Air ride or add a leaf
Discussion in 'Suspension' started by Dcsk8terantz, Apr 22, 2023.
  1. Apr 22, 2023 at 7:06 AM
    Dcsk8terantz
    Dcsk8terantz [OP] New Member
    Gumby McStaniel
    Atlanta, GA
    2020 4x4 SR LB
    Trans cooler Westin brush guard Bed cover Driver entry handle Full radio and speaker upgrade w/SW Seat covers
    Hello everyone. I’m pulling the trigger on a ‘21 DC longbed for a new glass truck. It will be sporting an aluminum glass rack that weighs around 1200lbs fully loaded. 900lbs empty.
    https://unruhfab.com/equipment/pickup-truck-glass-racks/
    https://www.chaosfab.com/product/2007-2021-Toyota-Tundra-Bed-Stiffeners-48677
    I have already decided to go with the bed stiffners but am unsure if I should go with the add a leaf or air ride addition for the full time extra payload. anyone that has a utility bed or something similar with experience in this what would they recommend and why.
    Thank y’all for the advice!
  2. Apr 22, 2023 at 7:18 AM
    I'm assuming this is a business truck. Are you subject to DOT inspections and weighing?
  3. Apr 22, 2023 at 8:37 AM
    Dcsk8terantz
    Gumby McStaniel
    Atlanta, GA
    2020 4x4 SR LB
    No DOT inspection. I’m more concerned with structural integrity
    ColoradoTJ likes this.
  4. Apr 22, 2023 at 8:51 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I would likely opt for a new set of leaf springs that are designed for the constant additional weight.
    Air bags rely on a compressor and extra parts that increase the failure factor.
    Leaf springs are just leaf springs that don't have electronics, a lot of moving parts and usually don't fail.
    I vote for beefier leaf springs and a rear sway bar.
    ColoradoTJ and 2mchfun like this.
  5. Apr 22, 2023 at 10:28 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    The spring route is a better way to go, but the add-a-leaf isn't ideal. They are curved too much and designed for lift, leading to eventual failure with a load. You want to match the factory curve (which isn't much) with more leafs. Boise Spring does kits for Tundras where they add 4 leafs to each side and remove the overload, and people seem very happy with them on Wander the West forum. Cost shipped was ~$550 a couple years ago, but like everything it's probably higher now. You could also probably find a local spring shop that would do the same thing.
    Shocks with more damping would be a good idea too... I like the Ironman FCPs on mine.
    HulkSmurf14 and ColoradoTJ like this.
  6. Apr 22, 2023 at 12:40 PM
    Dcsk8terantz
    Gumby McStaniel
    Atlanta, GA
    2020 4x4 SR LB
    Awesome so the Boise spring kit just adds to the top of the existing leafs it looks like from the picture. Would I be loosing a good bit of travel going that route? We do glass for heavy equipment (cat, komatsu, John Deere, etc) so we will be driving through rough job sites multiple times a day for grading crews. That would be my only concern is if we loose travel.
  7. Apr 22, 2023 at 3:13 PM
    rruff
    rruff New Member
    They just add 4 leafs to the 3 stock ones, minus your overload. If stock curve is maintained, travel up and down will be the same as stock. You'll gain a little ride height I think because the pack is thicker.
  8. Apr 22, 2023 at 3:19 PM
    2mchfun
    Dobinson's HD 5+2 leaf packs. Solid product for around $1200.
  9. Apr 22, 2023 at 5:17 PM
    You are commercial, so how are you not subject for inspection? We have mobile DOT inspections pop up all the time.
    I would also suggest spring pack route. It just makes sense to go that route.
  10. Apr 22, 2023 at 8:31 PM
    blenton
    blenton New Member
    Bags are great. I’ve run mine for several years without issue, occasionally running gravel roads at 50+mph with similar loads. They have helped my factory springs last longer. I ran each bag on a separate line up to the gas tank filler where they are easy and convenient to access. The nice thing about them is that they can be adjusted to suit the load and aired down when not needed. I’ve almost always had a compressor with me so it is convenient to fill wherever I am. Recently, I purchased an m18 inflator (the m12 version is good for basketballs and bike tires, and works great for air bag lines but not truck tires) and use it to adjust the bags and air up tires on the rare occasion that I need to air down (had to recently to self extract myself and trailer from the middle of nowhere in a snowstorm).
    That said, I am looking at entirely new custom leaf springs as my Icon 3 leaf add a leaf has not held up to the weight as I hoped. Alcan spring quoted me $1200 plus shipping, so it isn’t cheap. Maybe we ask them for a volume discount if 2 sets (says me jokingly).
  11. Apr 22, 2023 at 10:04 PM
    rruff
    rruff New Member
    Not for this application.
    Which ones? I think I'm going to get springs and bags both...
