Amp power wire size and installing 2 amps.
Discussion in 'Audio & Video' started by 1lowlife, Dec 28, 2019.
  1. Dec 28, 2019 at 12:19 AM
    1lowlife
    1lowlife [OP] Toxic prick and pavement princess..
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'm ditching my Apline PDX V9 5 channel amp, the 500 watt sub channel isn't pushing my twin 10" Stealthbox at all.
    I'm installing a JL Audio JX1000/1 mono and JX400/4D 4 channel amps.
    Both amps require a 4 ga line according to instructions.
    I have 1 4ga line already run.
    Debating on just running another 4 ga line from the 1 in 2 out fuse distribution block next to the battery and having 1 line for each amp.
    That block has 0ga to the battery.
    Or just running a 0 ga from the under hood block and putting a distribution block closer to the amps to run 4ga to each.
    A42FF023-6418-4EC0-B72D-C282CFBDE8D8_zps_e5e67cebb1f6b65e87a11f16b96baddda9cf5473.jpg
    Any input appreciated.
    Thanks...
    619Tundra likes this.
  2. Dec 28, 2019 at 4:28 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    I always run 0 gauge from the battery to my amp racks Distribution block. From there I can split up the 4 gauge feeds to my high and low amp. 0 gauge is a little more expensive than 4. But aesthetically it’s a much cleaner install and your setup will never max out what the 0 gauge can supply. It’s better to have more headroom then not enough.
    1lowlife[OP] likes this.
  3. Dec 28, 2019 at 9:10 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Thank you ..
    I think that is what I'll do.
    I can't figure out if the 4ga I have is copper-clad aluminum cable (CCA) so I was going to replace it.
    I had a shop run the line years ago.
    You have a recommendation on what wire to use?
    I usually use KnuKonceptz..
    Have a favorite on the dist blocks?
    I appreciate your help..
  4. Dec 28, 2019 at 10:18 AM
    Danman34
    Danman34 New Member
    Danny
    knukonceptz is good. I’ve personally been using a Kicker distribution block for damn near 10 years now. Any quality block will do the same thing haha.
    I have a sundown saz1000 and an alpine pdx4 off the single 0 gauge wire. So no shortage of power.
    1lowlife[QUOTED][OP] likes this.
  5. Dec 28, 2019 at 11:02 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    3880598C-2BE3-418A-A850-3BAF12C43D70.jpg This is a good reference chart I like to use.
    Toyotoholic and 1lowlife[OP] like this.
  6. Dec 28, 2019 at 1:10 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Definitely run 0 to a distribution block in the rear. Cleaner, and you’ll have more options in the long run.
    SKAR audio has OFC for a very reasonably priced kit. I used them for my wiring and my sub amp and i am pleased.
  7. Dec 28, 2019 at 2:34 PM
    Twinky
    07 double cab work horse
    Home depot/Lowes typically carries welding grade wire. It was much cheaper than any of the car audio branded ones last I checked. Less than half if I remember correctly.
    Car audio power wire is basically just welding wire with a few differences in the insulation and some car audio brands can have a higher thread count. Higher thread count is the main factor in its flexibility, but welders wire is already very flexible.
    If I was you, I would leave the 4 gauge from the battery and tie it directly to your 4 channel amp. Then run a new 0 gauge for you sub amp.
    Its probably overkill, but if there's a place that can never be overkill, its your electrical.
    And if you haven't already, do your big three upgrade too.
  8. Dec 28, 2019 at 3:21 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    X2 for welding wire
    Especially if u only need the run of 0 gauge
  9. Dec 29, 2019 at 10:43 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I looked at Lowes years ago and found just stiff home electrical wire.
    I'll go back up there and look for welding grade.
    I goggled the big three upgrade.
    I'll look into that,,
    I think the 4 ga I have is copper-clad aluminum cable (CCA), so I want to replace it.
    It looks like copper strands, but the cut end looks silver and not copper.
    Both amps will be under the passenger's seat.
    I should have put that in the OP.
    Thank you all for your input.
  10. Dec 29, 2019 at 11:48 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Both of those amps are class D
    The single 4gauge will be plenty of copper for both amps under the seats.
    They are not power hungry amps so you won't need to bump up the gauge. If they were BOTH 80-100a inputs and class ab, then you would, but they are not.
    A 40a and an 80a, class D is fine with a single 4g wire under 20 feet and a single 100a fuse at the battery is all you need. You will never be using the full current available, nor should you worry about it.
    Look at the chart @bensky posted for the Coast guard. That will be beyond whatever you want to reference for your truck.
    Desolate likes this.
  11. Dec 29, 2019 at 11:51 AM
    3rdGenTundraDC
    3rdGenTundraDC New Member
    MGM
    Central Florida
    14 Tundra DC
    305/50/20 Nitto Terra Grappler G2 Stock, stock, stock.
    Stinger 6000 4 guage ofc can handle up to 1700 Watts. 0 guage will all depends on your future upgrades. If you add a secondary battery and can keep the cables short, you'll be fine with 4 guage ofc. You only need 4 guage to be able to charge the secondary battery with an isolator relay.
