After undercoating, which parts shouldn't be sprayed for degradation concerns?
Discussion in '1st Gen Tundras (2000-2006)' started by atomicnugget, Sep 15, 2023.
  1. Sep 15, 2023 at 7:22 AM
    atomicnugget
    atomicnugget [OP] My bones hurt
    New Jersey
    2001 V8 Limited Access Cab 4x4 w. TRD package
    As the title implies I’m expecting some heckling but since this is by far the most important thing I can do to my truck outside of lbjs and others I wanna make sure I’m fully prepared.
    when undercoating am I good to basically spray everything I see, or are there certain areas that I should avoid to prevent degradation or lower the capabilities of said part? Like should I spray behind the wheel wells, etc.
    for those interested in using surface shield as my product as I heard it might be a little better and last longer then fluid film, also got that wand thing for getting inside the actual frame
  2. Sep 15, 2023 at 7:41 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    No idea on long-term protection since I bought a truck that spent a lot of time in Utah but that is now 100% in a dry part of Texas, so my goal was fixing past damage but with zero concern for the future. I removed surface rust (did it with a set of wire brush attachments in a drill) and then coated that. I used a phosphoric acid solution called Ospho which converts rust (wasn't much "rust" left to convert after the wire brush) and then rattle-canned the result with Rustoleum. I did not paint all the front suspension components super hard core because I plan to replace all that. For long-term protection (I see you're in New Jersey), I'll let one of our northern brethren chime in. I did watch a lot of videos at one point, and one guy (not the Farm Science or whatever dude) who did a long-term side-by-side test of several products, swears by the somewhat newer PBlaster coating since it doesn't evaporate (like WD40) or get all gunky (like woolwax), which he also applies with the spray tip wand things to get all up in them guts of the frame.
    Edit: I see now that PBlaster product is called Surface Shield which you mentioned, so yeah you seem to be watching the same videos as I did, haha.
    txagg likes this.
  3. Sep 15, 2023 at 7:45 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Wheel wells are plastic covered, so no. Inside the bottom of the door would be a good place once you insure you don't have anything rusting in there already that needs to be cleaned and prepped first.
  4. Sep 15, 2023 at 7:52 AM
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Has anyone used Woolwax Hard-On Permanent? The prospect of not having to recoat every year is inviting.
  5. Sep 15, 2023 at 7:55 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Most of the wax/oil base stuff that has to be reapplied annually, works fairly well.
    I would avoid anything that is like a paint, tar or rubber type coating. It will trap moisture.
  6. Sep 15, 2023 at 8:56 AM
    atomicnugget
    New Jersey
    To add onto that, I’m trying to prevent the metal parts in my engine bay from rusting like you see in engine bay pics of most trucks in the north east. You think I should put some surface shield on those components too to prevent that or should I look for a different product for that
  7. Sep 15, 2023 at 8:57 AM
  8. Sep 15, 2023 at 8:57 AM
    atomicnugget
    New Jersey
    no as in I don’t need to worry about spraying?
    or no as in don’t spray there lol
  9. Sep 15, 2023 at 9:29 AM
    Jack McCarthy
    Bill
    North of Boston
    Dont spray on there.
  10. Sep 15, 2023 at 9:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It holds up pretty well but does have to be reapplied. I actually don't like how well it works in places. After driving in Arizona all that dust stuck to the frame and other areas I sprayed.
  11. Sep 15, 2023 at 10:09 AM
    atomicnugget
    New Jersey
    Thats why im hesistant to use some of this on my engine bay parts, heard that these films collect dust which may help its effects for the frame, but would leave my engine bay absolutely cruddy. I might look into some other rust prevention products in the PB blaster line for this maybe.
  12. Sep 15, 2023 at 10:29 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I thought that was actually good for the "rust protection" aspect as it adds a layer of protection.
    I've read and seen posts on guys spraying, then driving down gravel/dirt roads to add it right after spraying.
    FirstGenVol[QUOTED] likes this.
  13. Sep 15, 2023 at 10:43 AM
    Jack McCarthy
    Bill
    North of Boston
    Buy a skid plate to put that fear to rest.
  14. Sep 15, 2023 at 11:01 AM
    atomicnugget
    New Jersey
    lol I’m more so trying to prevent it from the salty roads come winter rather than it getting filthy. I don’t want the eyesore of seeing rusty hooks, crooks, and bolts.
    still gonna use it for undercoating tho
  15. Sep 15, 2023 at 11:22 AM
    Jack McCarthy
    Bill
    North of Boston
    The skid plate will keep most of the salt/brine out of the engine bay and protect the front frame and crossmembers. You just have to remember to spray fluid film on the skid plate to protect it as well.
