Anti-theft Light Blinking
Discussion in 'General Tundra Discussion' started by tony93, Jan 27, 2023.
  1. Jan 27, 2023 at 8:48 AM
    tony93
    tony93 [OP] New Member
    2015 Toyota Tundra
    This morning I noticed my Anti-theft light started blinking when I turned off my 2015 Tundra. It has never done this before. If I turn on the truck it disappears. If I turn off and lock the truck the light goes from blinking to a solid light (also something I've never noticed before). Otherwise everything is fine. It starts, locks, and unlocks. Looked online but couldn't find anything specific to my issue. Also couldn't find anything in the owner's manual. A lot of online search results state that it should always be blinking when the key is out of the ignition but I'm 100% sure this has never been the case before this morning (been in the truck many times without the key in the ignition and never noticed this).
  2. Jan 27, 2023 at 9:24 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    My 2015 alarm light blinks approximately every 2 seconds with the key out of the ignition and the doors closed.
    1lowlife likes this.
  3. Jan 27, 2023 at 9:31 AM
    NewImprovedRon
    Ron
    NW Arkansas
    1-2. Theft deterrent system
    Engine immobilizer system
    The indicator light flashes after
    the key has been removed from
    the engine switch to indicate that
    the system is operating.
    The indicator light stops flashing
    after the registered key has been
    inserted into the engine switch to
    indicate that the system has been
    canceled.
    ■System maintenance
    The vehicle has a maintenance-free type engine immobilizer system.
    ■Conditions that may cause the system to malfunction
    ●If the grip portion of the key is in contact with a metallic object
    ●If the key is in close proximity to or touching a key to the security system
    (key with a built-in transponder chip) of another vehicle
    : If equipped
    The vehicle’s keys have built-in transponder chips that prevent
    the engine from starting if a key has not been previously registered
    in the vehicle’s on-board computer.
    Never leave the keys inside the vehicle when you leave the vehicle.
    This system is designed to help prevent vehicle theft but does
    not guarantee absolute security against all vehicle thefts.
    1-2. Theft deterrent system 79
    For safety and security
    ■Certifications for the engine immobilizer system
     For vehicles sold in the U.S.A.
    FCC ID: MOZRI-21BTY
    This device complies with Part 15 of the FCC Rules. Operation is subject to
    the following two conditions: (1) this device may not cause harmful interference,
    and (2) this device must accept any interference received, including
    interference that may cause undesired operation.
     For vehicles sold in Canada
    This device complied with RSS-210 of Industry Canada.
    Operation is subject to the following two conditions: (1) this device may not
    cause interference, and (2) this device must accept any interference, including
    interference that may cause undesired operation of the device.
    CAUTION
    ■Certifications for the immobilizer system
    Changes or modifications not expressly approved by the party responsible
    for compliance could void the user’s authority to operate the equipment.
    NOTICE
    ■To ensure the system operates correctly
    Do not modify or remove the system. If modified or removed, the proper
    operation of the system cannot be guaranteed.
    80 1-2. Theft deterrent system
    Alarm
    The alarm uses light and sound to give an alert when an intrusion is
    detected.
    The alarm is triggered in the following situations when the alarm is
    set:
    ● A locked door is unlocked or opened in any way other than using a
    key or wireless remote control. (The doors will lock again automatically.)
    ● The hood is opened.
    ● Vehicles with the glass breakage sensor: The side windows are
    tapped or broken.
    Close the doors and hood, and
    lock all the doors. The system will
    be set automatically after 30 seconds.
    The indicator light changes from
    being on to flashing when the system
    is set.
    Do one of the following to deactivate or stop the alarms:
    ● Unlock the doors.
    ● Turn the engine switch to the “ACC” or “ON” position, or start the
    engine. (The alarm will be deactivated or stopped after a few seconds.)
    : If equipped
    tony93[OP] and 1lowlife like this.
  4. Jan 27, 2023 at 10:08 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Chances are it's always blinked and you never noticed it..
    It's hard to see in the daylight and a bit dim at night.
    My 2014 has been doing it for 8 years..
    Welcome to the forum..:thumbsup:
    Mine blinks all the time when getting in and out of the truck.
    I never noticed what made it go off, I thought it was starting the truck.
    But now I know it's when you stick the key in the ignition..
    I learned something today..:D
  5. Jan 27, 2023 at 10:12 AM
    NewImprovedRon
    Ron
    NW Arkansas
    :hattip:
    1lowlife[QUOTED] likes this.
  6. Jan 27, 2023 at 11:50 AM
    tony93
    2015 Toyota Tundra
    Ok, awesome - thanks everyone for all of the quick replies. Guess I've just never noticed it before now. I won't worry about it then :thumbsup:
  7. Jan 27, 2023 at 1:40 PM
    Welcome from NY.
  8. Sep 8, 2023 at 8:16 AM
    CMT2020
    CMT2020 New Member
    Txos
    2020 cement tundra
    Low battery key fob with my experience.
