Alternator size?
Discussion in '3rd Gen Tundras (2022+)' started by ThatQualityGuy, Jan 24, 2024.
  1. Jan 24, 2024 at 7:54 AM
    ThatQualityGuy
    ThatQualityGuy [OP] New Member
    Dave
    Tundra 4x4 SR5 Dbl Cab TRD Sport with tow package
    Air bags
    Have a 2023 Tundra SR5 TRD sport DC 6.5ft bed with tow package. What is the amp size of the (stock) alternator?
  2. Jan 24, 2024 at 8:37 AM
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    I believe 180 amps. That seems big to me for a non hybrid. Makes sense for the hybrid. On my Scangauge, the percentage of alternator capacity is generally no greater than 27%. That would be around 47 amps which seems a lot DC current demands on a non hybrid if the output is truly 180 amps on my truck. But then we have electric fans, electric assisted steering, and a lot more electronics watching everything.
  3. Jan 24, 2024 at 8:45 AM
    smileytn1
    smileytn1 New Member
    Mine has a power inverter for the hybrid instead of an alternator.
  4. Jan 24, 2024 at 9:07 AM
    blenton
    blenton New Member
    Parts catalog lists the alternator as 180 Amps as @tbrady mentioned. That’s a fair size alternator. I believe 2nd Gen was 150 amp; must be a lot more Nannie’s on the 3rd gen.. :)
    A 47 amp nominal load isn’t all that much considering a blower motor can consume 30 amps by itself. Add all of the computers to run the vehicle, dash, lights, radio, etc and 47 amps isn’t bad, IMO. Most vehicles come with 80-100 amp alternators with headlights and HVAC typically being the largest power consumers.
    Mattedfred likes this.
  5. Jan 24, 2024 at 9:36 AM
    ThatQualityGuy
    Dave
    Air bags
    Looking at installing a 40 amp DC-DC charger to charge camper batteries while driving. Article said make sure alternator was large enough to handle it. Is it as simple as saying I will have 180 - 40 = 140 amps still available for the truck, ie, the 180 amp alternator is big enough?
  6. Jan 24, 2024 at 9:53 AM
    blenton
    blenton New Member
    Your camper batteries should already be charging from the tow vehicle via the 7 pin trailer plug - part of why tow package equipped vehicles have a larger alternator to begin with.
    Rcflyersd likes this.
  7. Jan 24, 2024 at 10:02 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    With most modern vehicles transitioning to electric power steering vs conventional hydraulic power steering, 175-200+ amp alternators are becoming the norm to keep up with the current demands while maintaining the ability for quick state of charge recovery for the battery from starting loads coupled with frequent short trip driving of some owners driving habits.
    blenton likes this.
  8. Jan 24, 2024 at 10:11 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    This
  9. Jan 24, 2024 at 10:17 AM
    ThatQualityGuy
    Dave
    Air bags
    Yes, I agree battery will charge via 7-pin plug. That's fine for an 80-100ah flooded battery, but that battery died and we are upgrading camper electrical system to inverter and probably 300ah lithium batteries. These will need a different charging regiment and present wiring to 7-pin plug can't carry enough amps to be effective or efficient. Hence the DC-DC charger.
  10. Jan 24, 2024 at 11:21 AM
    blenton
    blenton New Member
    The charger should be built in to the camper end and turn on whenever voltage is present at the plug. It will still charge your lithium batteries, just not at MAX charge rate.
    You are welcome to spend the money and install the additional charger if you please; we are just saying that it should already have power present (30A if memory serves).
  11. Jan 24, 2024 at 11:53 AM
    ThatQualityGuy
    Dave
    Air bags
    Exactly. And to circle back to alternator size, I have asked Service at the dealership to confirm what's been said here, which looks like the 180 amp alt has enough capacity.
  12. Jan 24, 2024 at 12:09 PM
    ThatQualityGuy
    Dave
    Air bags
    VERY NICE set-up! Ours is celestial silver. We camped in Algonquin as kids many, many decades ago - beautiful place. How are you using the portable solar?
  13. Jan 24, 2024 at 12:30 PM
    tbrady
    tbrady New Member
    Southern Idaho
    If I recall correctly, the DC power in the 7 pin connector is fused at 30 amps. Next the gauge of the wire providing the power is probably 10 or 12 gauge so a little small to carry 40 amps. 10 gauge is rated at around 30 amps but not for the distance from the alternator to the RV battery. If you are going to put in a DC-DC charger I would limit it to 15 amps. Most DC wiring guides recommend using 10 gauge wire for carrying up to 15 amps 20 ft. LFP batteries have a very high charge acceptance rate, and if you offer them 40 amps they will take it. One way to limit the current flowing to the battery is to limit the capacity of the charger.
  14. Jan 24, 2024 at 1:03 PM
    blenton
    blenton New Member
    Gotcha. I know Lithium batteries need a different charger but I was under the impression that the charger took whatever power was available and metered it out to the batteries similar to MPPT solar chargers, but it looks like I got my wires crossed. Good to know.
  15. Jan 25, 2024 at 6:11 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    It's not so much the amperage capacity coming from the 7 pin, rather lithium chemistry batteries need a completely different and critical charge algorithms to safely recharge them compared to lead acid deep cycle chemistry. Lithium batteries are much more subject to damage or even fire hazard if proper charge/discharge processes are not used. Therefore a dedicated charger must be used.
    Now standard lead acid type deep cycles can be charged directly from the B+ output of the 7 pin.
  16. Jan 25, 2024 at 6:31 AM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Trailer wire from plug back gets sketchy on trailers. Size-type-insulation. I’d keep charging system separate. Start at truck battery back. Use separate plug. Wire sized and protected.
  17. Jan 31, 2024 at 5:45 AM
    ThatQualityGuy
    Dave
    Air bags
    tbrady I believe you nailed it with "One way to limit the current flowing to the battery is to limit the capacity of the charger". I've read the lithium will take all that you give it, so I think I might use a 20amp charger, better for the alternator as well. What I've read and watched supports what bonefish says as well. Also, watched a Will Prowse video where he confirmed 40 amps coming out of a 40 amp charger to a lithium battery. And I have confirmed with the dealer I have a 180 amp alternator (tow package on truck). My question now, folks, is to ask if anyone has actually installed a DC-DC charger on a 2022 or 23 Tundra. What size charger installed? What are your experiences? Any problems caused with the alternator or anything else? The dealer's service shop has not seen these installed on such new models so they have little to no experiences to offer. Thanks.
  18. Jan 31, 2024 at 5:58 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Nice TT!
    Mattedfred[QUOTED] likes this.
  19. Feb 16, 2024 at 5:59 PM
    ThatQualityGuy
    Dave
    Air bags
    Back to - I confirmed the truck has a 180 amp alternator. I need to know the "rated output current" for this alternator. I assume it is not 180 amps because that's too easy. Does anyone know? Sent this question to the dealer but have not heard back.