  12. Apr 23, 2023 at 12:18 AM
    blenton
    blenton New Member
    I chose Firestone Ride Rides. The main reason I chose them over Airlift was the jounce bumper - or rather, the absence of a jounce bumper on the ride rites. I understand the reasoning behind putting one in the bags (so you can run 0 psi and not worry about destroying the bag by bottoming it out) but I didn’t see a time when I would need to run 0 psi. Very rarely is my bed empty, and since I decided to leave my camper shell on year round instead of swapping it for my tonneau in the summer, there’s always going to be enough weight on the bags to offset the minimum 5 psi.
    Also, due to the leaf spring position that Toyota chose being directly under the frame, there is a limited amount of room between the axle and the frame. Many manufacturers place the leaf spring outboard to the frame which sometimes allows the upper bag bracket to be mounted higher up on the frame or adjusted for different ride heights. Additionally, I chose to add Daystar cradles which are about 1/2” or maybe 3/4” thick; I don’t honesty recall offhand, but they take up a little more room. So while there is enough room for bags, the jounce bumper wouldn’t have much room before engaging.
    The Firestone bags have held up very well to my use and abuse. Gravel roads, rutted two track, hours of freeway towing and hauling on 100+ degree days, completely ice and snow packed undercarriage, heavy trailers, and lots of weight in the bed… they’ve made me a believer and been well worth the cost. I’ve had zero leaks with the plumbing, as well. I thought I had blown a bag last winter as one day it had zero psi in it, but I’m pretty sure it was a buddy poking a little fun at me; duramax owner humor, I guess… It has not had any pressure issues since. I think I’ve got around 100k miles on them. Maybe a little more.
    and added bonus, they even make a fun Monty Python and the Holy Grail-esque “clipptity cloppff” when flexing the suspension enough for the bags to leave the cradles, then reengage..
    rruff[QUOTED] likes this.
  13. Apr 23, 2023 at 9:11 AM
    rruff
    rruff New Member
    Oh, the clippity clop is a selling feature for sure! :thumbsup:
    I've been looking at long travel bags though. Zidaro on Tundra Solutions and ExPo had good luck with them, but is the only one I know who has used them on a Tundra. And I was going to upload a photo from my computer but I don't see a way to do that. Pretty sure I've done that before... ? Anyway, I can't remember why I thought this was a better way to go, but this is the kit: https://airbagit.com/products/towkit-toy4?rq=yr_2016~mk_toyota~md_tundra
    blenton likes this.
  14. Apr 23, 2023 at 10:18 AM
    blenton
    blenton New Member
    I’ve heard a mixed bag about airbagit gear. I can’t say they are junk cuz I’ve never used them, but the reviews I’ve seen are polarized: they are either the best thing since sliced bread or dumpster worthy. I don’t recall which series I was looking at but they had something like 9 or 10 inches of travel. Prolly a triple convoluted bag. Luckily, the cradles and firestones have met my needs.
    rruff likes this.
  15. Apr 23, 2023 at 10:37 AM
    rruff
    rruff New Member
    Ah, you have a big lift which gives more room for the bags. I want to be at stock height.
  16. Apr 23, 2023 at 11:06 AM
    2mchfun
    Check out Ironman 4x4 greasable shackles and bushings if you get decent springs. Definitely a great improvement to the system. Install with the zerk fittings to the outside for ez lube maintenance.
  17. Apr 23, 2023 at 11:33 AM
    blenton
    blenton New Member
    No, that’s just the wheel drooping. I thought I had a shot of the bag out of the cradles but wasn’t looking close. Stock springs and shackles, so stick height. Just showing that the bags and cradles don’t limit suspension travel.
    Couldn’t find a parking spot so I drove half way up the snow pile in the parking lot. Stuffed the other side. My boys thought it was hilarious. As did a jeep guy in the next row.
  18. Apr 24, 2023 at 11:27 AM
    Dcsk8terantz
    Gumby McStaniel
    Atlanta, GA
    2020 4x4 SR LB
    not sure if it’s a GA thing or not but we haven’t ever had issue with DOT. Hopefully this isn’t me speaking something into existence
  19. Apr 24, 2023 at 11:29 AM
    Dcsk8terantz
    Gumby McStaniel
    Atlanta, GA
    2020 4x4 SR LB
    Will do thank you for the tip
    2mchfun[QUOTED] likes this.
  20. Apr 24, 2023 at 1:18 PM
    That's a federal thing, but you have probably been lucky. It would be hard pressed to say a glass truck is for personal use only.
  21. Apr 24, 2023 at 1:54 PM
    Dcsk8terantz
    Gumby McStaniel
    Atlanta, GA
    2020 4x4 SR LB
    “I understand officer but you see I have a really big family and we are all known for being clumsy and having bad luck”
  22. Apr 24, 2023 at 3:41 PM
    Good luck. :rofl:
    I have been pulled into DOT checkpoints a couple times in the last two years. They have a hard time proving that I have a business when I'm employed someplace else and can prove it.
    Maybe you don't need to worry about it. You could call your local DOT and ask some questions.
