Anti-seize vs Thread locker
Discussion in '1st Gen Tundras (2000-2006)' started by sixteen2nd, Apr 17, 2020.
Thread Status:
Not open for further replies.
  1. Apr 17, 2020 at 2:07 PM
    sixteen2nd
    sixteen2nd [OP] Shadetree Mechanic
    2003 White Tundra Access Cab TRD
    I have been looking all over and can't find a definitive answer: when to use anti-seize compound vs thread locker?
    For instance, if I'm replacing my front brake rotors and pads, do the caliper fasteners take anti-seize or thread locker? How about tire lug nuts? How about radiator mounts? Etc...
    I've seen people saying it has to do with vibration, if that is true don't all parts of vehicles vibrate? I've seen some people say it has to do with temperature, if that is true don't most fasteners never exceed 200 degrees F? (The exceptions being near the combustion and exhaust)
  2. Apr 17, 2020 at 2:26 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I use thread locker when I dont want something coming apart by itself. Some examples are ball joint to spindle bolts, bolts in hard to see places like on my clutch, on my steering pump, things like that.
    I use anti seize on maintenance things where I know I'll be back to pull it apart soon, especially if dissimilar metals or things that are exposed to elelements. Things like the bolts that hold my brake calipers on, shock mounting bolts, exhaust bolts, things like that.
    I have used anti seize on lug nuts but I stopped doing that and wiped my nuts clean just in case the tire shop forgets to use a torque wrench.
  3. Apr 17, 2020 at 2:34 PM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    Thread locker is more expensive, but I use it on threads and I use anti-seize on mating surfaces and on the threads of things that are difficult to remove.
  4. Apr 17, 2020 at 3:53 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Busting some chops, I don't want caliper bolts falling out due to road vibrations but I also want to be able to take it off when servicing the brakes. So do I put both?
    Darkness[QUOTED] likes this.
  5. Apr 17, 2020 at 4:02 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Both wont work, the greasy anti seize wins. I use anti seize there because the end of the bolt is exposed to elements, so I would rather prevent it from seizing. Torque it to spec and paint mark it, it won't go anywhere.
    Paint marking should be done way more I think. I have a few paint markers and once I've torqued a fastener down I leave a mark. Good to track what hasn't been tightened yet and also track if that fastener has moved later on.
    15whtrd, Wynnded, rebmo and 1 other person like this.
  6. Apr 18, 2020 at 2:05 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    What paint markers do you prefer?
  7. Apr 18, 2020 at 2:46 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I mean you're likely not going to hurt anything using some blue thread locker on most things.
    Even with anti seize a properly torqued fastener shouldn't loosen from vibration present on a vehicle.
    All that said I've slapped anti seize on nearly every fastener I've removed from every vehicle I've owned. It's almost a necessity in PA if you want to make sure the rust doesn't lock it for you.
    15whtrd, Darkness and tvpierce like this.
  8. Apr 18, 2020 at 4:44 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    A tech has told me that pretty much all toyota bolts have some kind of thread locker on them, it’s not in the service manual
  9. Apr 18, 2020 at 7:14 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    tvpierce[QUOTED] likes this.
  10. Apr 18, 2020 at 8:41 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    When using anti-seize pretty sure the ft lb of tightness is supposed to be reduced by 10% or so, anyone know for sure? Also if your using thread locker make sure to only use the blue medium strength and not the red which is permanent.
  11. Apr 18, 2020 at 9:22 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    1. Coming from frame/ body work as a younger man I use anti seize on all suspension parts, wheel lugs, exhaust and different metal to metal bolts( example aluminum to cast iron water pump bolts not where a gasket would go)and any stainless steel threads with a harden / low grade nut or bolt to prevent thread gauling. Any nut that has a cotter key. Not on any bearing or surface (needing a gasket) a bearing would touch. Use a torque wrench on most or if not all 3/8 to 2” nuts, bolts etc. Once it’s torqued down and it’s mostly in an accessible place re check torque after it’s been hot/cold environment. Like a wheel lug nut.
    Thread locker, can be used in many areas but there’s many different kinds of thread lock for example,
    • LOCTITE® Threadlocker 242. ®
    • LOCTITE® Threadlocker 243™
    • LOCTITE® QuickTape® 249™ Blue Threadlocker Tape.
    • LOCTITE® Blue Stick Threadlocker....are all different and used for different purposes
    I’d look up the way you may be using before you actually use it. It may be the wrong one for your application. I just don’t use it because I think it’s going to enhance the thought it’s going to help secure that nut or bolt... for example I used 242 on my 13” flexible radio antenna because I don’t want it to take it off and I want it to stay in place while I own my Tundra. Thats my understanding of these two different products. Anti seize vs thread lock.
  12. Apr 18, 2020 at 11:04 AM
    The lug nut studs should always be dry. Never...ever use anything on the studs.
    Cpl_Punishment, jeremyd and Wynnded like this.
  13. Apr 18, 2020 at 12:20 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Wet torque is typically 25% lower than dry torque. But that's a very rough and generic estimate.
    sask3m[QUOTED] and tvpierce like this.
  14. Apr 19, 2020 at 3:48 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Been throwing anti seize on mine for the last 15 years or so with no issues. Why would you suggest against it?
  15. Apr 19, 2020 at 3:52 PM
    If there's some thread lock on there when I take a bolt off, I put some back on. I usually use the red (unless I have information to the contrary). I actually have a tube of Honda red that has lasted me for 15 years. I use copper anti-seize on my spark plugs and exhaust bolts. Not a professional mechanic. I have a Haynes manual that I use when tackling big jobs and generally follow a combination of that and personal experience. I've never had an exhaust bolt or spark plug fail to come out after using the copper anti-seize. Never had a bolt fall off after using the threadlock.
  16. Apr 19, 2020 at 4:00 PM
    Over torquing for one. There are different torque tables, one for dry, zinc plated, and for wet.
    The second is the whole nature of what anti seize is designed for. I personally do not want to help my lug nuts back out any more than what I’ve seen in the past.
    Good question. I would have never probably known that either except for the career I’m in.
  17. Apr 19, 2020 at 4:18 PM
    KarmaKannon
    Utah
    Some junk
    Alrighty. Do as you wish and I'll keep doing it my way. can't say I've ever had or noticed a out nut back off and I haven't ever had one break either. Given what I've put my junk through I guess that appeases my doubts. In a perfect world I probably wouldn't use anything on lugs, but vehicles that see the street and snow don't live in perfect worlds.
  18. Apr 19, 2020 at 4:56 PM
    You can lead a horse to water, but cannot make it drink.
    I believe this is a true statement that fits this conversation.
  19. Apr 19, 2020 at 5:03 PM
    KarmaKannon
    Utah
    Some junk
    Or you can be an ass and you can also be wrong probably applies. Sorry I forgot you were a secret squirrel know it all that's into some nanotech g13 classified stuff. I am not worthy I am not worthy!
  20. Apr 19, 2020 at 5:07 PM
    Toytock
    Toytock New Member
    Jeremy
    ND
    2015 Tundra TRD Pro
    While you're not wrong about over torquing lubricated vs dry fasteners, I've found anti-seeze on semi lugs, especially cattle trailers helpful in disassembly, and have never had one loose torque. But at the end of the day, it's all in the way someone was taught, and what they perceive works in their mind.
  21. Apr 19, 2020 at 5:15 PM
    I just proved you have been over torquing the lug nuts. Just because you have been lucky for 15 years doesn’t make me an ass. Sorry your feelings got hurt. Maybe I’m weird, but when I learn something new that I’ve been doing wrong, I change those habits.
    Since you plan to continue the process, at least lower the torque values when rotating tires. I’m sure the good ol’ boys at the local tire shop will do that for you.
    Wynnded likes this.
  22. Apr 19, 2020 at 5:17 PM
    I have never seen one lose torque (that I could prove). The more important lesson here is the over torquing and sheering off studs.
    Wynnded likes this.
  23. Apr 19, 2020 at 5:20 PM
    Toytock
    Toytock New Member
    Jeremy
    ND
    2015 Tundra TRD Pro
    Agreed, there is also a major torque difference between pickup trucks, and class 8 vehicles, where lug torque can be as high as 750ftlbs
  24. Apr 19, 2020 at 5:29 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Were you a Nuke ? cause this is some serious Submarine level stuff.. I was a conventional MM, never seen that chart before , Lol
  25. Apr 19, 2020 at 5:35 PM
    Totally agree with this statement.
    A semi has what, 1.5” studs?
    However, regardless of size over torquing can cross the yield strength and cause failures.
    I used to do the same thing with anti-seize. I had a lesson taught to me by a great turbine engineer about what I was doing wrong. I felt a little stupid, but changed what I was doing. I never had failures and I had been driving for 13 years.
    Wynnded likes this.
  26. Apr 19, 2020 at 6:13 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I read that a lot of spark plugs thesed days have a anti seize coating. You can tell by the color of the threads.
  27. Apr 19, 2020 at 6:37 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    If you ever have some spare time look up the NSTM Chapter 75.
    jeremyd[QUOTED] and ColoradoTJ like this.
  28. Apr 19, 2020 at 6:44 PM
    This ^^^
    or ASTM torque charts.
    Sorry for the late response Jeremy. My wife diverted my energy elsewhere.
    jeremyd[QUOTED] likes this.
  29. Apr 19, 2020 at 6:46 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I hear ya brother, mine does it all the time. Lol
  30. Apr 20, 2020 at 8:03 AM
    KarmaKannon will no longer be able to post in this thread. Sorry if you had to see our back and forth.
Thread Status:
