Aftermarket heated seats?
Discussion in 'General Tundra Discussion' started by Alexstundra, Nov 3, 2018.
  1. Nov 3, 2018 at 5:26 PM
    Alexstundra
    Alexstundra [OP] Not a new member
    Northeast PA
    2016 MGM DC Trd
    any good seat heaters for aftermarket leather ?
  2. Nov 3, 2018 at 6:47 PM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    I’d like to find an answer to that too!
  3. Nov 3, 2018 at 6:52 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    csuviper likes this.
  4. Nov 3, 2018 at 8:31 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Berdine[QUOTED] likes this.
  5. Nov 4, 2018 at 3:21 AM
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    This is the kit I bought,I have not installed it or my new seat covers yet but it’s a nice kit with oem style switches
    Berdine likes this.
  6. Nov 4, 2018 at 11:27 AM
    Berdine
    Binghamton, NY
    Hooked mine up today, took just about an hour. I already have seat covers. They work great! Under the dash was a fuse panel with fuse marked "heated seats" 20a fuse, used an add on fuse tap ran the power wires to there and ground to under driver kick panel.
    Trooper2 and JoshuaA like this.
  7. Nov 4, 2018 at 12:19 PM
    TheGibbster
    TheGibbster Kumite Express leaves in five minutes
    SF Bay
    You can get seat heaters with Katzkin leather seat covers. I haven't owned them myself, but I have had seat time in a few vehicles that did, and they are pretty good. You might be able to buy the heaters if you already got the leather.
  8. Nov 4, 2018 at 12:53 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Awesome that’s convenient. Also What spray did you use to cover chrome
  9. Nov 4, 2018 at 12:55 PM
    Berdine
    Binghamton, NY
    Its Rust-Oleum peel coat called Graphite, it matches the MGM pretty good, it's same as plasti dip
  10. Nov 4, 2018 at 1:05 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I’m using these, they have gaps for the rod/hog rings holding your seat down. You don’t need the new hog rings provided, zip ties work well and fit inside the groove, you don’t feel either anyway.
    I put the switches on either side of the center console near the front and tapped the fuse box for power. The tap that comes with these are usually just a cheap hook.
    2 panels each seat, so you need to buy two.
    Bulldog9, iHacker and Berdine like this.
  11. Nov 4, 2018 at 3:06 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Although they don’t have open sections for connecting the rods at the seams, note Berdine’s example has more coverage higher up the back and toward the knees, that might mean more to you.
    Berdine likes this.
  12. Nov 4, 2018 at 4:17 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    I've had great luck with the Rostra 250-1870 kits.
    iHacker likes this.
  13. Nov 4, 2018 at 4:28 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    NWA
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    gkelm, GAknight and JoshuaA like this.
  14. Sep 19, 2019 at 5:44 PM
    Indy Tundra
    Indy Tundra New Member
    2000 Tundra SR 5 Access cab
    Leveling kit powertrax locker, 330,000 miles and counting
    I have seen some postings regarding after market seat heaters being installed on cloth seats. Is that ok? how does the fabric hold up?
  15. Sep 20, 2019 at 5:03 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
  16. Sep 20, 2019 at 5:37 AM
    Indy Tundra
    Looks great! Thanks for your reply
  17. Jan 29, 2021 at 10:13 AM
    Gazinta
    Gazinta New Member
    2021 Tundra TSS Crewmax
    So wait, I thought these warmers go under the seat fabric? Did you adhere them to the surface and THEN add seat covers? I am about to install a set of Rostras this weekend and would like to know if this “on-top-of-seat-surface” method is okay? Do they stay in place and does the adhesive mess up the fabric at all? Thanks, looks like a far easier install if they work right and don’t destroy the original uphulstry. Any input appreciated!
  18. Jan 29, 2021 at 11:15 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Given enough time, it’ll probably mark the cloth seat whether by heat cycles and/or moisture going around the rectangular piece from above. It’s just less noticeable installed under the OEM seat but more work. To be honest I’d do the same thing if I was using covers, just put the heaters over top the existing ones.
  19. Jan 29, 2021 at 12:02 PM
    Berdine
    Binghamton, NY
    They're double sided tape on them to keep to seet bottom/back. I have no issues with mine under the seat covers
  20. Jan 29, 2021 at 12:45 PM
    ZeRussian
    ‘11 CrewMax
    I haven’t looked to see if the heaters did anything to factory seats under the seat covers, but I bet not. Even they did, they are covered up with covers. Made the install easy and they don’t slide around.
  21. Jan 29, 2021 at 4:25 PM
    Gazinta
    Gazinta New Member
    Ok thank you all for the feedback. Food for thought. Do you all do this because the original cloth plus seat covers is too thick to feel the heater? In other words, if I put the warmers under the uphulstry and THEN add seat covers, the heat never gets through both layers?
  22. Jan 30, 2021 at 7:19 PM
    ZeRussian
    ‘11 CrewMax
    I did it because of laziness. If you add it under the factory seat cover, you’ll still feel it, just would take longer to heat up at first.
  23. Jan 31, 2021 at 12:51 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have the kit from clazzio. I love it. If you have seat covers a good Tip is stick the seat heater to the seat covers, not the seat. That way no chance of the adhesive messing up the seat fabric.
  24. Jan 31, 2021 at 5:24 AM
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    I’ve installed many seat heaters. They are for sure designed to go under the seat covers and not sit on top. They are also normally installed under leather seats but work great with cloth covers too.
    On Tundra’s the switch that I use is round and it can be installed in the center console forward or back as the pics show or you can install them in the side panel of the seat itself.
  25. Jan 31, 2021 at 6:50 AM
    Gazinta
    Gazinta New Member
    Ty for responses e1. Much appreciated.
  26. Jan 31, 2021 at 8:53 AM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I had a dealer install this set in my TRD PRO when I bought it in 2017. They put the switches in exactly the same place. I also add put heaters in the rear seats. They must have some sort of pressure switch in the seat pad because they don't start providing heat unless you're sitting on it. I guess that's a good idea in aces which is left on accidentally as there's no timer.
    JoshuaA[QUOTED] likes this.
