Any Anti-theft hint??
Discussion in '3rd Gen Tundras (2022+)' started by 416taco, Jul 20, 2022.
  1. Jul 20, 2022 at 12:25 PM
    416taco
    416taco [OP] New Member
    My neighbour's new F150, being waited for 7 months and driven for only 1 month, was stolen last night on the driveway.
    Cuz most of pick-ups can't park inside the garage, is there any anti-theft idea??
    New Question: any Steering Wheel Lock recommended?
    Thanks
  2. Jul 20, 2022 at 12:29 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Hide an air-tag somewhere in it.
    snivilous, DexterL, TJF805 and 2 others like this.
  3. Jul 20, 2022 at 12:31 PM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    You could install a fuel pump kill switch in it and hide it somewhere inconspicuous. Hard to steal a truck that won't start.
  4. Jul 20, 2022 at 12:33 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Wheel clamp lock. No one is driving it with one of those things on it.
  5. Jul 20, 2022 at 12:41 PM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    You might also looking into electromagnetic kill switch for your battery. They usually come with a separate key fob. You press the button and it cuts battery power to the vehicle remotely.
  6. Jul 20, 2022 at 12:59 PM
    Tundratts84
    Tundratts84 New Member
    2024 Toyota tundra limited 4x4
    Ravelco Anti Theft Device had it on my last truck
  7. Jul 20, 2022 at 1:07 PM
    416taco
    will it void the factory warranty??
  8. Jul 20, 2022 at 1:10 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Its free to pull out your ignition or fuel pump fuse.
    snivilous and Osiris like this.
  9. Jul 20, 2022 at 1:12 PM
    416taco
    same question: will it void the factory warranty?
  10. Jul 20, 2022 at 1:13 PM
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    I use a Hikeit throttle controller. Plug and play right on the gas pedal. 2 min install. It has a lock mode that locks the throttle so it can only operate at idle speed.
  11. Jul 20, 2022 at 1:17 PM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    Not if they don't know you did it. If you take it in for service, just leave the switch enabled. Its not like the service techs will be combing through your electrical system to find stuff that you may have modified to see if it voids warranty.
    Also, I believe a person has the right to modify their vehicle and can't be denied a warranty claim unless the manufacturer can prove that the modification caused the issue. I can't recall the name of it, but there was some sort of lawsuit about that.
  12. Jul 20, 2022 at 2:32 PM
    Pushgears
    Pushgears New Member
    2021 Tacoma TRD OR 6-MT
    An old fashion “Club” with its lock cylinder facing the dashboard is an inexpensive, quick deterrent that adds at least 1 layer of protection.
  13. Jul 20, 2022 at 4:56 PM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Manual transmission would be perfect.
    Oh,well...
    SPP
  14. Jul 20, 2022 at 5:27 PM
    Retired...finally
    So we get cat shields to hopefully prevent our cats from getting stolen and the thieves just steal the entire truck. Cat shields and all.:annoyed:
    EmergencyMaximum likes this.
  15. Jul 20, 2022 at 5:49 PM
    blenton
    blenton New Member
    Empty holster on the dash…
  16. Jul 20, 2022 at 8:11 PM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
  17. Jul 20, 2022 at 8:19 PM
    Medinasmoke
    Medinasmoke New Member
    hugh
    Ohio
    2020 black crew max
    Couldn’t you just unplug it before stealing it?
  18. Jul 21, 2022 at 2:52 AM
    TommyTundra
    Long Island NY
    2019 PRO
    100%. If they know what theyre looking for. My controller is disguised pretty well. When i did the install i wrapped both harnesses with a little black electrical tape too. Now if someone tries to steal it and they even guess throttle contoller now they gotta stop, get out and get in the footwell area with a flashlight, untape two harnesses and get out their small screwdriver to disconnect two harnesses then plug the truck harness back into the gas pedal all while my truck is running in my driveway. I was a police officer for 31 years. Time is our friend. These douchbags want a quick kill. They dont want to work at it. On the flipside I also know if they want it bad enough they will get it. Its a crapshoot any way you look at it.
    Medinasmoke[QUOTED] likes this.
  19. Jul 21, 2022 at 5:32 AM
    Osiris
    Osiris New Member
    20 Plat
    Faraday cage case for your key fob to prevent RF relay attacks while parked.
    Put a piece of paper over your windshield VIN to prevent attackers from pre-emptively setting up a technician scan tool, so they can smash your window and plug into OBD2 and drive off in 15 seconds.
    Re-pin your OBD2 to short out devices that plug into it by changing the 12V and ground pins(fix it before taking it in for service).
    Relay kill switches controlled by remote(bluetooth switches/apps, or wifi remotes)
    Any of the multitude of manual kill switches for fuel pumps/starter/etc.
    They already have a built in GPS that is part of the data logging black box, which automatically shares your driving habits(speed,braking,sharp cornering etc) that can be tracked with the Toyota app but this is powered by a fuse, so... they might pull this.
  20. Jul 21, 2022 at 5:49 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Did they drive it away when they took it or did they use a tow truck to drag it?
    Good driver could drag it in under 20 seconds.
  21. Jul 21, 2022 at 9:15 AM
    Tundratts84
    Read about ravelco... Not one vehicle stolen in 46 years I have a appointment next week to get it installed on my truck
