Alcon Brake
Discussion in '2.5 Gen Tundras (2014-2021)' started by 19PlatinumCrew, Feb 10, 2024.
  1. Feb 10, 2024 at 4:44 AM
    19PlatinumCrew
    19PlatinumCrew [OP] New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Just wanted to let everyone know there is a Group Buy going on...model 07 to 22+ check it out in group buys.
    2mchfun likes this.
  2. Feb 10, 2024 at 8:15 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Highly recommend, 5 stars, would buy again.
    2mchfun and reywcms like this.
  3. Feb 10, 2024 at 9:00 AM
    JohnWhicker
    JohnWhicker New Member
    I always used OEM's in both of my Tundras and they lasted me forever. Why is the Alcon brand a better brand? Just curious? And cost will be a good place to start as well if is a group buy?
  4. Feb 10, 2024 at 9:48 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    This is a big brake kit . 6 piston calipers front 4 piston rear. Power stopping power, the rotors are larger and thicker allows harder longer stops more frequently without fade. This isn’t just a rotor pad replacement.
    https://alconkits.com/pages/product-result?rq=yr_2018~mk_toyota~md_tundra
    2mchfun likes this.
  5. Feb 10, 2024 at 9:56 AM
    JohnWhicker
    Nice and thanks partner. But holly smokes, 6K for the kit?
  6. Feb 10, 2024 at 12:22 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Followed by a shit-eating grin every time you stop hard. Hehehehe
    2mchfun likes this.
  7. Feb 10, 2024 at 12:26 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Not just more pistons, but aren’t they all larger pistons as well? I think they’re 2” diameter. Much larger pads that probably have twice the area of OEM.
    They’re fuckin’ yuge.
    2mchfun and reywcms[QUOTED] like this.
  8. Feb 10, 2024 at 12:37 PM
    blenton
    blenton New Member
    Ok, I didn’t want to clog up the group buy thread asking dumb questions about these brakes, but bear with me and pretend like I’m the simpleton that I am… I have questions.
    Is the Alcon brake kit completely bolt on, or does it require anything in addition? It comes with calipers, rotors, pads, hardware (like brake pins), and new brake lines. Any issues with the fittings? I know that’s dumb, but I recall some folks needing to grind a tiny part off the fittings of some stop tech braided lines.
    What is the service life like? Yes I know “it depends on usage” but let’s maybe talk in expected percentages. Say my OE pads lasted 130k and my replacement front set have gone 70k, but I had to do the rears at 60k.
    When they do need to be serviced, are the rotors usually good to go another round, or do they usually need to be replaced with the pads. I’ve had brake combos that eat pads, eat rotors, or both.
    Dust?
    I’m sure I have more questions but I’ll stop there.
    Oh, forgot to ask vs front only vs front and rear…
  9. Feb 10, 2024 at 1:38 PM
    19PlatinumCrew
    Dave
    That is the reason for the Group Buy..10 sets get you 15% off doesn’t matter if you want Fronts only Rears only each pair is counted towards the 10sets.
    2mchfun likes this.
  10. Feb 10, 2024 at 2:33 PM
    windblown101
    windblown101 New Member
    2019 CrewMax Limited
    IMHO one doesn't buy big brake kits for longevity. They will last as ong as OEM most likely though. One buys big brake kits for one of two reasons: 1) You are running heavy over size tires and racing and therefore need the larger surface area and fade resistance or 2) You have the coin and think they look cool and who doesn't like cool?
  11. Feb 10, 2024 at 2:45 PM
    JohnWhicker
    Exactly. I did a similar upgrade for my BMW V12 M8 twin Dinan turbos but I had a need for better breaks on this beast
    windblown101[QUOTED] likes this.
  12. Feb 10, 2024 at 2:55 PM
    blenton
    blenton New Member
    Thanks for your opinion. But it doesn’t answer any of the questions I asked… :rolleyes:
    Joe333x likes this.
  13. Feb 10, 2024 at 3:15 PM
    windblown101
    I thought you asked about longevity?
  14. Feb 10, 2024 at 3:26 PM
    blenton
    blenton New Member
    For which you opined. Unless you run Alcons or know those who do…
  15. Feb 10, 2024 at 3:37 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Per the bottom of the product site. Also, id look at youtube.
    These kits were designed through extensive testing in Alcon’s military and armored program for many years and are an extremely effective and proven platform used worldwide by both NGO and official vehicles. The basis of our newest Ford Raptor and Jeep kits was this research and knowledge.
    Benefits
    • 45% reduction in brake disc temperature rise
    • 42% reduction in pad work rate for longer life and more torque
    • 10% less pedal effort
    • 10% increase in brake torqu
  16. Feb 10, 2024 at 4:15 PM
    windblown101
    You are correct. I have no direct experience with this kit. Given the nature of your initial inquiry I thought perhaps a bit of background regarding big brake kits might be helpful. If you only want input from those who run this kit I understand. I'll part this thread with only a suggestion - I'd recommend asking for some specifics like what the piston volume differences are so you can calculate a likely needed MC swap. I'd also ask about what if anything should be done about changes to proportioning pressures between back to front.
