Another rat problem
Discussion in 'General Tundra Discussion' started by ttttttttttt, Oct 20, 2024.
  1. Oct 20, 2024 at 8:51 PM
    ttttttttttt
    ttttttttttt [OP] New Member
    2018 CrewMax Limited
    Hi Folks- Does anyone know what this port in the back of the cabin filter holder is supposed to be? It got all chewed up. Do I need to worry about replacing it?
    I discovered a rat was in my truck yesterday when I flipped up the back seat and found a nest made with a roll of paper towels I had in there. I vacuumed everything up but found more evidence this morning on the front passenger floor; this looked like sound proofing insulation.
    After searching here I was disappointed to see how common rat problems are. Thanks to the great posts I got mesh installed over the air intake and other holes in the firewall this afternoon. I also think I managed to scare the rat out of the truck. I saw something shoot out and jump into the undercarriage. I have a couple traps set inside just incase.
    When I took out the cabin filter it was very dirty (never changed) and full of debris. I didn't see too much rat evidence there but I think there are some piece of plastic that used to covering that port.
  2. Oct 21, 2024 at 6:29 AM
    2mchfun
  3. Oct 21, 2024 at 7:36 PM
    ttttttttttt
    2mchfun[QUOTED] likes this.
  4. Oct 24, 2024 at 7:52 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    First off. Close your AC to recirc every time you park. He is probably coming in thru the hole where fresh air enters. lift your hood, remove the plastic crap on the right side and when you get to the air inlet hole which is about 4”x9” cut a piece of 1/4” galvanized metal screen and use yellow painters tape to hold it flat over the opening. Nothing larger than 1/4” or they will squeeze thru. They won’t ever chew galvanized metal.
    they will leave if they have no food. But if you trap them they will chew thru 3” of solid wood to get out.
    I’m an expert at rat removal. Having actually shot over 300 and killed many more by other means on our rural property.
    smokint and OldGuy03 like this.
  5. Oct 24, 2024 at 8:47 AM
    seydou
    seydou Distinguished Member
  6. Oct 24, 2024 at 8:48 AM
    seydou
    Welcome.
    Looks like you've done just about all you reasonably can. Except for checking/changing the filter much more often.
  7. Oct 24, 2024 at 8:49 AM
    seydou
    He says he has already done the screening.
    And it would depend on how you trap them if they can chew through anything.
  8. Nov 4, 2024 at 7:01 AM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    After reading this thread and vaguely remembering seeing headlines about Toyota using soy-based wire insulation (can someone confirm this?), I purchased a bottle of the peppermint oil concentrate and, after mixing it with water, sprayed the entire engine bay with a generous amount. I do park outside and have plenty of squirrels running around. DO not want to wake up to some wires being chewed and/or a big nest built in the engine bay. Anyone else using peppermint oil in the engine bay area?
  9. Nov 4, 2024 at 7:04 AM
    2mchfun
    I keep pine sol soaked rags and bars of pink dove soap in the engine bay 24/7
    Pine_Cone67[QUOTED] and OldGuy03 like this.
  10. Nov 4, 2024 at 7:27 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    I tried peppermint spray. Only seems to work a day or so for keeping squirrel out of engine bay. Tried vinegar on rocks around truck, didn't work either. Neither did other pungent sprays that did work for deer repellent.
    So far I haven't found anything to work well for squirrels on engine. Maybe need a general reduction in squirrel population in yard. They haven't chewed anything yet that I can find but I see footprints all over.
    Pine_Cone67 likes this.
  11. Nov 4, 2024 at 7:34 AM
    Pine_Cone67
    2024 Tundra Limited
    Smack.. well, I do not mind squirting the engine bay every other day or so. For the record, I am NOT seeing any activity in the engine bay for now; I just do not want them to ever venture I there.
