Anybody Running 3 Car Seats?
Discussion in 'General Tundra Discussion' started by Cpl_Punishment, Jan 27, 2024.
  1. Jan 27, 2024 at 2:50 PM
    Cpl_Punishment
    Cpl_Punishment [OP] Do unto others as they've done to you
    Neil
    2020 MGM SR5 CM 4X4
    2020 Crewmax. Bought 3 Graco Slimfit 3LX car seats for our 3 kids. Tried to install one forward facing and two rear facing in the back seat of the truck. It doesn't seem to be possible to get the middle seat so it doesn't slide around because of the shape of the truck seat (convex where all other seats are concave).
    I think the big challenge is that the middle seat doesn't have UAS connectors. So I tried using the auto retracting feature of the seatbelt but to get it tight enough, it pulls one side of the car seat up. I also tried with one of those locking clips but it had the same effect.
    Has anyone gotten this to work?
  2. Jan 27, 2024 at 4:51 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I used industrial grade chain extensions to hook onto when I had a rear facer in the middle between 2 front facers. Worked well. Have you tried any extensions?
    Cpl_Punishment[OP] likes this.
  3. Jan 27, 2024 at 4:52 PM
    @Fotnot us running 8 car seats
    Cpl_Punishment[OP] and Fotnot like this.
  4. Jan 27, 2024 at 5:17 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sorry, I'm not sure what extensions are or how I would use them and Google was not helpful.
  5. Jan 27, 2024 at 6:00 PM
    MadMaxCanon
    I guess they are called quick links
  6. Jan 27, 2024 at 6:37 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    And you hooked those into the UAS anchors? My issue is there are only 2 sets of anchors - one for each of the outboard seats - and what I've read is that you can't hook two car seats to the same anchor unless your owner's manual specifically allows it, which it doesn't look like the Tundra manual does.
  7. Jan 27, 2024 at 6:57 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What happened to the days when you could have them sit on your right knee and lean against your right arm holding the wheel while you held the Coors Banquet in your left hand with a cigarette between your fingers?
    (sorry - not helping… :p)
  8. Jan 27, 2024 at 7:03 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm all for it but Momma Bear is really uptight about this shit.
    RainMan_PNW[QUOTED] likes this.
  9. Jan 28, 2024 at 12:04 AM
    MadMaxCanon
    They have to say that for liability but it's better than not using them at all. I hooked the quick link into the anchor and hooked tbe car seat hooks to that. For the middle seat I hooked one clip to the inner most link on each side of the car then I used the seat belt too. I trusted it completely it was really solid. All 3 seats had barely any play.
  10. Jan 28, 2024 at 12:07 AM
    MadMaxCanon
    Alternatively you can use seat belt and the top anchor point that goes to the back of the back seats and leave the seat anchors for just the muddle car seat. It'll stil be solid.
  11. Jan 28, 2024 at 12:37 AM
    blenton
    blenton New Member
    We've done three car seats in the double cab, but they weren't all the same so we were able to offset front facing, rear facing, front facing. Our youngest rides in the middle seat for easiest access on road trips and we used the anchor points for the left and right seats. There was always enough room to double up the strap anchors on the two inner anchors. Securing the middle seat with the seatbelt always let the car seat wobble and shake too much. We also removed head rests to let the car seats to sit back further; else it felt like they had 8-12" of gap where the seat contour didn't match the car seat contour.
  12. Jan 28, 2024 at 3:01 AM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    I have a forward facing Diono Radian 3r in the middle, it is secured with the regular seat belt and tether. It is the slimmest of their models and I am confident you could fit three across. A booster fits fine on either side currently. I have two other Diono seats in the Sequoia and am very happy with them, but they are slightly wider and didn’t fit as well in the Tundra.
    Here is a pic:
