Air suspension valve location in the cab
Discussion in 'Suspension' started by Natebucks, Mar 9, 2022.
  1. Mar 9, 2022 at 11:41 AM
    Natebucks
    Natebucks [OP] New Member
    Nate
    2008 Tundra 5.7L
    Has anyone installed air valves in the cab to control air bag psi from the drivers seat with a ridgid cordless pump? Ridgid pump is only $70 compared to the on board compressor kits.
  2. Mar 9, 2022 at 11:42 AM
    Natebucks
    Nate
    2008 Tundra 5.7L
  3. Mar 9, 2022 at 12:07 PM
    timsp8
    NY
    I did kinda what I think you’re asking. I have airlift airbags and an airlift compressor. I ran the hoses in to the cab and mounted the compressor behind the rear passenger side seat where the jack was. I used a plug in the floor to run the hoses.
    Not the best picture, but here one is.
  4. Mar 9, 2022 at 12:23 PM
    Natebucks
    Nate
    2008 Tundra 5.7L
    That’s a great idea but I was thinking about the valves up front where I can manually inflate with the cordless compressor.
  5. Mar 9, 2022 at 1:47 PM
    timsp8
    NY
    It’s the same idea. I have a T on my hose in the cab where I can manually inflate if the compressor goes out. In your instance, just run the valve up front instead of behind the rear seat. It’ll work.
  6. Mar 9, 2022 at 2:12 PM
    Natebucks
    Nate
    2008 Tundra 5.7L
    I understand now sorry.
    Where did you run the hoses to get into the cab?
    Iam going to look for an existing hole instead of drilling.
  7. Mar 9, 2022 at 2:31 PM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Yes I did, this is the control panel that I have installed, and I put the compressor behind the drivers rear seat.
    I can inflate and deflate while sitting in the drivers seat.
    I cant remember what hole I used to get the plumbing thru, but I seem to recall that there are a couple of rubber bungs around there in the floor.
  8. Mar 9, 2022 at 2:36 PM
    timsp8
    NY
    I used a plug in the floor under the rear seat. There’s also plugs under the front seats that I used to run the wires for my pop n lock. Just cut a small slit and use some silicone after you run the hose. It’s never leaked. The part # was on the plug too if you ever remove it and want to replace the plug.
  9. Mar 9, 2022 at 2:56 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I thought about what you are asking but decided against it. Instead I placed the valves in where the licence plate bolts were.
    Doing the inflation outside allows you to ensure the load it level and you put only as much as needed. I would have been going outside to check the results anyways.
  10. Mar 9, 2022 at 5:39 PM
    Natebucks
    Nate
    2008 Tundra 5.7L
    Than you all for the info. I see your point about being outside checking the height.
