Any issues with different size wheel spacers on the front compared to the back?
Discussion in 'Wheels & Tires' started by JerseyTundra1260, Jan 17, 2018.
  1. Jan 17, 2018 at 2:38 PM
    JerseyTundra1260
    JerseyTundra1260 [OP] 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    I am considering picking up a set of Bora wheel spacers. My question is would everything be okay if I went with a 1-inch spacer in the front and a three-quarter inch spacer in the rear? I'm assuming everything would be okay but I just want to make sure. Reason being is for it looks like the fronts are tucked in some a little more than the rears and I wanted to match it up best I can. After the alignment nightmare I went through and finally getting it aligned properly my tires got pulled in a little bit more in the front. I miss that more aggressive look:D
  2. Jan 17, 2018 at 3:11 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    the problem with wheel spacers is more about the stress on wheel bearings, ball joints and wheel studs. personally i would probably use the same offset front and rear but it's your vehicle.
  3. Jan 17, 2018 at 3:19 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Marc, shouldn't be a problem at all. As far as wear on your bearings, a 1" / 3/4" spacer is not gonna effect them. You get into trouble going with 2" + spacers that push your wheel out that much farther. I have some gearhead buddies at work that mix match there spacers. My opinion of course. :thumbsup:
  4. Jan 17, 2018 at 3:35 PM
    JerseyTundra1260
    Marc
    New Jersey
    I have had spacers in the past with no issues. Just not different sizes.
  5. Jan 17, 2018 at 3:36 PM
    JerseyTundra1260
    Marc
    New Jersey
    Awesome.... Thanks for the info :thumbsup:
