Aftermarket radio replace jbl lost steering wheel controls
Discussion in '2nd Gen Tundras (2007-2013)' started by Hossco, Apr 11, 2020.
  1. Apr 11, 2020 at 4:31 AM
    Hossco
    Hossco [OP] New Member
    I have replaced head unit and jbl amp, I kept the maestro in place however I have lost steering wheel controls..
    Any ideas? I was think maybe the controls run through the amp?
    Thanksb
  2. Apr 13, 2020 at 7:29 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    You would need to look through the head unit manual and see if it supports steering wheel controls. Most should, but you never know.
  3. Apr 13, 2020 at 7:31 AM
    Hossco
    I had controls with the head unit as I have a maestro installed replaced the jbl amp now have no steering wheel controls...
    I'm wondering if the signal goes direct to the deck or does it route through the amp?
  4. Apr 13, 2020 at 7:52 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Maestro connects to the HU with a 4 pin Data cable in the back of the HU on most HUs.
    Which HU do you have?
    Did the controls ever work with the new HU or did this issue start afterwards?
  5. Apr 13, 2020 at 7:52 AM
    blackdemon_tt
    doubt its routed through the amp... there may be a signal interruption, due to the installation of the amp.. I'm no electrical engineer, but you may need an additional wiring adapter for the controls...
  6. Apr 13, 2020 at 7:53 AM
    Hossco
    Issue started after I took out the jbl amp..
  7. Apr 13, 2020 at 8:01 AM
    blackdemon_tt
    I may be wrong on my previous comment, I think you're correct and it may actually be routed through the amp due to volume controls which will go through the amp itself...
  8. Apr 13, 2020 at 8:43 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    What HU do you have?
    You may need to reflash the Maestro since you pulled the JBL amp.