    That's definitely CCA. On audio type cables, usually if it doesn't advertise OFC on the jacket, it's most likely CCA. I had the 4 guage knukoncept basik before upgrading from a 500w amp to 1000 RMS and i recently replaced it with the stinger Only which is only $60 from Sonic Electronics without rca. I do notice the competitors have very inconsistent jacket thickness and the savings are pocket change for compromising quality. If you go with them, be sure to protect the whole run with wire loom.
    Replacing a current cable with a new one is very easy. Just tape the end together with about 6 inch overlap on each cable and slowly pull it through the firewall.
  12. Dec 29, 2019 at 7:35 PM
    Twinky
    Yeah, that's CCA. But CCA isnt necessarily bad. The problem with CCA is when ppl are buying their wire according to copper standards and the retailer doesn't inform them that there is a difference in the appropriate size needed compared to ofc vs CCA.
    Basically if you size the CCA accordingly compared to ofc, it will work safely.
    You current wire would be fine for your 4 channel, but for your sub amp I wouldn't rum anything less than 4awg ofc. That is unless its a short run. Like from a distribution block. Then its not a big deal.
    I still stand by my first recommendation if your budget allows. That said, as long as you don't go below the manufacturer's minimum required gauge you'll be fine.
    Doing a run of at least 2awg from the battery to a distribution block by the amps, and then use your CCA to connect to your amps would be a good option also.
  13. Aug 16, 2020 at 3:11 PM
    jobe
    jobe New Member
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    i have a jl jd 400/4 and a jl jd 1000/1 mono class d amp. im running 0 gauge from my battery to the back seat where i have an audio distribution block. then i will have the two amps back there also. running the 0 gauge on the drivers side and the speaker info wire on the passenger side. here is my block btw.
    https://www.amazon.com/gp/product/B078SCQJNM/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    do i do 0 gauge from the block to the amps or 4?
  14. Aug 17, 2020 at 11:45 AM
    3rdGenTundraDC
    MGM
    Central Florida
    14 Tundra DC
    Whatever your amp recommends and ultimately will accept or fit.
  15. Aug 17, 2020 at 12:06 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Since this was my thread I never updated it, I'll update it.
    I ended up pulling that 4ga CCA out and replacing with with 0ga copper.
    I'm only running an Alpine PDX V9 now, but I may end up running a 4 channel and a bigger mono amp for the sub.
    Does it sound any different?
    No.
    Do I like the way it looks and the possibilities for expansion?
    Yes.
    Should I have used copper instead of CCA in the first place?
    Yes.
    I also replaced the battery ground to chassis with 0ga.
    0e33q5g2_zpssm0sqsag_813d798ec184e0790e7f6a565431d9931eaa976f.jpg e74i36du_zpshny0zage_3e6560b7c52791fe5d88d898422190220a9f005b.jpg
    r7df2zr7_zpscoegh5fw_711a87d3160fc85284b780795e9591756e482e2e.jpg gvap7jp5_zps2iu2ff0k_dbf216b8dd86d54836468820fe4aabe9cccddc0c.jpg
    3rdGenTundraDC and AZBoatHauler like this.
  16. Aug 17, 2020 at 3:43 PM
    3rdGenTundraDC
    MGM
    Central Florida
    14 Tundra DC
    You forgot...
    Do I feel better knowing that might truck won't catch on fire at full tilt.
    HELL YEAH!
    I do have a question for you. Does your battery gauge jump up and down between 14v-12v when you have it cranked? Mine does but I installed a digital gauge to the cigarette lighter and it never goes below 12v so I just ignored it.
  17. Aug 17, 2020 at 3:44 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    It shouldn't. You still running the factory battery?
  18. Aug 17, 2020 at 3:49 PM
    3rdGenTundraDC
    MGM
    Central Florida
    14 Tundra DC
    Yes
    Also I have the SR model with the smaller alternator. I think 90 or 100 amps.
  19. Aug 17, 2020 at 8:20 PM
    Danimal86
    Daniel
    Sacramento, CA
    get a northstar, odyssey, xspower or optima and a capacitor, see if that fixes it.....if not, bigger alternator time
    3rdGenTundraDC[QUOTED] and jobe like this.
  20. Aug 17, 2020 at 10:19 PM
    jobe
    jobe New Member
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    thank you that picture helps me a lot understanding where i will put my block. Is that under the passenger seat? isnt there a vent right there?
  21. Aug 17, 2020 at 10:29 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    That too, I don't worry about the CCA melting.
    I've never had an issue with voltage changes.
    Maybe a capacitor might help with that.
    Keep in mind I don't do too much cranking of the system.
    I rarely turn it up to the halfway point of volume.
    I tried an X2Power AGM battery but it was nothing but a pain in my ass.
    It died on me twice in 6 months.
    Long story, in the end I think I got a lemon and Batteries Plus wanted me to jump through hoops to replace it.
    I traded it on for a core charge for an Interstate and told Batteries + to get ****ed.