  16. Sep 15, 2023 at 11:24 AM
    atomicnugget
    New Jersey
    Another dumb question but figured it’s not worth a seperate thread, but is there a concern about the difference in these air filters?
    I ordered the new one from a local Toyota but the filter in the original seems fatter with less grooves. I can’t help but shake the feeling this dealership took the lazy way out and just gave me something that would “fit”. Another idea is that there’s been different iterations or versions over the years and this is the one they got in stock. I can’t think of a reason why the slightly different filter would be detrimental tho if anything more benefitual in filtering maybe with more grooves.E466A2C4-80A3-4D42-B3F4-E300CC9016C8.jpg
  17. Sep 15, 2023 at 11:36 AM
    atomicnugget
    New Jersey
    Nvm i answered my own question, I double checked with mcgeorges and it looks to be the same and part number so I should be good
    Jack McCarthy and shifty` like this.
  18. Sep 15, 2023 at 12:11 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah I'm not sure why you would spray Fluid Film in your engine bay. I've only used it on my battery terminals. For your frame it's good. PB Blaster Surface Shield is good too. Some say it's better.
  19. Sep 15, 2023 at 12:14 PM
    atomicnugget
    New Jersey
    Basically trying to avoid this from happening.
  20. Sep 15, 2023 at 12:25 PM
    Jack McCarthy
    Bill
    North of Boston
    That’s inevitable. You’ll always get a small amount of rust in the engine bay. The trick is to make sure most bolts are coated with anti-seize or penetrant oil to insure they wont cause issues further down the line.
    Of you’re anal about keeping it pristine, you could probably use wd40 to coat the parts subject to rust so long as it doesn't burn off and give some horrible toxic smell.
  21. Sep 15, 2023 at 12:28 PM
    Keep your skid plate on at all times to help cut down on it.
    Jack McCarthy likes this.
  22. Sep 15, 2023 at 12:35 PM
    atomicnugget
    New Jersey
    Guess the solution isnt as simple as I hoped it to be. Was hoping there was a alternatve wb40 ish product ppl recommended that didn't have those kinda issues. All good, ill just stick with undercoating the frame and like yall said, use the skid plate for what it was designed to do.
    BravoDeltaRomeo likes this.
  23. Sep 15, 2023 at 12:44 PM
    Jack McCarthy
    Bill
    North of Boston
    Its hard enough keeping rust off the frame that I think most people don’t deal with detailing the engine bay and keeping it immaculate. If you find something that works, let is know. Most people in that category around here generally don’t take their truck out in bad weather and have an alternate beater to drive.
  24. Sep 15, 2023 at 12:51 PM
    atomicnugget
    New Jersey
    You're 100% right, but don't get me wrong, I'm not trying to showcase the thing and fine if it does rust over time, just figured id ask if that was something I could do while i'm over here winterizing the truck anyways, thats all :D
  25. Sep 15, 2023 at 12:57 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Depending on which undercoating you decide to use, read the directions on each product as some don't recommend it to be sprayed on any rubber components.
  26. Sep 16, 2023 at 8:11 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Tons of good answers in here. I think the dirt/dust after using was a PHM thing. It's inevitable no matter how ya look at it.
    I vote akif plate like.others have said, make sure all of you're splash guards etc. Are where they are supposed to be and in the winter with all the shit they put on roads don't let it sit and collect. Wash often just to knock it down. I believe you can use a baking soda mixture spray to help break up the salt if ya want. I wouldn't go crazy just lower areas and stuff that's not a mechanic moving parts like brakes etc.
    I will say my faves up front skid/splash guard made a ton of difference in the winter as I did t have one when I bought due to lift I assume.
  27. Sep 16, 2023 at 11:00 AM
    atomicnugget
    New Jersey
    I also heard some guys suggest not washing all winter to preserve the undercoating while others seem to wash the salt off regularly so the salt doesn’t sit and in theory the film is water resistant. Not sure which train of thought to follow come the upcoming months
  28. Sep 16, 2023 at 6:30 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    GM dips their truck frames in a waxy tar coating and they don’t seem to have nearly the corrosion issues Toyota has. Just a thought
  29. Sep 16, 2023 at 8:45 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    You can grease rub your frame then spot spray with FF or blasters surface shield...It's a lil messy but it doesn't wear off, if it does it doesn't do it very easily.
  30. Sep 17, 2023 at 5:38 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I use WD40 on the frame and in the engine bay. Works really well -- and I'm in Maine (harsh winters with very salty roads).
