Alternatives to decked storage
Discussion in 'General Tundra Discussion' started by Rubberdown, Jul 5, 2021.
  1. Jul 5, 2021 at 2:52 PM
    Rubberdown
    Rubberdown [OP] Spilling my guts here.
    That decked storage system is absolute garbage. Is there a good alternative to them that is out there that doesn’t crack and fall apart?
    Sunnier likes this.
  2. Jul 5, 2021 at 3:02 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  3. Jul 5, 2021 at 3:05 PM
    Blue Thunder
    Washington
  4. Jul 5, 2021 at 3:12 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Build ur own with mdo plywood and cover it with a camper
    JustJake and B.Ross like this.
  5. Jul 5, 2021 at 4:54 PM
    jsteph89
    jsteph89 The wish list continues to grow
    Joseph
    South Texas
    2019 Limited 4x4
    Blacked out emblems, Leer 100XL camper shell, Magnaflow exhaust, ProComp 3/1 level kit, 285/55R20 Falken Wildpeaks AT3, WeatherTech mats, full led interior swap,
  6. Jul 5, 2021 at 4:57 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    I've come to the conclusion I'll be building my own when the time comes.
  7. Jul 5, 2021 at 7:56 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Do you need sliding drawers? I was about to pull the trigger on a Milwaukee Packout setup for my bed before I sold the truck.
  8. Jul 5, 2021 at 8:03 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Good to know, was saving up for one but not if the AZ heat is going to kill it.
  9. Jul 6, 2021 at 7:11 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I use a Bedslide and contractors cap and it gives me a lot more flexibility than the drawer systems I think as well as better more secure and weathertight storage overall.
    The side boxes are larger than the drawers and a lot more easy to access and latch with steel pins at three heavily weatherstripped points and then I use drawers or bins or both or neither as needed in the bed which I can bring out to me as I need to and I dont have to lose any height in the bed to the drawers all the time.
    Last week I removed the two huge RV fiberglass drawers that I usually have stacked in one side in back so that I could move tall stuff and it is really quick and simple to make the change too.
    I thought I wanted the Decked myself but I know now it would just be in my way a lot of the time. It also seems like a lot of space is wasted in a Decked by how thick and curved the plastic needs to be to support any real weight there so you lose space to make it possible at all.
  10. Jul 6, 2021 at 7:45 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    First I've heard of this issue with the Decked system. Can you elaborate?
  11. Jul 6, 2021 at 9:46 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I, also would like to hear about your decked system failure. I have had mine installed for 5 years without any problems. Please validate your criticism with some details and pictures.
  12. Jul 7, 2021 at 8:53 AM
    Dontra
    Dontra Newer
    Don
    AR
    2021 Ram Big Horn
    2021 Ram Patriot Blue, Lonestar or Bighorn, Crew cab 4x2, 5.7 bed, 5.7 Hemi etorque, Level 2, anti-spin 321 rear end, Air ride, 33 gal tank, 18 in wheels, Multifunction tailgate, Ram box, Wheel liners, MT Brown Deluxe bucket seats, 8.4 no navigation, Trailer brake controller. Front and rear rubber mats. Mopar power steps,8 yr 85K extended Mopar warranty.
    I had a decked system for about 5 years, works real good
    Saltyhero13 and gosolo like this.
  13. Jul 7, 2021 at 3:30 PM
    Rubberdown
    I had one briefly. The top cracked with very little use and minimal weight. I have several contractor buddies that use them that are experiencing the same thing within the first year of purchase. Plus they leak once the top cracks and everything gets soaked as the water just stays in the drawers.
    Glad yalls are working out for you.
    gosolo and Sunnier like this.
  14. Jul 7, 2021 at 4:03 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Expect to get a little... friction when you call an item absolute garbage, people will defend said item because they paid alot of money for it, whether its a good product or not. Seeing that you're from Houston, you should probably explain that you're in a hot, dry?wet? environment and the drawer system is exposed to the elements and not under a cover or whatever the situation was.
