Android auto adapter
Discussion in 'Audio & Video' started by Lou_F, Feb 21, 2023.
  1. Feb 21, 2023 at 8:29 AM
    Lou_F
    Lou_F [OP] New Member
    2018 Tundra SR5
    New member here. I wanted a way to use Android Auto in my 2018 Tundra without spending $700 plus for a new head unit. I found this on Amazon for just $200. It just came out a few months ago and the few reviews so far are mostly positive. I just ordered it so I don't have any personal experience yet but will follow up with a review if any of you are interested. If any of you have installed this please let me know how you like it.
    GaryinAZ likes this.
  2. Feb 21, 2023 at 8:33 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
  3. Feb 21, 2023 at 8:34 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    https://www.tundras.com/threads/carabc-carplay.118579/
    Different head unit. 20+21 have android auto and apple car play. What OP is talking about adds android auto and apple car play to a head unit that does not support it.
    Lou_F[QUOTED][OP] likes this.
  4. Feb 21, 2023 at 8:58 AM
    Rocko9999
    Rocko9999 New Member
    Others who bought this for the Carplay function had mixed reviews. You have to reconnect it each time you start the truck. It doesn't pick up where the song left off. Kind of a pain.
  5. Feb 21, 2023 at 9:14 AM
    Lou_F
    2018 Tundra SR5
    Don't know if this applies to Android Auto. Guess I will find out.
    Rocko9999[QUOTED] likes this.
  6. Feb 24, 2023 at 10:22 AM
    Lou_F
    2018 Tundra SR5
    Got it from Amazon a few days ago. Installed on my 18 Tundra. Awesome addition to the truck. Can't speak for Carplay but Android auto wireless connection works great. Only reason i gave it 4 stars is the manual could be more in depth as far as operation. Installation was a breeze.
    20230224_131234.jpg 20230224_131226.jpg 20230224_131217.jpg 20230224_131207.jpg
    mhardee86, Henry1jg, Vr0ck and 4 others like this.
  7. Feb 24, 2023 at 10:42 AM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Do you have any pictures of the install itself/hardware attached?
    Sidenote, as a Tuscaloosa native, I absolutely hate that song lol
  8. Feb 24, 2023 at 10:56 AM
    Lou_F
    2018 Tundra SR5
    No pics of the installation. Should have taken some. Hardest part was taking out the radio. The rest was easy. Just removed 4 plugs from the radio and plugged in the unit.
    PomDad[QUOTED] likes this.
  9. Feb 24, 2023 at 12:22 PM
    Rocko9999
    Nice. Any issues with the backup camera turning off while backing up? I saw some others had this issue.
  10. Feb 24, 2023 at 12:24 PM
    Lou_F
    2018 Tundra SR5
    No problems so far but oly been using it a few days. Will report if any problems.
    Joe333x and Rocko9999[QUOTED] like this.
  11. Mar 1, 2023 at 9:10 PM
    manfang
    manfang New Member
    I installed this unit in my car a couple days ago so I thought I'd share my experience. I've got a 2016 Platinum which has the JBL system; and a Pixel 6 with Android Auto.
    The unit comes with no instructions at all, it's just the unit and the cables in a box. Install is straight-forward, there are a few youtube videos on how to take the lower trim pieces out. Others have mentioned removing the XM unit below the head unit, there's no need to do that, there is a ton of room to the sides and far behind the unit. I found it snugly to the left side of the head unit and used some mounting tape to hold it in. The wire harness adapter is well made and can only go in one way. I didn't bother with the USB/Camera harness, I was using the wireless version of android auto and don't have a secondary camera.
    Usage of the unit takes a little getting use to, but overall I'm happy with it.
    The head unit will have 2 different modes after install; "classic mode" which works exactly as before, and AUX/hijack mode where CARABC is in control of the display and buttons. I've found 2 way to switch between the modes. The first is to hold down the talk button on the steering wheel for about 3 seconds then let go, it may start an entune voice prompt but will switch over to the unit. The second way is to switch to the "AUX" input when in classic mode. If you already in Aux you need to switch to another input and the back.
    The backup camera works as before with one exception, you have to wait an extra ~2 seconds or so for the carabc unit to finish booting before you go into reverse. Camera switches on and off just like before when you shift in/out of reverse regardless of which mode you are in.
    When you switch to Hijack mode, a clunky black and white interface comes up which allows you pair the unit and set a couple other options. I unpaired from my entune unit just to make things easier. After pairing and configuring android auto to startup on connection; you'll never see the clunky interface as long as you are paired with the unit.
    Android Auto looked pretty good, no quite as crisp as classic mode but close. Voice recognition worked really well (unlike entune) and the call/hangup,skip etc. buttons on the steering wheel worked in android auto.
    The biggest draw back is that you need to manually switch from classic to hijack mode every time you startup.
    [​IMG] [​IMG]
  12. Mar 2, 2023 at 8:07 AM
    Rocko9999
    Great information. Thanks. Any touch screen lag when moving through Android auto screens?
  13. Mar 2, 2023 at 9:49 PM
    Outdoor Life
    Outdoor Life New Member
    Robert
    2016 Barcelona Red Tundra
    Stock for now
    Thanks for the install info. I'm also thinking about installing this but have a few questions.
