Air Injection pump stuck P2442 code
Discussion in '2nd Gen Tundras (2007-2013)' started by 10 Bears, May 24, 2024.
  1. May 24, 2024 at 6:39 PM
    10 Bears
    10 Bears [OP] New Member
    11 CREW 5.7
    None at the moment
    I got the dreaded P2442 code
    On my 11 5.7 Tundra today. I got it last year in my 2.7 Taco, eazy enough one pump right on top of the exhaust manifold.
    Another video I saw says there's two pumps one behind each front wheel and there connected to a unit inside the air intake ?? WTH TOYOTA ???
    GUYS what is the easiest cost effective way to get this code gone if I have just one bad pump I'd like to replace just that pump in the meantime as I really don't have the money to change two Unless I absolutely must...I just had foot surgery and been out of work for 3 months. Any tutorial videos or bypass hacks on this forum ?? Help...
    Anything else I should know ??
    IMG_20240524_195216106_HDR.jpg IMG_20240524_195231964_HDR.jpg IMG_20240524_195240946_HDR.jpg IMG_20240524_195237806_HDR.jpg IMG_20240524_195216106_HDR.jpg IMG_20240524_195231964_HDR.jpg IMG_20240524_195240946_HDR.jpg IMG_20240524_195237806_HDR.jpg IMG_20240524_195216106_HDR.jpg IMG_20240524_195231964_HDR.jpg IMG_20240524_195240946_HDR.jpg IMG_20240524_195237806_HDR.jpg
  2. May 25, 2024 at 7:36 AM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Your problem isn’t the pump which is the valve that’s underneath the intake. I would suggest changing both. The valve itself is just a thin Reed valve that when it gets moisture inside it would foul up. For a short term fix you could disassemble the valves and clean them and reassemble the problem will eventually come back though
    koditten and 10 Bears[OP] like this.
  3. May 25, 2024 at 7:38 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Google AIP delete kit. There a company in here that makes them. That's usually what everyone does.
    10 Bears[OP] likes this.
  4. May 25, 2024 at 7:43 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Just to understand you correct..the problem is not the valve in the intake but I should replace both pumps underneath the truck ? Or I should replace all 3 units in the intake and underneath the truck ??
  5. May 25, 2024 at 7:45 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Does anyone know the difference between Gen 1 & Gen 2 AIP DELETE my truck is a 2011 5.7....
  6. May 25, 2024 at 7:58 AM
    2mchfun
    Hit the search box here on the site and research before doing anything. Also watch some Youtube on the subject. Lots of resources are available for you. Hewitt by pass kit is a good solution too. Remember to work any difficult bolts back and forth as you back them out to avoid problems.
  7. May 25, 2024 at 7:59 AM
    2mchfun
    Call Hewitt Tech, very helpful and knowledgeable staff there.
    10 Bears[QUOTED][OP] likes this.
  8. May 25, 2024 at 8:38 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    I'm gonna call them Monday.
    2mchfun likes this.
  9. May 25, 2024 at 8:52 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The two pumps (one for each bank) are up in the passenger fender behind the front bumper. The valves are nestled to the rear of the engine behind/below the intake manifold, but they don’t connect to the intake - they connect to the exhaust headers. The system blows air into the exhaust under certain conditions (colder temps maybe?) at startup, then shuts off after a few.
    The design of the pumps can allow moisture to get into them, and eventually flood them out make them fail… OR the moisture can with its way to the valves and corrode/gum them up either open or closed. You’ll potentially see different codes for the pumps (each bank) as well as valves stuck closed (which you can reset and keep going for a while) or valves stuck open (computer sees an exhaust leak and you’ll go into limp mode).
    If one component is throwing code, it’s best to solve it all at once. But the pumps can be crazy pricey (I haven’t looked them up in years) and the work to replace the valves (it’s one unit) isn’t a small lift either.
    The Hewitt kit (back when I installed it on my 2008) will have a plug-in harness, a wire to run to your starter relay (if I recall correctly), and two blank off plates to block the connection between the valves and the exhaust headers. Those blank off plates were a real pain to get installed (the driver’s side especially) - working in a gravel driveway with the wheels still on didn’t help. But still much cheaper and easier than redoing the whole system.
  10. May 25, 2024 at 8:57 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Ok thanks understood.
  11. May 25, 2024 at 9:38 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Or is it ???? Lol
    Q. The "switching valve stuck" mentioned in the P2442 code above in pictures...
    Is that valve located inside the bad pump ?? Also anyone know if Bank two is
    Driver or Passenger side.
    You can tell I'm a oil filter plugs and brake change level pre auto mechanic LOL...
    I'm not a mechanic by trade.
  12. May 25, 2024 at 9:45 AM
    koditten
    Kirk
    Midland of the Mitten
    There is no difference. The only problem is often, the dealer would reflash the ECU to make pumps run at random times instead of only at cold start.
  13. May 25, 2024 at 9:58 AM
    RainMan_PNW
    Casey
    Clark County, WA
    The valve is the ones behind the air intake - the valves open to push air into the exhaust stream.
    Bank 1 is drivers side, Bank 2 passenger side.
    Not that it makes a lot of difference - this is what the unit looks like. Both valves are part one component.
    I didn’t watch the full thing, but this gives a run down of the replacement
    https://youtu.be/kq7-Qc9bzHk
  14. May 25, 2024 at 10:13 AM
    Orions Dad
    2007 Tundra 4.7L
    There is a difference between gen 1 & 2 for your year you want Gen 2. You can go to Hewitt web site it will explain the differences. The Gen 1 was more for pre 2007 and only fixes electrical issues the Gen 2 fixes electrical and mechanical issues
  15. May 25, 2024 at 10:15 AM
    Orions Dad
    2007 Tundra 4.7L
    The valve is separate from the pump. Bank 2 is passenger side
  16. May 25, 2024 at 10:18 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Wow now I'm really off base. In case I decide to repair...Does this mean my two pumps are fine behind the fender well ? And this is the stuck open part ^^^^^^ Wich happens to be behind the air intake not inside the upper intake on a 5.7 ??
    I haven't found a 5.7 video on YT with my code and repair
  17. May 25, 2024 at 10:21 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Looks like Siamese valves one for ea bank ?
    By installing the Gen 1 (2011) bypass I can avoid all this work in the video looks like...I hope.
  18. May 25, 2024 at 10:24 AM
    Orions Dad
    2007 Tundra 4.7L
    Your code shows valve and not pump. Your pumps are fine. If you get the Hewitt 2nd gen kit it will eliminate any codes except for damaged pressure sensors in the valves ( the block off plates will keep that from happening)
  19. May 25, 2024 at 10:25 AM
    Orions Dad
    2007 Tundra 4.7L
    Yes one valve for each bank.
  20. May 25, 2024 at 10:27 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Thank God so by installing the Gen 1 bypass I avoid the extra labor I can leave all parts in place.?
  21. May 25, 2024 at 10:30 AM
    Orions Dad
    2007 Tundra 4.7L
    You can leave the damaged parts in. You will need the Gen 2 it will show on Hewitt’s web site and when you call the owner he will tell you the same thing. Remember Monday is a holiday
  22. May 25, 2024 at 10:33 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Dumb question....Why do I need the Gen 2 and not Gen 1 ?? Bypass kit..anyone ??
  23. May 25, 2024 at 11:14 AM
    Northwoods22
    Northwoods22 New Member
    MN
    2013 tundra grade
    Your truck is Gen 2..
  24. May 25, 2024 at 11:28 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Fa
    Fair enough
    Northwoods22[QUOTED] likes this.
  25. May 25, 2024 at 12:39 PM
    koditten
    Kirk
    When a pump fails, you get out into limp mode.
    When a valve goes bad, you just get a code .
  26. May 27, 2024 at 11:14 AM
    10 Bears
    11 CREW 5.7
    None at the moment
    Screenshot_20240527-130646.png Aside from the OEM Toyota air Injection check valve $$$$. I reckon these are maybe best in quality ? Has anyone bought a after market unit and not had issues with it ? I'm thinking sure some are hot garbage but all of them ???. If you have used one in your 5.7 and it's been a good unit or know of one please post or pm me where you found it and cost.
