Alignment Specs
Discussion in '2.5 Gen Tundras (2014-2021)' started by denali302, Aug 30, 2019.
  1. Aug 30, 2019 at 5:32 PM
    denali302
    denali302 [OP] Meh...
    Michael
    2017 Crew Max
    Can someone look at this and tell me if this is what it’s supposed to be? Don’t know much about this
  2. Aug 30, 2019 at 6:08 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    scratch my first post if ya read it. Edit! Yes that is a good align after your initial spec sheet. They did ya a great align
    Below is spec with Camburg control arms. It’s suppose to have 6-7* of caster. Rides night and day diff
  3. Aug 30, 2019 at 6:17 PM
    denali302
    Michael
    2017 Crew Max
    Thanks! Much appreciate the info. Here’s the finished product
    motoxscott, Stroke250 and fundratss like this.
  4. Aug 30, 2019 at 6:25 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    6-7* of caster? Good lord. You must really like replacing your rack and pinion every 10k miles huh?
    You shouldn’t run more than 3* of caster, especially with larger, heavier wheels and tires. 6-7* of caster puts tremendous strain on your steering components.
    B737 likes this.
  5. Aug 30, 2019 at 7:04 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    That looks great!
    Maybe you should call Camburg and tell them you would like to be their engineer since apparently you know more.
    Positive caster creates a lot of align torque (the force that straightens the steering wheel when you go forward) which improves straight line stability of the car. Due to the geometry of positive caster it also will increase negative camber gain (a good thing) when turning. As you increase positive caster the steering wheel will get heavier also, but with modern power steering systems this is rarely a problem.
    However when you do not have stock suspension components then there isn’t a need to replace components (ie rack) every 10k because it is correct. Doubtful Camburg has only a YouTube degree....
  6. Aug 30, 2019 at 7:13 PM
    Danman34
    Danman34 New Member
    Danny
    Camburg isn’t telling you to run 7* of caster. Positive caster is needed, but you can certainly have too much. I know exactly how caster works. Hence why I’m trying to help you. You can put the required oil fill amount in your truck but putting an extra quart isn’t going to make it run better. You’re doing more harm than good. Too much positive caster means the pump has to work that much harder to turn the wheels opposite of the force pushing them back straight, I.e. positive caster. The truck only comes with 3* of positive caster at most in stock form with 31.8” tires.
    The truck will right itself perfectly fine with as little as 1.5* of caster in these trucks. 2-3* of caster is ideal
    So you can run 7* of caster all you want since you seem to know what you’re doing.
    Lol
    Good luck.
  7. Aug 31, 2019 at 2:01 PM
    motoxscott
    motoxscott New Member
    Scott
    Hurricane, UT
    2017 Tundra
    Camburg - FOX - Method - General Tire - Deaver - Rigid
    We build quite a bit more caster into all our Tundra upper arms intentionally, it really improves the handling. We typically align them around 5.5 - 6 degrees depending on the ride height of the truck. Because of the anti-dive built into the upper arm frame mounts in relation to the lower arm mounts, caster changes quickly with ride height changes.
    We have trucks with over 100K miles on them with zero steering issues on the original steering parts. Not something to be concerned about. I've got 30K on my Tundra and steering is good as the day I drove her off the showroom floor.
    Scott @ Camburg
    NoMoreGreen and fundratss like this.
