Any other tool i should get before tackling my timing belt?
Discussion in '1st Gen Tundras (2000-2006)' started by fogg, May 30, 2023.
  1. May 30, 2023 at 3:19 PM
    fogg
    fogg [OP] New Member
    2000 Tundra 4.7 2×4
    None
    Gonna replace belt and pump soon. Got my torque wrenches, all the sockets i need and of course the actual parts. Anything else to make it easier?
  2. May 30, 2023 at 3:24 PM
    Favorite beer or whiskey never hurts. :anonymous:
    ATV25, TRD VO and Tripleconpanna like this.
  3. May 30, 2023 at 3:32 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Pulley puller
    TRD VO likes this.
  4. May 30, 2023 at 3:34 PM
    TRD VO
    TRD VO Fix It Again, Tony
    Louisiana
    2015 Inferno CrewMax TRD Pro
    Crankshaft pulley puller tool if the pulley decides to put up a fight and stays seized on the crankshaft.
    -edit- FrenchToasty beat me to it. :thumbsup:
    FrenchToasty likes this.
  5. May 30, 2023 at 5:11 PM
    bron-yr-aur
    bron-yr-aur New Member
    Ché Calvo
    Windber, PA
    2004 DC 4x4/Tow pckg
    Mods: zip-tied PS line and tire shine
    I know some just use an impact for the crank bolt. But I personally recommend the tool. Crank sensors don’t like impact vibrations. I got mine off Amazon for $26. It was sooo worth it. Surprisingly heavy and solid. Made torquing to spec very easy.
    I took the pic with my hand in it for perspective. The pics online make it look like a flimsy little tool, but it’s stout.
  6. May 30, 2023 at 6:33 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Yep, the right tool, just like a clutch basket holder when working on a motorcycle clutch, instead of jamming the primary gear with a rolled up rag to loosen and tighten the clutch basket retaining nut. The right tool for the job.
    bron-yr-aur[QUOTED] likes this.
  7. May 30, 2023 at 6:39 PM
    bron-yr-aur
    Ché Calvo
    Windber, PA
    Lol or the penny trick (smh). In my earlier days, I actually had a penny jam between the gears. I thought it was going to crack the case with how hard it jammed in between the crank and main shaft (2 stroke). I also broke an inner clutch hub using one of those stupid “universal” clutch holders (the Vice grip type). After using the proper EBC holder, I’ll never go back to rigging stuff like that again.
    chunk[QUOTED] likes this.
  8. May 30, 2023 at 6:46 PM
    chunk
    chunk New Member
    Ha, I've seen the Haynes manuals suggest using a penny, but I was never that brave, I've used an impact to loosen things that go round and round, but to torque it, to satisfy my OCD, you really need to hold it properly. The same with fork damping rods, I buy or build a tool to hold them as well.
  9. Jun 1, 2023 at 11:15 PM
    Jack87
    Jack87 New Member
    Jack
    Denver, Co
    2001 White Tundra TRD AC Limited 4WD
    Pretty much stock
    This tool paired with a 25" breaker bar (I used mine for putting it back and torquing to spec), a pulley puller, and an impact wrench for removing crank pulley bolt (electric 1/2" Ryobi worked for me), and some swivel head sockets 14mm, 12mm and 10mm for all the hard to reach bolts.
    Bonus tool a 3/8” impact for removing bolts easier than a regular ratchet.
