Alternatives to Switch Pros SP-9100?
Discussion in 'Electrical' started by tnine, Jul 29, 2021.
  1. Jul 29, 2021 at 1:02 PM
    tnine
    tnine [OP] New Member
    Todd
    2016 TRD Off Road
    ADS External Reservoir Shocks Deaver Leaf Springs 35" Tires C4 Fabrication Bumper Warn Winch Baja design LP9
    Hi All,
    I've unfortunately gone through 2 switch pros in the last 18 months. The first failure, the unit was swapped under warranty, and it appears that this one will likely be swapped as well. Does anyone have any alternatives to the switch pro with a similar function they can recommend? I basically need the following.
    1) Remote key panel for 6 switches
    2) Some sort of mount. Right now I have mine mounted to the stick shift with the SDHQ mount for the Tundra
    3) The ability to configure DPDT for 2 switches. I have 2 Baja LP9 Pros, and I want to ensure you can't turn both low and high switches on at the same time since it cooks the lights.
    4) Something that will last longer than 6 months.
    Given that the first Switch pro 9100 lasted a year, and the second only lasted 6 months, I'm really beginning to lose faith in the product.
    Thanks in advance!
  2. Jul 29, 2021 at 1:10 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Gravy likes this.
  3. Jul 29, 2021 at 1:44 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    SPOD is another option
    Trigger as mentioned
    Rough Country makes one
    DIY for six switches is possible but you’re gonna end up with wires out the ass in the console/dash.
    I went with cheap Amazon option from voswitch but not sure how it would handle the high/low on those Baja’s, I have the lp9 sports so they are just on or off and it didn’t matter for me.
  4. Jul 29, 2021 at 2:26 PM
    dgtulsaguy
    dgtulsaguy New Member
    18' 1794
    Sorry to hear that! How is the brain mounted? I've had the exact same setup mounted between the battery and headlight for almost 2 years now.
  5. Jul 29, 2021 at 2:26 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I use the ARB Linx controller but it doesn't have integrated relays like SP does so you'll have to install your own.
  6. Jul 29, 2021 at 2:48 PM
    tnine
    Todd
    2016 TRD Off Road
    Thanks for the reply everyone! @dgtulsaguy, attached is a photo of my installation. It sounds similar, it's mounted vertically just to the right of the left (driver) headlight. In the first failure, I used a new keypad connection cable and a new keypad from an unopened box to verify I was receiving the same error (keypad sync errors), where the keypad was unrecognized even after scanning for it in the app setup. Given that the power module and the keypad were replaced, I assumed it would resolve the issue.
    However, now that I'm experiencing the same failure again, I'm wondering if my connection cable was installed incorrectly and possibly damaged in some way. How close is yours to the battery and radiator? Whenever I check the temp on the app while driving, it's well below its max claimed operating temperature. I've never seen it get above 70C at it's highest point. It's supposedly rated to 125C, so I think the mounting is fine.
    dgtulsaguy likes this.
  7. Jul 29, 2021 at 2:57 PM
    dgtulsaguy
    18' 1794
    That's where I mounted mine as well. I was curious because I saw warnings all over their documentation about not mounting it horizontally, mounting seems fine. Did you use the same harness or did you switch that out last time too? That may be pinched somewhere...
  8. Jul 29, 2021 at 3:15 PM
    tnine
    Todd
    2016 TRD Off Road
    Yeah, that's my concern that the wiring harness is pinched. They want me to send all 3 back for testing. I figure I might as well send them all back since the wire is the hardest part to remove.
  9. Jul 29, 2021 at 4:04 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    I would recommend the triggersystems linked above. The overall design is superior and I believe their functionality is equivalent. I am admittedly biased against switchpros, I find their pricing to be predatory. I do like that they claim to be made in the USA, and they definitely have some neat features, but, in the end, the controller is a potted pcb. Weatherproof yes, but also poor heat dissapation and non-repairable. IMO thats why although they charge a premium, their warrantee is only for 2 years. If you have the cash and like the small form factor, more power to you.
  10. Jul 30, 2021 at 10:19 AM
    tnine
    Todd
    2016 TRD Off Road
    I've ordered a replacement wire, rather than have to go through the hassle of taking everything out. Both failures occurred when I unplugged my Amp Power Steps ODB2 connector to flash my ECU. I have a feeling that the pressure of that connector hanging down exacerbates a broken or pinched connection where the cable comes through the firewall. It's the only component that's not been replaced, so it would make sense that it is the root cause of my issuses. I'll report back once it's re-run!
  11. Jul 30, 2021 at 11:21 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    If your getting a new replacement on your unit I'd be willing to buy that and the mount from you if your selling them. Dm me.
    HulkSmurf14 likes this.
