Alpine Ktp445u amp
Discussion in 'New Member Introductions' started by Caritaman1, Feb 2, 2021.
  1. Feb 2, 2021 at 11:59 AM
    Caritaman1
    Caritaman1 [OP] New Member
    Charles
    2012 Tundra Crewmax 5.7 Texas Edition
    Hello everybody, I am new to the forum. I’m just excited for I just added the Alpine ktp 445u to my stock head unit. And I gotta say it made the focal plug and play speakers sound amazing. Don’t even need sub. Just had to share. My Tundra is a 2012 Crewmax .
    The Black Mamba and YardBird like this.
  2. Feb 2, 2021 at 12:52 PM
    TheBeast The Beach
  3. Feb 2, 2021 at 12:53 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Welcome! Did yours have the factory JBL system?
  4. Feb 2, 2021 at 1:27 PM
    Caritaman1
    Charles
    Non jbl.
  5. Feb 2, 2021 at 5:41 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Feb 2, 2021 at 7:03 PM
    BMET
    BMET New Member
    2018 Tundra Limited
    Nice. I need more volume out of my unit.
  7. Feb 5, 2021 at 8:54 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
  8. Sep 5, 2023 at 11:27 AM
    mestes1999
    mestes1999 New Member
    Marcus
    2020 Tundra SR5 CrewMax
    I realize that this is an old post, but looking to replace the factory, non-JBL underseat amp with the KTP-445U. Found these wiring harnesses which are made for this amp on Amazon, do I just cut off the factory harness and resplice it to this harness or how does it work? Amazon.com: 2010-2019 Toyota Tundra (w/o JBL Audio) AutoHarnessHouse.com Factory Amp Upgrade Harness AHH-4438 : Electronics
  9. Sep 5, 2023 at 12:17 PM
    Caritaman1
    Charles
    No need for slicing. Just connect right wires from harness to amp. Then it’s plug to factory harness.
  10. Sep 5, 2023 at 12:18 PM
    mestes1999
    Marcus
    Excellent, thanks
  11. Sep 5, 2023 at 12:24 PM
    Caritaman1
    Charles
    I just hope you’re not like me and never satisfied. Since then I upgraded with Audison af m 12.14 bit, all Audison components, mid range, Audison coaxial and Jl audio powered sub. Now satisfied
  12. Sep 5, 2023 at 12:26 PM
    mestes1999
    Marcus
    Well, my current plan is to replace the head unit with an Alpine Halo 11, replace the factory amp, then the factory speakers at some point.
  13. Sep 5, 2023 at 12:33 PM
    Caritaman1
    Charles
    Alpine sounds great, but didn’t know you had factory amp. Wiring could be tricky. My truck was non jbl and no factory amp.
  14. Sep 5, 2023 at 12:38 PM
    mestes1999
    Marcus
    Yes I have the non-JBL factory system which has an amp under the seat. The harness I sent the link for is supposedly to attach the KTP-445U directly to the factory wiring so you can just directly replace that factory amp.
  15. Jan 1, 2024 at 1:09 PM
    meagain
    meagain New Member
    Any reports on satisfaction or otherwise with the Alpine replacement amp? I may grab one today
  16. Jan 2, 2024 at 1:58 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Another revival of an old intro thread!
  17. Feb 4, 2024 at 11:56 AM
    mestes1999
    Marcus
    Okay, so I got the wiring harnesses in which connect directly to the factory harnesses under the passenger seat for the non-JBL amp. I also got the Alpine KTP-445U amp. I'm a super newb at car audio, I know I will need to crimp wires together, but where do the RCA jacks go? I have other pics if needed.
  18. Feb 4, 2024 at 2:44 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You won't use the RCA jacks.
    You are using speaker-level inputs..:thumbsup:
    500KTP445U (crutchfieldonline.com)
    Make sure you put the switch on speaker input.
    Your amp and speaker wire colors.
    That is the amp at the bottom of the page.
    It should have every wire you need unless you run a power line from the battery instead of using the factory amp power...
    Screenshot_2024-02-04_165024_90fa801d5b5524602449a022377e2a5c5bb8a0c1.pngScreenshot_2024-02-04_165044_39ed9faa7b1abfabe9eab1ccfae0706aad29943a.pngScreenshot_2024-02-04_165100_a3d7b7180bba5e5d7676e478905f0efcc12b4b9f.png
    Remember your dash speakers are powered from the HU, they don't go thru the amp.
  19. Feb 4, 2024 at 4:08 PM
    mestes1999
    Marcus
    Wow, thank you so much.
    1lowlife likes this.
  20. Feb 5, 2024 at 6:27 AM
    mestes1999
    Marcus
    Where did you get the color diagrams? I need to find the larger version that are a little clearer.
  21. Feb 5, 2024 at 7:09 AM
    1lowlife
    DADA
    2014 MGM DC SR5