    But in the process of trying to make the X2 work for me, I bought a voltage amp booster and an ammeter like you have to get an accurate reading.
    Although it sucked having to look at the ammeter several times a day to make sure my X2 was going to start the truck in the morning.
    Twice it didn't.
    I bought a MK2 Micro blade 5A booster.
    https://www.hkbelect.com/product/436-mk2-micro-blade-5a-electronic-fuse-version-2014/
    My voltage with the engine running is now a constant 14volts, it used to be 13.4 before the booster.
    So I ditched the X2power but kept the booster.
  22. Aug 18, 2020 at 2:33 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I like the sound of that. A constant voltage is good. Where exactly does that booster plug into? And is it specifically for the stock alternator, because I just had a 290 amp high output alternator installed.
  23. Aug 18, 2020 at 4:53 AM
    bamelanc
    bamelanc New Member
    Orange, Texas
    2018 Magnetic Grey Platinum 4x4
    Addictive Desert Designs Stealth Fighter bumper w/ 40" Baja Designs Onyx6 arced dual control combo light bar and Smittybuilt X20 Comp 10k winch. Baja Designs S8 10" amber fog lights. sPod Control for lighting and compressor. ICON Stage 3 Suspension with tubular UCA set at 3". ICON Alloys Six Speed 17" machined/satin black wrapped in 285/75/17 Nitto Ridge Grapplers. TRD Performance Intake. TRD Cat Back Exhaust. LED Kit inside and out. ARB onboard compressor. Amp Research Power Step w/LED kit. Retrax XR Pro bedcover. Armadillo Bed Liner. Tint - 35/5/5 ceramic. Center Console Safe. Weather tech mats.
    If you're running less than 150 amps then 2 gauge should be fine. Keep in mind, that's 150 amps if you ran straight test tones at full volume on all your amps. That will never happen. Musically, a 400 watt and 1000 watt amp will not draw close to that.
    The shop that installed my stereo used 0 gauge. I didn't find out until later, so I feel I was overcharged and the logistics of running 0 gauge vs 2 gauge is a lot different. That said, if you have room to run it and you want to pay the premium then I guess it's fine.
    Upgrading alternators, batteries and the wiring between those is the most important thing you can do to prevent voltage sags.
    I run 2 JL HD 600/4's and a 750/1. 160 amps total.
  24. Aug 18, 2020 at 8:07 AM
    3rdGenTundraDC
    MGM
    Central Florida
    14 Tundra DC
    Yes, that's why I built a small platform to clear the vent. You can buy one premade from metal off the taco tunes website if you don't want to make your own.
  25. Aug 18, 2020 at 8:28 AM
    3rdGenTundraDC
    MGM
    Central Florida
    14 Tundra DC
    I have 2 type s 10s hooked up to that XR-1000.1 in a q power ported box fireing up, port firing towards the back wall of the double cab and it hits but I'm wanting it to hit to the point where you can't understand what the passenger is saying or you're having a hard time swallowing your own saliva type of hit. I think the tundra needs at least 2000 watts RMS or a better box. My setup is a very good back massager but I want that hard hitting bass that you feel it in your chest, not just on your backside. When you can't use the side view mirror hit.
    What do you guys think? How do you feel with your setup?
  26. Aug 18, 2020 at 8:36 AM
    bamelanc
    bamelanc New Member
    Orange, Texas
    You're going to need more than 10's if that's the kind of bass you want.
    3rdGenTundraDC likes this.
  27. Sep 1, 2021 at 10:49 PM
    KingKong
    KingKong New Member
    Asher
    2008 Super White Double Cab Long Bed 4x4
    10s can definitely do it but not those 10s and not any under seat box. You're gonna want something like a Sundown SA series or better in a big box with lots of power. The best configuration for an under seat box that would really bump would be with a few monster 6.5s or 8s like the Soundqubed HDS2s or Savard Hi-Qs.
  28. Sep 1, 2021 at 11:21 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Since you quoted my 2 year old thread and I'm not sure who are directing your comment to.......................
    I ended up running 0 ga to my Alpine PDX V9..
    Just in case I wanted to change the current setup.
    I have a twin 10" JL Audio Stealthbox with two 10TW3-D8 Subwoofers that I hated for 4 years.
    SB-T-TUNDB3/10TW3/BK - Car Audio - Stealthbox® - Toyota - JL Audio
    After finally researching it, and taking it apart, that box was factory wired in series and that is why it sounded like sh!t.
    Rewired it in parallel, bought the box down to 1.9 ohms, and it now sounds perfect with 525 RMS watts...
  29. Sep 2, 2021 at 12:03 AM
    KingKong
    KingKong New Member
    Asher
    That was directed to bamelanc's response to 3rdGenTundraDC's post. For some reason quote wasn't working. But glad to hear your setup is working well. I'm looking to get a tech12volts under seat ported box with two 10 TW3s, but for now I've got two 12" Polk MM2124DVCs in a 2 cubic foot sealed box on a Prime R2-750 that's keeping me satisfied.
