Any way to disable the ‘automatic’ cargo light?
Discussion in '1st Gen Tundras (2000-2006)' started by PenderBen, Oct 22, 2019.
  1. Oct 22, 2019 at 10:57 AM
    PenderBen
    PenderBen [OP] Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    i would like it if the cargo light didn’t come on every time I open the door, I would like it if I could just turn it on with the dash button when I want it on.
    Does anyone know if there is a practical way to do that?
    Thanks
  2. Oct 22, 2019 at 11:06 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'd love to know as well. This has bothered me since day one and I'm sure it's just a wire that needs to be clipped.
  3. Oct 22, 2019 at 11:07 AM
    PenderBen
    2003 Tundra AC 4x4
    Yeah, maybe someone with a wiring diagram could help :)
  4. Oct 22, 2019 at 12:12 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Here you go
    Darkness, bmf4069 and Pinay like this.
  5. Oct 22, 2019 at 12:55 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    This should get you going....1st 2 pages is simply power sounce for just in case. Last 3 should help you let the smoke out :)
    edit.....woops, looks like TX-TRD posted 1 page already !
    Here's also a link to 2000-2003 FSM. One of the links in the index concerns Tundra along with many other Toyota's and one of the 2 documents available under Tundra is a FSM pdf for 2000-2003 if it will help.
    http://toyota.aitnet.org/Toyota/
  6. Oct 22, 2019 at 12:58 PM
    hewitttech
    hewitttech New Member
    Paul
    Toyotas/Lexus
    Secondary Air Injection System Bypass Kits
    Check your owners manual. I remember this annoying me on my 05 DC. There is a setting in the body computer you can change with the tech stream software for this. I want to say there was a setting to stop the door locks from triggering it and another where you can change the time it stays on to 0 and it will only work on the dash switch. I think if you change both you will get the desired behavior but its been about 10 years since I did it so no guarantees.
    Edit*** There are different wire diagrams for the different cabs. Yes, you could just snip the wire from the integration relay to the cargo lamp.
  7. Oct 22, 2019 at 1:34 PM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Or one could just remove the bulb. Mine hadn't worked since I got the truck several years ago, and only recently while doing the LED swap in the interior did I check the cargo light and found the reason to be an empty bulb holder. I put a new bulb in and now the darn thing works all too well. I'm thinking or removing the bulb as it bothers me now, always going on whenever I open the door or use the ignition key.:(
    YardBird likes this.
  8. Oct 22, 2019 at 1:40 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What light are you guys talking about? The one on the roof to light up the bed?
  9. Oct 22, 2019 at 1:40 PM
    hewitttech
    Paul
    Toyotas/Lexus
    That was the obvious solution but he wanted to use only the cargo switch. The reason I looked into it back then was it started to discolor the lens. When I opened it the reflector plastic had started melting. Someone installed the wrong bulb. Snip the wire from the integration relay or change the settings with the techstream.
  10. Oct 22, 2019 at 1:40 PM
    hewitttech
    Paul
    Toyotas/Lexus
    Yes.
  11. Oct 22, 2019 at 1:46 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Why would that light bother anyone? :notsure:
  12. Oct 22, 2019 at 2:06 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The one on the bed. It makes my truck look less dark at night.
  13. Oct 22, 2019 at 2:19 PM
    Professional Hand Model
    Hand Protectors
    I like my OEM set up. Just in case a bad guy is hiding in my bed, the light will shine upon him and scare him away.
  14. Oct 22, 2019 at 2:21 PM
    marbleville
    Yep, last name too.
    State of Confusion
    Yes it is an obvious solution and preferable to snipping wires IMHO. When I installed the new bulb I didn't know that it went on automatically, thinking it was only switch activated. I also made a point of putting in a very high output LED that acts as a flood light, extra helpful when backing up in the dark. Downside is when I go out early in the morning to go fishing and access my cab to load my gear the light comes on and floods my neighbors daughter's bedroom. Not too neighborly. I wish it was switched differently; I am constantly moving quickly to turn it off and it has become rather annoying. I will probably go with a lower output light source.
    tvpierce and YardBird like this.
  15. Oct 22, 2019 at 2:21 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, I like it coming on when I open the door. I use it to locate newspaper in the dark. Also with LEDs i can skin and 1/4 a deer.
    D4x4TRD and Cacoleman2014 like this.
  16. Oct 22, 2019 at 3:25 PM
    mr_data
    mr_data New Member
    Northern New York
    2016 Super White Tundra SR5
    I just took the bulb out of mine. I installed rear facing flood lights anyway.
  17. Oct 22, 2019 at 5:19 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The main reason it bothers me is because I sincerely believe Toyota has a flawed design there. Everybody with a first gen who has removed the lense on that light found melted housing, so I like those lights off as much as possible.
    I pulled a fuse on mine but that also disabled using it if I wanted to. I've never found that light to be useful.
