Another King 3.0 rubbing thread
Discussion in 'Suspension' started by Trabs00, Jun 28, 2022.
  1. Jun 28, 2022 at 11:27 AM
    Trabs00
    Trabs00 [OP] Lifetime Social Distancer
    Travis
    Seattle, WA
    2012 Black Tundra CM
    7" BDS lift King 3.0 Performance series with RR and adjusters 37" Yoko Geo MT Front bumper Demello Offroad Rear Bumper Expedition 1 ATC canopy AMP power steps Alu-cab RTT Alu-cab shadow awning Alu-cab shower cube
    I just upgraded from ICON 2.5s to King 3.0s and initially had contact with the shock from the bolt head on the sway bar. I removed the sway bar but now I rub the coils on my tie rod ends at full lock. Since CB tie rods are pretty thick this doesn't help my situation but I like how robust they are for my setup.
    I know there are many threads on 3.0 coilovers and rubbing but I was hoping for any new opinions or ideas. I have read tons of threads here and on TT on 3.0 coilovers as well as alignment and can't seem to come up with a clear solution.
    I run this truck pretty hard and take it places where avoiding near / full lock is really not an option so "don't go to full lock" will not work for me.
    BDS 7" lift
    King custom 3.0 coilovers
    ICON Billet Delta joint UCAs
    Coachbuilder steering kit
    Kansei offroad 17 x 8.5 -10offset with 37 x 12.5 Yoko MT
    Current alignment specs attached, I was hoping to get my alignment shop to see if they could add a bit more Caster to clear the coils without messing up the rest of the alignment
    Anyone have any luck with Caster > 3 on the rest of the alignment / drivability of their truck?
    Any help greatly appreciated!
    Wheel Straight
    Wheel at lock
  2. Jun 28, 2022 at 5:54 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    I would ask a fab shop about making you a chromoly version of the coach builder tie rod end. I think you could machine a smaller diameter tie rod sleeve if using chromoly instead of aluminum
  3. Jun 28, 2022 at 5:59 PM
    Rubberdown
    What he said. You have no need of those tie rod ends... put the stockers back on and see if it clears.
  4. Jun 29, 2022 at 9:13 AM
    Trabs00
    Travis
    Seattle, WA
    Thanks Rubber
    Would love to hear other opinions as well. I bought the CBs for the additional travel, improvement in steering hangup with BDS lift, and that they are beefier.
    https://www.tundras.com/threads/tundra-2007-coachbuilder-steering-kits.2094/
    My truck is an overland / offroad setup so it is HEAVY but I do actually drive my truck hard, and with 37s I like having robust components... but I never had OEM on this setup so not sure if they are plenty strong enough for the job.
    Unfortunately OEMs are long gone.
  5. Jun 29, 2022 at 9:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Try adding caster first. Above 3 is no problem. Most of the guys I wheel with actually prefer higher and are around the 5 range. Some even higher.
  6. Jun 29, 2022 at 9:44 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Maybe something like this?
  7. Jun 29, 2022 at 2:49 PM
    Trabs00
    Travis
    Seattle, WA
    I have the truck going into the alignment shop tomorrow. I am asking them to shoot for moving the caster until it doesn't rub and then see if they can get everything else in spec. :fingerscrossed:
    joonbug[QUOTED] likes this.
  8. Jun 29, 2022 at 2:50 PM
    Trabs00
    Travis
    Seattle, WA
    Is this a Moog?
  9. Jun 29, 2022 at 2:51 PM
    alb1k
    Left Coast
    It's good
    I don't think so, I remembered seeing them and went to google today. The sight I was on had strait and curved options next to each other.
  10. Jun 30, 2022 at 9:24 AM
    Trabs00
    Travis
    Seattle, WA
    Truck is currently at the alignment shop, targeting Caster 4-6 or what it takes to clear the coils.
    I will update later today / tomorrow with alignment specs and results
  11. Jun 30, 2022 at 6:11 PM
    Trabs00
    Travis
    Seattle, WA
    Update. Try as much as they could they couldn't quite get it to fully clear at lock in reverse. Alignment specs attached.
    They did get more clearance though which is good enough for me, i'll just paint the coils periodically.
    Alignment guy says the BDS knuckle is possibly contributing to this issue (if it extended a bit further forward where the tie rod connected, this wouldn't be an issue).
    I am thinking of grinding a touch off the tie rod arm coating at the spot where it rubs... will check with @Coachbuilder1 if this is safe (just need a few more mm deep off. probably half inch in length)
  12. Jun 30, 2022 at 6:16 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    How does it drive? The toe is a bit high and you should have more caster on the driver's side to account for road crown
  13. Jul 5, 2022 at 11:24 AM
    Trabs00
    Travis
    Seattle, WA
    Update: I haven't had a chance to take the truck on any fire roads / offroad yet (will this weekend) but on road it handles great. Without the front sway bar there is a bit more body roll (to be expected) but I am getting used to it and likely will never put it back on.
    I get just a teeny bit of rub at full lock in reverse, that said I used to hit the sway bar so I think I actually get about the same turn radius if I stay just before lock.
    I am going to stick with as is for a little while and see how things go before I play around with getting different tie rods and opening another can of worms. Might shave down the outer edge of the coachbuilder shackles to see if that helps (still undecided).
  14. Dec 17, 2024 at 7:52 PM
    whitetundy2020
    whitetundy2020 New Member
    2020 Tundra 1794
    Just came here to say I have THE SAME exact issue.... BDS kit, and tie rods hitting my kings and it is killing my soul to see the paint rub off... did you ever find a solution or are you just living with it?
  15. Dec 17, 2024 at 9:34 PM
    Trabs00
    Travis
    Seattle, WA
    Removing the sway bar fixed the issue of rubbing on the coils.
    The coach builder steering kit for me makes it so the tir rods do not hit the coilovers
    I feel you. We Paid A LOT of $$$ for these coilovers, it killed me to see the contact
  16. Dec 17, 2024 at 9:36 PM
    Trabs00
    Travis
    Seattle, WA
  17. Dec 17, 2024 at 9:46 PM
    whitetundy2020
    2020 Tundra 1794
    Thank you so much !!!
  18. Dec 17, 2024 at 9:59 PM
    Trabs00
    Travis
    Seattle, WA
    Also for alignment and " Toyota Lean" I added the 1 inch shims from CB as well
    And better alignment shop got things much aligned more optimally. I also rotate 5 tires every 3k and keep an eye on wear
  19. Jan 17, 2025 at 6:41 AM
    whitetundy2020
    2020 Tundra 1794
    What were your final alignment specs ?