    As for an alternative, I always recommend making friends with a welder and supplying him liberally with beer and tacos.. you could end up with a very nice custom system :thumbsup: :welder:
  15. Jul 7, 2021 at 5:48 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Sorry to hear about your experience. I worked in construction my whole life and can understand how the decked system could fail with that sort of use. In retirement, with limited use it’s really nice for my current needs.
    edit; I’m not ‘defending’ anything, but if someone has a valid complaint about a product we should be provided details to know if we’re being trolled or not.
  16. Jul 7, 2021 at 6:12 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    We have one in a dually at work, 2 years now with no issues. The boys are pretty hard on stuff but it seems to be holding up quite well !
    gosolo and Wallygator like this.
  17. Jul 7, 2021 at 6:33 PM
    OnespeedTRD
    Don
    San Diego
    Something doesn't sound right about this.
    Did you contact Decked to see about a warranty replacement?
    From everything I've heard and read they are really good when it comes to standing behind their products.
    Anything can break, but these systems are pretty stout and normal use should not be causing the sort of damage you describe... abuse on the other hand. You can't overload something and then wonder why it failed, and you can't just toss heavy equipment or materials on it and expect it to hold up.
  18. Jul 7, 2021 at 7:15 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Weatherguard packrat
    CallsignKodiak and gosolo like this.
  19. Aug 11, 2021 at 12:53 PM
    CallsignKodiak
    CallsignKodiak New Member
    Bear
    Iiawah
    2021 CrewMax 4x4
    Bone stock
  20. Aug 11, 2021 at 12:54 PM
    CallsignKodiak
    Bear
    Iiawah
    2021 CrewMax 4x4
    Bone stock
    Has anyone owned the truck tool box made by Decked?
  21. Aug 11, 2021 at 1:01 PM
    Looking in from the outside…
    “This system is garbage!”
    “Here’s a quality one..”
    “Kick me hard in the taint! I don’t wanna pay that for quality!”
    Living in Houston might be pretty rough on plastic where others might not have any issues. :thumbsup:
    Terndrerrr, Bammer and GODZILLA like this.
  22. Aug 11, 2021 at 1:11 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    I had a Truck Vault in my last vehicle (Tahoe). It worked for what I needed it for but was extremely expensive and not particularly rugged. I believe their pickup truck models may be built differently.
    In my Tundra, I've had a DECKED system for a few months now. Love it, but it does have its limitations. Probably only makes sense if you have a canopy or don't need a tonneau cover. With a tonneau, you really don't have much space above the drawers for taller items like ice chests, luggage, etc. When we went on our beach trip this summer, I had to remove the entire DECKED system to be able to fit larger items under the tonneau. RLD Design canopy should arrive in another month or so though, at which time I will reinstall the DECKED system.
    Saltyhero13 and CallsignKodiak like this.
  23. Aug 11, 2021 at 1:35 PM
    CallsignKodiak
    Bear
    Iiawah
    2021 CrewMax 4x4
    Bone stock
    Agreed. Any manufacturer can have a bad production run based on flawed raw materials or flawed process, QA, etc. I don't have any particular opinion on Decked overall, but I'll always give a manufacturer a chance to warranty an issue.
    AggiePhil likes this.
  24. Aug 12, 2021 at 2:48 PM
    Blue Thunder
    Washington
    The D Box? Yes, they are awesome. I kept the two I had when I sold my Decked system. They are heavy, but solid.
  25. Aug 12, 2021 at 3:51 PM
    AggiePhil
    College Station, TX
    No he’s referring to their new in-bed vertical toolbox.
  26. Aug 13, 2021 at 2:49 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Arb makes one I think
  27. Aug 13, 2021 at 2:59 PM
    Rubberdown
    Guys I’m sorry I never responded to this. I ended up selling my bed cover and then ended up buying a longbed f250 diesel to use in those situations anyway so... I just walked away from the raised platform stuff. I just have a couple pelican cases and transfer them from truck to truck as needed.
    gosolo likes this.