    FirstGenVol likes this.
  18. Oct 22, 2019 at 5:51 PM
    marbleville
    Yep, last name too.
    State of Confusion
    I installed LEDs in the sockets: https://www.amazon.com/gp/product/B07BMQKSPL/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    These LEDs use 7.2watts as compared to the supposed 18watts of the OEM, so my hopes are they run cooler. They sure are brighter. I'll keep a watch out for heat issues, but frankly I turn them off almost as fast as they turn themselves on to limit battery drain even though I'm fairly sure the drain is minimal.
  19. Oct 22, 2019 at 7:18 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I will look into the tech stream action soon, the 4runner could use some customization thru that, lengthen the light cycles for courtesy lighting(puddle lights off the side mirrors, I know wow!!!) and turning off the seat belt chime!!!!!! Yes you can do that!
    Tundra:
    I will lengthen the cycles on that cargo circuit/dome light if it’s the same, and I would tap into that circuit to power a LED pod at the tail gate to shine inward(not in my eyes!!) into the bed of the truck. Also might do a amber removable pod facing the rear(Baja fan boy love) in one of the bed posts.
    marbleville and Darkness[QUOTED] like this.
  20. Oct 22, 2019 at 8:33 PM
    marbleville
    Yep, last name too.
    State of Confusion
    Would you care to translate that for those who are both interested and ignorant of the subject matter, with myself keenly aware that I lead the field. Thank you.:bowdown:
  21. Oct 22, 2019 at 8:59 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Just push the button.
    BestGen likes this.
  22. Oct 22, 2019 at 9:27 PM
    PenderBen
    2003 Tundra AC 4x4
    I’m interested to see where people get with the reprogramming, I don’t have that readily available.
    I’m going to give the wiring diagram a look and see if I can come up with a hardware based solution.
    I didn’t really care about it when I had dim (stock) lights in there, but they were also pretty useless, so I put some LEDs in (just like the ones marbleville posted) and they’re super bright, which is great for actual function, but overkill the rest of the time.
    Anyone here have the ability to try reprogramming?
    marbleville likes this.
  23. Oct 23, 2019 at 6:43 AM
    FrenchToasty
    Mo
    Bone stock
    So you can buy a blue toof obd2 port, you then download a “tech stream” app on your phone or whatever, and you then have access to a bunch of different settings. It allows you to change the length of how long certain lights stay on, or if they come on at all. You can turn off the seat belt chime for when you unbuckle and don’t wanna hear that thing. On the 5th gen Runner I know there are a bunch of other options but I haven’t got into it to find out....yet
    marbleville[QUOTED] and BestGen like this.
  24. Oct 23, 2019 at 6:59 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Techstream is the dealer software, and I'm not aware of any way to run it on a phone. You can run Torque Pro on an Android phone, but that won't give you the full functionality of Techstream.
    I have Techstream running on an old XP laptop. It does give full dealer functionality. On my wife's 2013 Prius, I was able to adjust seat belt chime, auto door locks, and I programmed a new FOB -- which you can no longer do with the "chicken dance" proceedure. I didn't get into adjusting courtesy light functions... but I'm sure it's in there.
    I doubt that level of control is available on the 2000 - 2004 Tundras. Probably on the 2005 and newer it is though.
  25. Oct 23, 2019 at 10:50 AM
    PenderBen
    2003 Tundra AC 4x4
    Any chance you want to try it? You have the techstream and a 2000 Tundra...
    I don’t think there’s a simple mechanical way to ‘fix’ this problem, the third brake light appears to share the same wires.
  26. Oct 23, 2019 at 10:57 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I never heard of doing any of that on our trucks. I know it is common in the VW community but not here. Is there a function to change the paint to black? Some guys here need that one
    :duel:
    bmf4069 and TX-TRD1stGEN like this.
  27. Oct 23, 2019 at 2:42 PM
    Hand Protectors
    I solved the melting housing assy by installing metallic foil tape where the burns happened and then installed LED landscape bulbs like 10 years ago (way ahead of my time and they worked except their frequency messed with my fob distance).
    Just unplug the bulbs if they bother you and be done with it.
    The newer installed LED bulbs have restored my fob action and light up the neighbor like a baseball field at night!
    because_wumbo-truck likes this.
  28. Oct 24, 2019 at 2:16 AM
    tvpierce
    Maine
    Sure. I won't get to it for a while but I can check it out.
    marbleville and bmf4069 like this.
  29. Oct 24, 2019 at 4:59 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Isn't there a switch? Mine has one.
  30. Oct 24, 2019 at 5:21 AM
    War Machine
    War Machine SSEM # 5 3MW
    Not trying to be a smartass here (for once), but why do you need this? I don’t see why it’s a problem for it to come on.
    @NewImprovedRon knows the electrical pretty well, so he may be able to help.
    NewImprovedRon likes this.