    1) I also have a Pixel 6 (pro) and will be using Android Auto mostly to use Google maps. So after pairing the CARabc unit to my phone (Bluetooth I guess?) I can use Android Auto wirelessly without using a USB cable? I guess I'm wondering what the USB cable that comes with the CARabc unit is for.
    2) The picture of the CARabc unit shows a WIFI antenna. What is that for?
    Thanks!
  14. Mar 3, 2023 at 4:44 AM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    I have been experimenting with this unit for a few months.
    https://www.amazon.com/dp/B0BCQ1GKV6
    I use it instead of my phone for all my apps since it is an independent unit that has all the apps loaded on to it.
    Lets the kids and my dad use my truck and enjoy the apps without needing a phone.
    I use a data only SIM from https://www.eiotclub.com for the data.
    I got the 24Gig 360day card for $96 which works out to $8 a month. I have found I use about 1.5Gig a month when I use Waze everyday and some Tunein streaming. I have it connected to the home wifi when I need to update any apps or download any large files.
    I do connect my phone to it via Bluetooth only so it can make calls via my phone. No longer need to connect my phone to my truck anymore.
    Works well so far.
    I also used the moto MA1 for a while but it would need to be unplugged and plugged back in about once a month for some reason.
  15. Mar 3, 2023 at 7:48 AM
    manfang
    manfang New Member
    @Rocko9999 - Other than the startup (a few seconds) the unit is as responsive for scrolling etc as other units I've used (OEM honda pilot system, and other rental cars).
    @Outdoor Life - The USB cable that I didn't install is used for a wired connection to the carabc unit; it doesn't look like the tried to hijack the USB connection to the entune unit. If you wanted to do wired Android Auto you would plug in there, it also looks like if you wanted to do a firmware upgrade it would be from USB storage using that connection. It's also the connection if you have a second camera. I believe the wifi connection is used during the Android Auto scenario for more bandwidth; wireless Android Auto required 5Ghz wifi. You never have to manually connect to it, the only thing you need to connect to is the bluetooth connection.
    I also figured out there is a "car" app in android auto, that when you click on it, it goes back to the carabc UI, and then you press android auto on the unit get back. It makes it a little easier than I though if you want to navigate to the secondary camera.
    Still figuring things out since there are no instructions, but so happy to have this instead of still stuck with entune 2.0 which is worthless.
  16. Mar 3, 2023 at 10:27 AM
    Outdoor Life
    Robert
    Stock for now
    Thanks! If I ever get my tax return back this will be the first thing on my list.
  17. Aug 28, 2023 at 7:01 AM
    Portigy1
    Portigy1 New Member
    B
    2017 Super White TRD Pro Crewmax
    Tint, nerfed bars, dash cam, spectre intake, and Bakflip cover
    Hey guys, have a 2017 Tundra and I'm looking into this product. Any updates? Do you have to switch from hijack mode to regular mode everytime you startup the truck? Thanks!
  18. Aug 28, 2023 at 7:51 AM
    manfang
    manfang New Member
    Yes, pretty much every time you get in, you'll need to double tap the power button on your head unit to initiate the hijack mode for display. I have my android setup to use wireless, always connect and always start playing media. So maybe 30 seconds after you start the car audio will start streaming even if you don't tap the power button.
    Overall this thing has been game changer for me using my stock head unit. I hate fumbling around with my phone to try and stream different stuff while driving not to mention trying to use maps. But there are a few things that you need to be aware of with this unit:
    1. You have to wait 5-10 seconds (until toyota logo appears) after starting before putting car into reverse or your backup camera won't show up.
    2. Call switchover isn't great. If you are talking on the phone then get into your car and start it. You lose audio for 5-10 seconds while it's connecting to the head unit.
    3. You don't get a volume level indicator in Hijack mode.
    Mine connects 99% of the time with no problems. Android Auto has pushed an update which switches your phone automatically into Do Not Disturb mode when driving. That breaks audio streaming for this unit. Easy enough to disable once you find the setting on your phone. I wouldn't hesitate to buy this again... it's the best upgrade you can do.
  19. Aug 28, 2023 at 1:28 PM
    Florida AF
    Logan
    North Florida
    I tore mine out and am working towards a new HU. Good luck with whatever you decide.
  20. Jun 28, 2024 at 9:12 AM
    GaryinAZ
    GaryinAZ New Member
    Gary
    Phoenix AZ
    '19 Tundra SR5 CrewMax; Cavalry Blue; Shortbed; 5.7L, TRD 4x4 Offroad
    Four section tonneau, Air-lift rear levelers, left & right rear bed swing storage boxes and running board steps; 2" front lift, folding mirrors, catalytic converter shield, tailgate pop n lock and next considering a roof rack
    I have a 2019 Tundra and also found the same CARabc accessory that you pointed to for abt $200. I noted some of the one-star reviews and have a little reservation about going with this one. Others like the Navik is for about $700 and seems to work pretty well. So I'm wondering if you got yours installed and found it to be a good upgrade. I want to be able to put my phone on the OEM display and view Waze, Google Maps and maybe browser content. What's your experience & recommendation?
