double Cab
    There was a blue wire I had to cut when I did mine. I've since thrown it away and gone back to stock otherwise I'd pull it apart and take pictures.
    RoninWolf[OP] likes this.
  10. Oct 20, 2021 at 11:28 AM
    RoninWolf
    I see the blue wire in the new ddvk which is labeled amp. Figuring I need to find the stock amp wire and tap it.
    BenAZ likes this.
  11. Oct 20, 2021 at 11:29 AM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    I'm guessing you have a JBL system?
  12. Oct 20, 2021 at 2:22 PM
    RoninWolf
    Not too sure. I'll need to chdck/verify either through the user manual or visual inspection.
  13. Oct 20, 2021 at 2:24 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    It would say JBL somewhere on the face of the stereo if you do. If you do, cut the amp wire and insulate both ends. It should work after that.
  14. Oct 20, 2021 at 2:30 PM
    RoninWolf
    Haven't noticed and JBL logos anywhere. But yeah, was thinking of splicing both (blue) amp wires hoping it works. Now, just a matter of locating the stock amp wiring
  15. Oct 20, 2021 at 2:32 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    Are the blue amp wires not currently connected? If not, connect them to each other. JBL needs the wire cut and non-JBL needs them connected IIRC.
  16. Oct 23, 2021 at 3:17 PM
    RoninWolf
    This is the wiring thus far
  17. Oct 23, 2021 at 3:18 PM
    RoninWolf
    Tried searching for the primary (blue) amp wire but unsuccessful. I also tried searching for the speaker wires and connecting directly to the new player, but no luck.
  18. Oct 25, 2021 at 8:01 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Does your hizpo radio’s harness have the “Orange/black” wire? That would be the amp turn on wire on some unit. The blue is for power antenna. I would check that.
  19. Oct 25, 2021 at 10:10 AM
    RoninWolf
    The Hizpo unit has a blue line labeled AMP. It also only has one solid orange wire that I can see. Still need to locate the actual amp (if any)
  20. Oct 25, 2021 at 10:12 AM
    RoninWolf
    Hizpo amp wire
  21. Oct 25, 2021 at 5:27 PM
    BrandonL812
    Brandon
    Gotcha. then i have no clue. Sorry i cant help.
  22. Oct 25, 2021 at 6:26 PM
    RoninWolf
    No prob, thanks
