Antenna base frustration
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mog, Sep 5, 2020.
  1. Sep 5, 2020 at 11:55 AM
    Mog
    Mog [OP] New Member
    2017 CM SR5 4x4 Magnetic Gray
    I have read every thread I could find and cannot get the broken stud out of the antenna base on my 17 CM. The previous owner broke it off and it looks like tried to super glue it back in. I called the dealer and they want $170 for the assembly and 2 hours of labor to replace. I am moderately handy but don't want to mess with running new assembly to back of radio. Is there something I can do to just replace the component that that the broken stud is stuck in? Can I cut the wires and just replace the assembly that connects to the antenna without running everything back to the radio. So frustrated...
  2. Sep 5, 2020 at 3:27 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Can you drill a hole in it and use an extractor? Also do you have any pics?
  3. Sep 5, 2020 at 8:06 PM
    Mog
    Mog [OP] New Member
    I've drilled all the way through basically, even got the left hand drill bit from harbor freight.
  4. Sep 5, 2020 at 8:11 PM
    DSLKSL
    DSLKSL New Member
    Don
    take a hex bit metric or SAE what ever fits so tight you have to hammer it in. Soak it with WD40 Liquid Wrench, let it for about 30 mins. Then back it out.
  5. Sep 5, 2020 at 9:08 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Get a bigger drill bit.
  6. Sep 5, 2020 at 10:25 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    From your pic I can't tell what is going on.
    It there still mast in there of did you hit the threads?
    Maybe heat the mast up with a soldering iron (melting the super glue) and then try a left hand twist drill bit to get it out.
    Or soak it in WD40 or penetrating oil.
    Maybe...........
    https://www.youtube.com/watch?v=fSx7RjF-pYI
    If you have to replace it;
    Don't forget to buy a mast too.
    https://parts.toyotaofcoolsprings.c...9dHVuZHJhJnk9MjAxNyZ0PXNyNSZlPTUtN2wtdjgtZ2Fz
    How to get the base out, I can't find an interior part video.
    https://www.youtube.com/watch?time_continue=3&v=Wo6liyP0FmU&feature=emb_logo
    Nighthawk likes this.
  7. Sep 6, 2020 at 6:16 AM
    Mog
    Mog [OP] New Member
  8. Sep 6, 2020 at 6:49 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
  9. Sep 6, 2020 at 6:56 AM
    1lowlife
    DADA
    2014 MGM DC SR5
  10. Sep 6, 2020 at 8:15 AM
    Mog
    Mog [OP] New Member
    Alright I've given up on extracting the bolt. I will have to order the new assembly and see if some shop will do it cheaper than the dealer. Appreciate everyone's help and input.
  11. Jan 3, 2021 at 9:27 AM
    Miguel505
    Miguel505 New Member
    Miguel
    2015 CM
    Hey OP just ran into the same problem as you. Did you end up ordering the assembly and getting this installed? Trying to figure out my next move.
    Thanks.
  12. Jan 3, 2021 at 9:35 AM
    Mog
    Mog [OP] New Member
    I ended up just getting a new shorty antenna and screwed it into the hole I drilled out from the super glued mast that was stuck in there. It doesn't fit perfect and but I'm just being careful with it, the radio reception is good though. Never could get the original superglued mast out.
