Amber DRL / Turn Signal bulb keeps going out?
Discussion in 'Lighting' started by ToyotaTundraMike, May 8, 2019.
  1. May 8, 2019 at 12:12 PM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    One of my amber drls finally burned out last month so I had the dealer swap out the bulb last week when I had my truck in for an oil change / tire rotation.
    2 days later the new bulb they put in is already burned out.
    Any ideas what is causing this?
  2. May 8, 2019 at 12:22 PM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Either a short or just a bad bulb. Try installing another one and if it goes out too then you've narrowed it down to a short.
  3. May 8, 2019 at 6:34 PM
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    I had this same issue. I found out it wasnt a bad bulb after my replacement wenent out. When I wiggled the connection the light would come on and then go back off. What I found out was the copper prongs that hold the bulb in place were too loose. I just took a small screwdriver and got behind each prong and slightly bent them inward so when I slide the bulb back in it was tight. I have not had an issue since. Hope this helps
    8notch likes this.
  4. May 8, 2019 at 7:35 PM
    They tend to rust out too. The good thing is you can replace the socket and it is only about $10.00
  5. May 8, 2019 at 8:22 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I had one where it turned out that the base of the bulb wasn't pushed into the socket far enough and was making intermittent contact.
  6. May 22, 2019 at 11:54 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    Make sure you're using latex gloves to install as well. Your oils from your skin kills a bulb fast.