  17. Feb 10, 2024 at 4:48 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Low dust, and much longer wear. We bet at least 2-3 times more than an Oem set and this is with extreme use. It does bolt in. Only mods needed are to mod the dust shield or removing it. The calipers actually clear better than factory. Brake lines etc included.
  18. Feb 10, 2024 at 5:12 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Yup, what Rey said. We trimmed the backing plate (dust shield) to make room for the larger diameter rotors.
    Otherwise, it’s all bolt on. I have a buddy that owns a brake & alignment shop, and he put it all together for me. He was really impressed with the quality and completeness of the kit.
    No Ragerts.
  19. Feb 11, 2024 at 3:19 AM
    19PlatinumCrew
    Dave
    My primary reason for even considering these is I tow and am planning to tow cross country to Alaska. I have looked at other mfg of BBK kits and they appear to lean towards the look than the performance aspect. I haven't run them because of the buy in....that's why I'm TRYING for this GB.
    reywcms and 2mchfun like this.
  20. Feb 11, 2024 at 3:41 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    I saw the link and the price is just out of my budget at the moment but thanks for the information.
    I will have to put it on my list of things to get.. Lord willing I will get to the brakes later this year.
    I like having options and did not know about this brand.
  21. Feb 11, 2024 at 8:40 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    How readily available are replacement pads and rotors? Are they a must buy from Alcon or are they available through retailers?
  22. Feb 11, 2024 at 8:40 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Alcon
  23. Feb 11, 2024 at 9:08 AM
    coTony
    Tony
    Montrose, CO
    where does everyone work in this forum to get the money for brakes that are made of gold?
    raylo, Chad D. and reywcms like this.
  24. Feb 11, 2024 at 9:21 AM
    19PlatinumCrew
    Dave
    RETIRED.......I am on a fixed income
    coTony likes this.
  25. Feb 11, 2024 at 9:59 AM
    blenton
    blenton New Member
    The corner...
  26. Feb 11, 2024 at 8:55 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    I’m a regular fella with a fairly regular job in a niche sector of the construction industry. Like most folks, we budget our money and know wheee it goes. When there is a surplus, it goes in savings and we get to buy things that we don’t normally need.
    Here’s how I planned for it…. I was about due for all new brakes at about 120,000 miles. I’d rolled new pads in the front around 85K, but that was before we started towing a lot more.
    How much are all new OEM rotors and loaded calipers? I never checked, but I’m sure it’s not too cheap. Let’s say $750? Shit, I dunno…. But, take that amount off the price of the Alcons.
    Then, put a value on how you want the truck to perform when you’re towing and need to stop now. Yeah, I’m ready for someone to tell me that I need a bigger truck if I have braking concerns. Priced out a new truck lately??? Well, move some of that cost over to the Alcon budget.
    Since the OEM brakes were the only thing that I didn’t feel was up to the task of my towing, why get a bigger truck? I love my Tundra and it does everything I want. Now, it also stops the way I want.
    So, are the Alcons really that expensive???
    We have no issue dropping $3K on wheels and tires. $1,000 light bars, Yes please. Gears are spendy, as is a good exhaust if you want one. And don’t get me started on superchargers! I can’t get my head (or budget) wrapped around one of those yet…
  27. Feb 11, 2024 at 9:05 PM
    blenton
    blenton New Member
    Ain't that the truth...
    Consider the supercharger like buying a new truck... but paying much less.. :D
  28. Feb 12, 2024 at 8:20 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Alcon's kit for Tundra is same for LC200, which were originally made and designed for security vehicles, aka armored vehicles, a lot of them were armored up to B7 level.
    I don't have personal experience with Alcon, but I've had experience with other similar brake systems design for armored vehicles, the longevity is good, pads are decent, they are more aggressive, but the rotors tend to wear very well.
    Also keep in mind these type of brake calipers use ductile iron vs alloy, ductile iron are much more stiffer than alloy and doesn't deform when hit by projectiles, Alcon states if vehicle is sub 4700kg or 10k lbs, use the front kit only.
    Do you have photos? I recall there was only 50 Dinan 8
    reywcms likes this.
  29. Feb 12, 2024 at 1:53 PM
    JohnWhicker
    Sorry, but no makeup and a very bad hair day :( It didn't look like this in the last car show :)
    No idea how many are left. This is the last one for the US market that rolled outta factory in 97 and I drove it from Munich to Rotterdam and then ship it into Galveston with about 500 miles on board. I now have 25K miles on it and still smells brand new inside :) My son is gonna be one lucky SOB as I promised him if he makes Eagle Scout the the V12 is his. Well he made Eagle last year :)
    19PlatinumCrew[OP] and reywcms like this.
  30. Feb 12, 2024 at 3:48 PM
    Downytide
    GTA
    Wow, spent lot of time in the BMW world and E31 is always one of my favorite, I assume it's a CSi due to the turbine wheels?
