Anyone dynoed a stock 2nd gen?
Discussion in 'Performance and Tuning' started by charge556, Jun 22, 2022.
  1. Jun 22, 2022 at 12:54 AM
    charge556
    charge556 [OP] New Member
    2017 Inferno 4x4
    From factory TRD off road package with 275/65/r18 TRD wheels;
    I have a 2017 NA limited (5.7 FFL). Anyone dyno tested this gen stock? I know its rated 381/401...just wondering how much hp/torque its losing from the drivetrain and restrictive stock exhaust....
  2. Jun 22, 2022 at 1:41 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    If you browse thru the stage 1 harrop thread. A few guys posted the before dyno
    mine was 287/310. It was a 90degree shop. Houston
    most folks are 300/310-ish
    I’ll add. I have a trd exhaust. No other mod at time of dyno
    snivilous, Saltyhero13 and 5N0W808 like this.
  3. Jun 22, 2022 at 3:17 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I highlighted the base run.
    the other run is untuned Stage 1 Harrop. 6psi-ish.
    this is a '20 - I doubt it differs much from yours.
    snivilous and Saltyhero13 like this.
  4. Jun 22, 2022 at 3:40 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    My stock run was similar to @nobodyintexas w/ 297HP/334TQ
    Not sure there is much to gain from the exhaust but @dirtydeeds could answer your question.
    snivilous likes this.
  5. Jun 22, 2022 at 6:01 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    DD exhaust will give 3-10HP and 10-20 torque, depending on rpm in a stock truck.
  6. Jun 22, 2022 at 7:27 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    They’re good for 335 Hp to the wheels on a dynojet. Simply fitting off the stock muffler is good for 3-10hp
    installing long tube headers with a BAmufflers 3” race exhaust is good for 49hp
    Saltyhero13 likes this.
  7. Jun 22, 2022 at 7:29 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    where in the rpm range is the gain?
    I'm guessing up top?
  8. Jun 22, 2022 at 7:50 AM
    dirtydeeds
    Keith
    USA
    That was my misconception also. Until I dynod it. With a properly built system such as the Bamufflers system, ALL of the powerband shifts ‘up’. There’s zero loss anywhere but gain everywhere.
  9. Jun 22, 2022 at 7:55 AM
    jbcrewmax
    jbcrewmax New Member
    SETX
    2019 TRD Pro
    Who'd you get to install your SC, or did you DIY? Just outside Houston and looking to get an SC in the next year or two
  10. Jun 22, 2022 at 7:57 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Peitz Performance did mine.
    Prospeed is good, too.
    D3 performance did my Stage 2 tuning.
    jbcrewmax[QUOTED] likes this.
  11. Jun 22, 2022 at 8:01 AM
    jbcrewmax
    SETX
    2019 TRD Pro
    Awesome, thank you.
